Download MacClean to Start Your Excellent Mac Cleanup Experience!
Download Now See Pricing
User Guide of MacClean
Learn how to clean junks, malicious cookies, potential risks as well as using the versatile Mac tuning tools. Download and try it now.
Free Download For Mac | 100% Clean & Secure
See PricingView Suitable Price Plan
Trash Sweeper
With MacClean, you can empty all of the Trash folders on your Mac permanently, including iPhotos, Word, Excel, etc.. Thus, these files cannot be recoverable completely anymore, which totally protects your privacy and data security. Please refer to the detailed guide to make good use of MacClean.
Step 1: Preparations.
Do as following:
  • Open MacClean from your Dock or Application List
  • Click Optimization Tools (1)
  • Choose Trash Sweeper (2)
Once you launch MacClean successfully, you will see the interface below:
MacClean Main Interface
Please select Trash Sweeper under Optimization Tools. Then, you will see the interface as below:
Select Trash Sweeper Function
Step 2: Analysis.
Do as following:
  • Tick junk files you want to delete (3)
  • Check total junk items (4) you tick
MacClean scans junk on your Trash automatically. To manage your data better, you can view junk list by name/size in descending/ascending order (5).
Choose Files to Clean
Step 3: Cleanup.
Do as following:
  • Choose a preferred removal solution (6)
  • Click Remove button (7) to reconfirm the erasure
Please unfold the solution menu to choose your preferred solution. After that, please click Remove button to reconfirm the cleaning action. To abort the cleaning process, please click Cancel button (8).
Remove Junk on Trash
1. The security level will go up from Remove Immediately to Remove Safely to Remove Completely. Please choose any solution as you need.
2. Please notice that once you delete the data with MacClean, it will be erased permanently. Please be cautious before starting the cleaning process.
After finishing cleanup, you will see the Cleanup Completed page. To go back to the previous page, please click Start Over button (9).
Cleanup Complete Page
FAQ
