How to Use Your Android/iPhone as Webcam for PC
Do you want to use your phone as a webcam for making a video conference on Zoom or Skype? If yes, then you don’t need to worry because we are going to offer you proven ways to use your phone as a webcam 2021. Continue reading and try a specific solution according to your needs.
Author Avatar Joy Taylor Last Updated: Feb. 17, 2022
In today’s digital-savvy world, webcam play a significant role in our day-to-day corporate life. May it be attending videoconferencing virtually, such as Zoom and Skype. Or you may need to connect in one-to-one sessions over a video call sometimes. In these occasions, a webcam is a must for delivering high-quality videos. Webcams are still quite hard to find or select, and also the camera on your laptop isn’t professional for delivering flawless video. Still, fortunately, there’s another option, and that’s to use your phone as a webcam. Yes, you read that correctly!
How to Use Phone as Webcam
The Smartphones that you use for various purposes can also be used as a webcam for discord, so as to offer you a high-quality video calling feature and make you look better. How to use a phone as webcam discord might sound pretty challenging, but in reality, it is not that tough as long as you choose the right toolkit. In this guide, we will show you how to use your phone as a webcam, along with suggesting great Android and iOS applications that can help you get the most out of your phone’s camera!
Can You Use Phone as Webcam for PC?
Many of you might have this question stuck in your mind, but the answer to this is really, very simple!! Yes, you can undoubtedly use your Smartphone as a webcam discord on PC. Whether you own an Android device or an iOS device, you can seamlessly turn your phone into webcam discord on PC within a couple of minutes.
Well, even if you have a built-in camera on your laptop, then chances are your phone’s camera is much better, and therefore it can be used as a webcam. Along with the basic methods of using a phone camera as a webcam, there are a lot of applications to help you! Here in this article, you’ll get to know basic methods as well as apps that will turn the camera of your phone into a webcam for discord on PC.
As using your phone as a webcam via USB or Wi-Fi is complicated, we highly recommend you use some professional webcam apps to use phone as webcam for discord. So, let’s start with some proven webcam solutions in 2021. Detailed steps will be offered accordingly.
How to Use Phone as Webcam via AnyMirror?
AnyMirror, as a powerful mirror tool, can help you use phone as webcam for PC. There are no technical requirements, as long as you want, you can use your Android phone as a computer camera anytime and anywhere. These are reasons why you need AnyMirror to use your phone camera as Webcam:
  • Mirror your iPhone or Android’s camera to either your Windows computer or Mac computer with a few clicks.
  • Use your iPhone or Android phone as a webcam easily on your own.
  • Support all Android brands with Android 5 and above as well as iPhone/iPad/iPod touch.
  • Connect via Wi-Fi flexibly or USB cable stably – choose what’s best for you.
Step 1. Download and Install AnyMirror on Your Computer and Your Phone
Free download AnyMirror on Windows/Mac computer > Then double click on anymirror-en-setup.exe to install it. At the same time, search AnyMirror in Google Play and download it on your Android device.
Select Function on AnyMirror
Step 2. Connect Your Phone to Computer with a USB
1. Open AnyMirror on your mobile phone and computer. Choose the Camera Mirroring mode on your phone.
Choose Camera Mirroring
2. Then, connect your Android device to computer with a USB cable (You can also connect your Android device to the computer via Wi-Fi) > Turn on the USB Debugging in Settings.
Turn on USB Debugging for Android
Step 3. Mirror Camera to Computer and Use Your Phone as a Webcam
1. When your Android device is detected successfully by AnyMirror, your camera will be mirrored to the computer. You can also draw, record the screen and take a screenshot via the tools at the top-right corner.
2. You can freely switch the front or rear camera, and cast any scene you want.
Edit the Mirroring screen on Your Device
How to Use Phone as Webcam via iVCam Webcam
iVCam Webcam is another webcam application that most Android users can use seamlessly to use phone as a webcam. This application allows you to deliver high-definition videos. With iVCam Webcam, you will get the opportunity to adjust the video and audio quality settings, frame rate, and it even supports multiple modes like macro or portrait. In addition to all this, this app also supports numerous modes for screen mirroring, flash, and face beauty. With its easy-to-use interface, you can attach your Android device to the PC with no wires and use it as a webcam.
Use Android Phone Camera as a Webcam via iVCam Webcam
To know more about iVCam Webcam, have a look below!
Key Features:
  • High-quality video with low latency and fast speed
  • Automatic connections via USB or Wi-Fi
  • Supports common video sizes like 360p, 480p, 720p, 1080p and 4k
  • Supports front, rear camera and real-time switching
How iVCam Webcam Use Phone as Webcam?
Download and load the iVCam Webcam application on your Android device and its computer drivers on your PC. After setting up the application by following the on-screen instructions, connect your phone with iVCam to use it as a webcam on PC. You can do this either via Wi-Fi or USB. Now, wait for iVCam Webcam to detect and configure your Android phone as a webcam. Once it is ready, you will see a handful of icons to control the video settings on the iVCam toolbar on your phone’s screen. Later, iVCam will show up as a webcam for all the video chatting platforms on your PC.
Pros:
  • Supports face beauty feature
  • Completely replaces USB webcam
  • Easy to use
Cons:
  • The free version involves multiple ads in between
  • Fewer features are available in the free version
Supported Platforms:
Windows 7/8/10 and macOS
How to Use Phone as Webcam via EpocCam
If you are an iOS user, then EpocCam is also a feasible application that will help you use phone as webcam flawlessly without much hassle. It is basically a cross-platform that is available for Android, iOS, macOS, and Windows. With EpocCam, you can seamlessly transform your phone companion into a high-definition PC webcam. The best thing about this webcam application is that it is free to use, but the free version comes with limited features. So, if you want to avail the benefits of advanced features, you have to switch to its paid version.
Use iPhone Camera as a Webcam via EpocCam
To know more about EpocCam Webcam, have a look below!
Key Features:
  • Stunning video quality
  • HDR color
  • Manual focus
  • Wide-angle camera support
  • Green screen
How EpocCam Use Phone as Webcam?
To use the EpocCam Webcam application, you simply need to download it from the App Store on your iPhone and install the computer drivers for Windows or macOS. Restart your PC after installing the desktop software. After restarting, launch the EpocCam Viewer application on your PC alongside the EpocCam app on your Android phone to check if it’s working fine. As long as both phone and PC are on a similar Wi-Fi network, they will link automatically. Later, EpocCam will show up as a webcam for all the video calling platforms that you may use.
Pros:
  • Excellent video and audio quality
  • Available in free version
  • Premium version is quite affordable
Cons:
  • Ads are interrupting
  • Limited features in the free version
Windows 10 or later, macOS 10.14 or later
How to Use Phone Camera as a Webcam without App?
As you have learned the professional ways to use phone as webcam 2021, now it’s time to figure out some ways that will not require you to download any application. Though many Android and iOS applications can turn your phone’s camera into webcam discord for PC, some of the users continuously hunt for effective ways relating to “How to use the phone as webcam discord without app”!
Though there are some methods that can help you use a phone camera as a webcam without requiring you to download any special application, not all of them are reliable or easy to complete. So, here we have compiled a list of the top 2 methods that will free you from the hassle of downloading any special application to turn your phone’s camera into a webcam. Both the methods included in this section are very basic, and therefore, you can opt for any of them depending upon your system requirements.
Method 1. How to Use Phone Camera as a Webcam via Wi-Fi
The first and foremost method to use your phone as webcam discord for PC is via Wi-Fi. In this method, your Smartphone’s video will be streamed and made available to the applications on your PC via Wi-Fi. This method might sound quite confusing, but it is the easiest and most flexible way to use your phone’s camera as a webcam.
Requirement: Your Android device and computer must be connected to the same network with Android connected via Wi-Fi.
Once your Smartphone is connected to the PC network via a stable Wi-Fi connection, you need to follow the steps stated below!
Step 1. Go to Play Store and download IP Webcam.
Step 2. Open the application, and there you will get the configuration screen where you can easily set the options for sound, video quality, port, and username/password.
Click the Options for IP Webcam Settings
Step 3. Now, scroll down and tap on the “Start Server” option.
Step 4. IP Webcam will now turn on your phone’s camera and start streaming the video to a specific IP address and port. Here, click on the “How Do I Connect” button at the top left corner of the screen and select the “I’m using Wi-Fi router” option to get this IP address and port. Now, few things like “HTTP:// 10. 42. 43. 89: 8080” will appear on the screen.
Get IP Address and Port
Step 5. Note this IP address and enter it on your PC’s web browser. You will get a page with links for multiple ways in which you can use your new webcam. From the list, you can use either of the two links i.e.
  • Connect to PC for use with Skype and other video chats on Windows
  • Connect to PC for use with Skype and other video chats on Ubuntu GNU/Linux
Choose the IP Address Link to Enter on PC Web Browser
Depending on your Operating System, use the specific links to download and install the web driver on your PC.
  • For Windows, the driver comes as an easy and quick installer.
  • For Linux, it comes as a script that needs to be run in a terminal as a root. Before running, change the value of variable “WIFI_IP=” to the IP address from IP Webcam in the script.
Google Plus Hangout with Android as Webcam via WiFi
That’s all! It was this easy-to-use Wi-Fi for turn your phone’s camera into a webcam for discord. Now, you can open Skype or any other video calling application and choose the webcam driver you recently installed and start it.
Method 2. How to Use Phone Camera as a Webcam via a USB
Another method to use your Android device as a webcam is via USB. By opting for this method, you will need to work extra hard because Android devices can communicate with PC via USB only in the USB debugging mode by using ADB.
Also, for USB mode, you will need an application called DroidCam. So, here’s a guide on how to use a phone as a webcam for discord via USB.
Step 1. Go to “Settings”> “About Phone” and hit 7 times to become a developer and then go to “Developer Options” > “USB Debugging” to set up your Android device in debugging mode.
Step 2. Connect your Android device to the PC via USB. Make sure not to select the storage mode if the phone asks while connecting USB.
Step 3. Install DroidCam from the Play Store and launch the app. It will show a “Starting Server” message on your phone’s screen.
Use DroidCam for Mode
Step 4. Now, download and install the application on your PC from Dev47Apps.
Step 5. Start the DroidCam client and select the “USB” option.
Choose the USB Button to Open the Camera of Your Phone
That’s all!! DroidCam will now open the camera of your phone, and you can then use it as a webcam on your PC. You need to configure the video settings of your video calling application to use the “DroidCam” driver.
Google Plus Hangout Webcam from Phone via USB
“How to use the phone as webcam discord” is no longer a problem with the help of AnyMirror. No matter which method you opt for, you will definitely get excellent results! So, what are you waiting for? Choose the method of your choice and convert your phone’s camera into a high-definition webcam discord on PC in a quick and hassle-free manner.
