Download MacClean to Start Your Excellent Mac Cleanup Experience!
Download Now See Pricing
User Guide of MacClean
Learn how to clean junks, malicious cookies, potential risks as well as using the versatile Mac tuning tools. Download and try it now.
Free Download For Mac | 100% Clean & Secure
See PricingView Suitable Price Plan
Security Issue Cleanup
Through cleverly discovering and safely removing hidden danger on Mac, MacClean protects your Mac from the potential risk. To ensure good performance on risks scanning, please make sure you have installed and updated MacClean Security Database firstly. Then, please refer to the detailed guide to make good use of MacClean.
Step 1: Preparations.
Do as following:
  • Open MacClean from your Dock or Application List
  • Select Security Issue (1) option
Once you launch MacClean successfully, you will see the main interface as below:
MacClean Main Interface
Please select Security Issue. Then, you will see the interface below:
Select Security Issue Function
Step 2: Analysis.
Do as following:
  • Select a preferred scanning solution
  • Click Scan button (3)
  • Wait for the scanning process
MacClean provides 3 scanning solutions to choose the scanning target as you need. To scan your Downloads and Applications folders where risks may usually hide, please select Quick Scan.
Custom Scan
To scan potential risks in a specified folder, please switch to Custom Scan and then click Select (2) to add folder from your computer.
Quick Scan
To scan all files on your Mac thoroughly, you can choose Full Scan option. But notice that this process may take longer time to finish. Please keep patient.
Quick Scan
After selecting a preferred scanning solution, please click Scan button (3) to continue.
Quick Scan
Step 3: Management.
Do as following:
  • Check the name and location of the infected files
  • Clean the infected files or put them into Quarantine
  • Click Clean button
MacClean will list infected files after the scanning process completes. To locate the infected files, please clickBlack and white photo of magnifying lensbutton (4). To prevent any infected file from damaging your Mac, you can simply move it to Quarantine by clicking Black and white photo of No symbolbutton (5). You also can delete the file directly by clickingBlack and white trash can button (6).
Manage Scanned Files
After clicking Black and white no symbol button, the infected file will disappear from your list and you can check it under Quarantine.
To clean infected files massively, please tick the box in front of each file and click Clean button (7). And then, please click Yes button (8) to reconfirm the cleaning process.
Clean Infected Files
Please notice that once you delete the data with MacClean, it will be erased permanently. Please be cautious before starting the cleaning process.
After finishing cleaning process, you will see the Cleanup Completed page. To go back to previous pages, please click Start Over button (9).
Cleanup Complete Page
FAQFAQ
