Download PhoneClean to Start Your Excellent iOS Device Clean Experience!
Free Download For Win & Mac | 100% Clean & Secure
“How can I clean the App Caches and App Cookies on my iPhone 5s without USB?”
“What should I do if I want to erase Photo Caches, Artwork Caches on my iPhone?”
If you just encounter the similar issue above, don't worry. You can try “Silent Clean” mode to clean junk files remotely associated with Apps, Photos, Downloading Temp Files, Artwork Caches and Crash Log even without connecting your iOS device to computer.
Windows OS | Windows 11, 10, 8, 7, Vista, XP (64bit & 32bit) |
macOS | macOS 10.8 and later |
iOS | iOS 5 and later |
Junk File Types | iOS 8.2 or earlier | iOS 8.3 or higher |
App Caches, App Cookies, App Temp | ![]() |
Download Temp Files, Crash Log, Photo Caches, Artwork Caches | ![]() |
Apple blocks Apps access permission for iOS version 8.3 or higher because of security issue.
Benefits | Trial Version | Activated Version |
Clean Your iPhone with Wi-Fi | ![]() |
Before you start to use Silent Clean function, get the tool downloaded and installed on your computer. Please make sure the network is stable while downloading and installing PhoneClean on your computer.
Please choose Silent Clean mode. If it is the first time to use Silent Clean, you need to connect your device to computer to enable the cleaning feature. Once your device is recognized, you can see the device name in the upper middle of PhoneClean interface. Please switch the button on the lower left corner from grey to blue to enable Silent Clean.
Enable Silent Clean on the Device
Disconnect the USB connection, and connect your device and computer to the same Wi-Fi. And then Silent Clean will detect the device and start the cleaning process automatically.
Cleaning in the Process
To let the cleaning process work smoothly, please try to put your device closer to the computer for keeping Wi-Fi connection stable.
You can view the details of Current Cleaning Session as well as the Silent Clean Histories. And you may delete any Cleaning history by clicking Delete button. If you want to deactivate Silent Clean, please switch the blue switch to grey.
Silent Clean Completed
If you still have questions after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
We'd love to hear how PhoneClean is working for you.
If you're enjoying PhoneClean, we'd be so grateful if you could leave us a review on Trustpilot. Your support helps others discover PhoneClean and motivates our team!
