OK, got it
Download MacClean to Start Your Excellent Mac Cleanup Experience!
Download Now See Pricing
User Guide of MacClean
Learn how to clean junks, malicious cookies, potential risks as well as using the versatile Mac tuning tools. Download and try it now.
Free Download For Mac | 100% Clean & Secure
See PricingView Suitable Price Plan
App Uninstaller
MacClean helps remove applications with all of their related files correctly. And the App Uninstaller displays all applications available on your Mac. You can decide whether to remove them or not based on your needs. Please refer to the detailed guide to make good use of MacClean.
Step 1: Preparations.
Do as following:
  • Open MacClean from your Dock or Application List
  • Select Cleanup Tools button(1)
Once you launch MacClean successfully, you will see the main interface as below:
The Main Interface
Please select App Uninstaller (2) under Cleanup Tools. Then, you will see the interface below:
Select App Uninstaller Function
Step 2: Selection
Do as following:
  • Tick App (3) you want to uninstall
  • Check App data before uninstalling
MacClean lists all app names in alphabetical order. To check which app taking up your Mac space quickly, you can view app list by name/size in descending/ascending order (4). And you also can check the number and size of the files you tick (5) from the bottom.
Check App List
MacClean also lists the App attachments on the right side of the page and ticks all attached files by default. To keep files you may need, please untick them (6) as you want.
Untick Attachment to Keep
Please notice that once you uninstall the app with MacClean, all the app data and related files will be erased permanently. Please weight cautiously before start the uninstalling process.
Step 3: Uninstalling.
Do as following:
  • Click Clean button (7)
  • Click Remove button (8) to reconfirm the uninstalling
After reconfirming this action, please click Remove option. To abort the uninstalling process and go back to previous page, please click Cancel button (9).
Confirm the Uninstalling
After finishing removing process, you will see the Cleanup Completed page. To go back to the previous page, please click Start Over button (10).
Cleanup Complete Page
We'd love to hear how MacClean is working for you.
If you're enjoying MacClean, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover MacClean and motivates our team!
