Download MacClean to Start Your Excellent Mac Cleanup Experience!
Download Now See Pricing
User Guide of MacClean
Learn how to clean junks, malicious cookies, potential risks as well as using the versatile Mac tuning tools. Download and try it now.
Free Download For Mac | 100% Clean & Secure
See PricingView Suitable Price Plan
iOS Backup Cleanup
Given the security of data, iTunes or other 3rd party apps will help you back up your iOS device contents to your computer. These data may become useless and redundant after a period of time. iOS Backup Cleanup option helps locate and clean them to regain more free space. Please refer to the detailed guide to make good use of MacClean.
Step 1: Preparations.
Do as following:
  • Open MacClean from your Dock or Application List
  • Click Optimization Tools (1)
  • Choose iOS Backup Cleanup (2)
Once you open MacClean successfully, you will see the interface below:
MacClean Main Interface
Please select iOS Backup Cleanup under Optimization Tools. Then, you will see the interface as below:
Select iOS Backup Cleanup Function
Step 2: Analysis.
Do as following:
  • Tick backup files you want to delete from the list (3)
  • Check total space you can reclaim (4)
MacClean scans and lists backup files on your Mac by device name and type. To manage data before cleaning them, you can check your scanned data by date/size in descending or ascending order (5). To go back to previous page, please click Start Over button (6).
Check Backup Files
Step 3: Cleanup.
Do as following:
  • Click Clean button (7)
  • Click Remove button (8) after reconfirming
You need to confirm the cleaning process again before clicking Remove button. To abort the cleaning process, please click Cancel button (9).
Reconfirm the Cleaning
Please notice that once you delete the data with MacClean, it will be erased permanently. Please be cautious before starting the cleaning process.
After finishing cleanup process, you will see the Cleanup Complete page. To go back to the previous page, please click Start Over button (10).
Cleanup Complete Page
FAQ
