Download MacClean to Start Your Excellent Mac Cleanup Experience!
Download Now See Pricing
User Guide of MacClean
Learn how to clean junks, malicious cookies, potential risks as well as using the versatile Mac tuning tools. Download and try it now.
Free Download For Mac | 100% Clean & Secure
See PricingView Suitable Price Plan
Privacy Issue Cleanup
MacClean provides a trouble-free and easy method to clean your Recent App Usage, App Documents and App Private Histories so as to protect your privacy. Please refer to the detailed guide to make good use of MacClean.
Step 1: Preparations.
Do as following:
  • Open MacClean from your Dock or Application List
  • Select Privacy Issue option(1)
Once you launch MacClean successfully, you will see the main interface as below:
The Main Interface
Please select Privacy Issue. Then, you will see the interface below:
Select Privacy Issue Function
Step 2: Analysis.
Do as following:
  • Click Scan button (2)
  • Wait for the scanning process
MacClean will analyze private data automatically after you click Scan button.
Scan Privacy Issue
You can abort the process at any time by clicking Stop button (3). Meanwhile, the analyzing time varies based on the size of junk files. Please keep patient.
Stop the Scanning
Step 3: Cleanup.
Do as following:
  • Review the junk list before cleaning
  • Start cleaning process
When the scanning completes, the total amount of junk files will be displayed. To avoid deleting your important data accidently, please tick items manually. To keep files you may need, you may click Review Details (4) to view all scanned files before cleaning them.
Review Details
You can choose all or parts of the junk files that you want to clean by checking the boxes (5) in front of them. To go back to the previous page, please click Back button (6).
Check Privacy Issue to Clean
After finishing checking process, please click Clean button (7) to continue and click Yes (8) to reconfirm the cleaning process. To abort cleaning process, please click Cancel button (9).
Clean Privacy Issue
Please notice that once you delete the data with MacClean, it will be erased permanently. Please be cautious before starting the cleaning process.
After finishing cleaning process, you will see the Cleanup Completed page. To go back to previous pages, please click Start Over button (10).
Cleanup Complete Page
FAQFAQ
