OK, got it
Download MacClean to Start Your Excellent Mac Cleanup Experience!
Free Download For Mac | 100% Clean & Secure
MacClean Update option enables you to check whether you are using the latest version of MacClean and Security Database. Please refer to guide below to update MacClean and install Security Database required to make good use of MacClean.
Once you launch MacClean successfully, you will see the interface below:
Please select MacClean Updata under Utilities. Then, you will see the interface as below:
The installation requires good Internet connection. Please make sure the Internet connection is fine during the installing process.
It may take several minutes to finish installing process. Please keep patient.
After finishing installing, you can use all functions as you need. To enjoy latest cleaning and optimization features in time, please check for update or Security Database once a week.
We'd love to hear how MacClean is working for you.
If you're enjoying MacClean, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover MacClean and motivates our team!
