Download PhoneClean to Start Your Excellent iOS Device Clean Experience!
Free Download For Win & Mac | 100% Clean & Secure
“How can I clean iOS notifications on my old iPhone XR?”
“I want to clean app leftovers and active apps on my iPad 9. What should I do?”
If you just encounter the similar issue above, don't worry. You can try “System Clean” mode to clean iOS Notifications, App Leftovers and Active Apps on your iOS devices. The following instructions will help you do it.
Windows OS | Windows 11, 10, 8, 7, Vista, XP (64bit & 32bit) |
macOS | macOS 10.8 and later |
iOS | iOS 5 and later |
Benefits | Trial Version | Activated Version |
Clean System Data | ![]() |
Before you start to use System Clean function, get the tool downloaded and installed on your computer. Please make sure the network is stable while downloading and installing PhoneClean on your computer.
Choose System Clean mode. By default, PhoneClean will detect your iOS device automatically. If you don't connect your iOS device to computer or your iOS device is not recognized, you will see "No Device Connected" on the interface.
No Device Connected
Once your iOS device is recognized, the interface below will display. PhoneClean supports multi-devices connection. At the same time, you can check which iOS device is ready to be cleaned in the middle of the interface.
Your Device Is Connected
If PhoneClean is not able to recognize your iOS device, you may try these troubleshooting steps to solve this problem.
Given the importance of your data, System Clean will back up your data automatically before cleaning junk files. Even though you delete data by accident, you may find them back from backups. The backup interface will display after clicking Scan button. You can abort the process at any time by clicking the Cancel button. Meanwhile, the backup time varies based on the size of data.
Load Data on Your Device
Apple will not let the third party software to detect encrypted backup for protecting user's privacy, so you need to uncheck encrypted backup firstly.
The interface of analyzing iOS device will display after loading data on your iOS device. And the analyzing time varies based on the size of junk files. Please keep patient.
Analyze Data Now
When the scanning begins, please keep your device connected until the process completes.
When the scan completes, the total amount of items ready for safe cleanup is displayed below. To keep files you may need, you may click Review Details to view all scanned files before cleaning.
Review Details
System Clean would clean all scanned data by default. To prevent cleaning files you may need, you may uncheck the box in front of it. To go back to the previous page, please click Back button.
Choose File You Want to Clean
Click on Clean button to free up your device's space after finish checking details. The time to clean depends on the size of the junk. To ensure a smooth cleaning process, please keep your device connected until it finishes.
Clean Data on Your Device
To use Internet Clean feature, you need to turn off Find My iPhone / iPad / iPod touch option on your device temporarily.
To refresh data in your iOS devices, your iOS devices will restart automatically after finishing uploading data. Please keep patient.
Your Device Restarts
When the cleaning process is complete, you will see the System Clean Complete screen, and you can click Start Over button to return to the main interface of PhoneClean.
System Clean Completed
If you still have questions after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how PhoneClean is working for you.
If you're enjoying PhoneClean, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover PhoneClean and motivates our team!
