How to Use Phone Camera as Webcam for Zoom
Are you wondering about how to use an iPhone or an Android phone as a webcam for Zoom? If so, read this post thoroughly and get your hands on it flawlessly.
Author Avatar Joy Taylor Last Updated: Sep. 18, 2021
In this pandemic, video calls are continuously being used in place of face-to-face meetings. But it is inconvenient for you to take the laptops anywhere. And multiple online video calling services like Google Meet, Zoom, and Skype are the new conference room for workers, but they do come with some quirks.
If you join Zoom call from your laptop or PC, then its built-in camera is not capable of delivering high-quality videos that are otherwise possible. Taking the Zoom call from the PC’s built-in camera increases the chances of bad video quality. Having a high-definition image of yourself helps to get the most out of Zoom meetings, but if you have to deal with your laptop’s built-in camera, or you don’t have a laptop beside you, then you may find yourself quite annoying during the entire Zoom call session. But fortunately, there are great ways to tackle this!
If you are eager to know how to use a phone as a webcam for Zoom, we got your back. In this article, you’ll learn effective ways to use Android Phone and iPhone as a webcam for Zoom.
What Is A Webcam for Zoom?
A webcam is typically a small camera that sits on a desk, attaches to a user’s monitor, or is built into the hardware. Webcams can be used during a video chat, conference, or online classroom, etc, allowing a user to be seen by other users on the Zoom call. The global pandemic has replaced personal conversations with Zoom and other video conferencing applications. Though the laptops come with built-in cameras, most of them don’t deliver satisfactory video quality.
In this case, you can connect your Android phone or iPhone as a webcam and use its camera for video calling. Using your phone’s camera as a webcam for zoom will make it possible for you to attend video calls with high-quality video anywhere you like.
Use Android Phone as Webcam for Zoom
It might sound pretty challenging, but in reality, it is not at all problematic. Even for novices and starters, it’s not at all challenging to use Android as a webcam for Zoom. All it needs are few easy steps involving connecting your phone and PC to the Wi-Fi, installing a webcam application on both the devices, i.e., PC/Laptop and Phone, pairing them together, and changing the camera in Zoom.
This was just a glance at how to use the phone as a webcam for Zoom, but below stated are detailed steps that will help you use Android phone as a webcam for Zoom calls. But before moving to the step-by-step guide, let’s look at what needs to be prepared before doing that!
Prerequisites need to be fulfilled:
  • A PC or Laptop
  • An Android device
  • Stable Wi-Fi- connection
  • Webcam application and its related computer drivers
Below stated are the steps you need to follow to use your Android phone as a webcam for PC.
1. Firstly, connect your Android phone and PC to the same Wi-Fi network. Then, install any Android webcam applications like iVCam on your Android phone and iVCam PC client on your PC.
If you don’t have a Wi-Fi connection, then you can use the secondary phone to create a hotspot and connect your PC and phone to it.
2. Once the app on your Android phone automatically detects the PC, make sure they both are connected to the same Wi-Fi network.
Wait for iVCam Connection
Though the iVCam app will automatically connect to the PC client, sometimes you may have to hit the “Connect” button manually.
Once done, your Android phone will now work as a webcam connected to your computer, and its camera video will show in real-time on your PC’s screen. You can easily use the controls of your phone to switch the front camera, apply enhancements, and much more. You can also change the video preferences in the iVCam PC client settings.
Certain Changes Need to Be Done on Zoom
If you are using iVCam on your computer, you need to change certain settings on Zoom app for it. Follow the steps below:
1. Open Zoom on your PC and click on the “gear” icon at the top right corner of your screen.
Tap on the Gear Icon
2. Click on the “Video” option from the sidebar at the left and tap the drop-down menu under “Camera.”
Go to the Video Option
3. Finally, select “e2eSoft iVCam” from the list and save the settings.
Choose the e2eSoft iVCam Option
You can now join a Zoom call, and it will start using your Android phone’s camera for the meeting.
Use iPhone as Webcam for Zoom
If you’re an iPhone user, then the above-mentioned application can help you use iPhone as a webcam for Zoom, but here in this section, we will introduce you to another top-notch application that will flawlessly allow you to use iPhone as a webcam for Zoom!
What you need to prepare beforehand:
  • A PC or Laptop
  • An Android device
Here’s how to use iPhone as a webcam for Zoom:
  1. Connect your iPhone and PC to the same Wi-Fi network.
  2. Download and Install the Iriun webcam application on your iPhone via App Store and download its client software on your PC. After downloading the application on both devices, grant all the permissions required to set up.
  3. Now, wait until your iPhone and PC connect with each other. Once both the devices on the same Wi-Fi network connect with each other, you can seamlessly use the camera of your iPhone as a webcam for joining Zoom call on PC.
Wait for Iriun Connection
That’s all!! It was this easy-to-use iPhone as a webcam for Zoom. You can now change the video settings either from your PC or your iPhone.
Few Changes Need to Be Done before Joining the Zoom Call
If you are using Iriun, follow the steps below to set Zoom:
  1. Open Zoom on your computer > Tap on the “gear” icon at the top right corner of your screen > Select the “Video” option from the left panel > Click on the drop-down menu under “Camera.”
  2. Select the “Iriun Webcam” option from the list and save the settings.
You can now join a Zoom call, and it will start using your iPhone’s camera as a webcam for PC.
With this easy-to-understand guide, it’s now clear how to use the phone as a webcam for Zoom! Whether you are an Android phone user or an iPhone user, we have listed the steps compatible with each device. So, what are you waiting for? Grab your phone and PC, get connected to a stable Wi-Fi connection, and start using your phone’s camera as a webcam for joining Zoom calls on PC. Do try and let us know the feedbacks!
