OK, got it
Download MacClean to Start Your Excellent Mac Cleanup Experience!
Free Download For Mac | 100% Clean & Secure
Some binary files are generated to fit for the requirement of different platforms. These files not only take up your Mac space, but may also slow down your applications running speed. Binary Junk Remover enables you to get rid of the superfluous junk easily. Please refer to the detailed guide to make good use of MacClean.
Once you open MacClean successfully, you will see the interface below:
Please select Binary Junk Remover under Optimization Tools. Then, you will see the interface as below:
MacClean scans and lists Binary files on your Mac automatically. To manage data before cleaning, you can check your scanned data by name/size in descending/ascending order (5). To go back to the previous page, please click Start Over button (6).
You need to confirm the cleaning process again before clicking Remove button. To abort the cleaning process, please click Cancel button (9).
Please notice that once you delete the data with MacClean, it will be erased permanently. Please be cautious before starting the cleaning process.
After finishing cleanup, you will see the Cleanup Completed page. To go back to the previous page, please click Start Over button (10).
We'd love to hear how MacClean is working for you.
If you're enjoying MacClean, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover MacClean and motivates our team!
