Webcam Test on Windows and MacOS
You may use the built-in webcam on your computer to chat with others or join in a conference. No matter you are using a Windows or Mac computer, you should see whether the webcam is workable before communicating with others online. Read this article to know how to test a webcam before using it.
Author Avatar Joy Taylor Last Updated: Aug. 24, 2021
For both personal and professional communication, webcams have become increasingly vital. Video conferencing is being used by more individuals than ever before to replace audio calls that went on forever.
Webcam Test on Windows or MacOS
Webcam Test on Your Computer
It’s critical to be able to view what your webcam will show other people before starting a call or making a video conference. Maybe you want to make sure you look well or hide your cluttered bedroom. Here are near all the ways to test your camera before using it.
How to Test Webcam on Windows?
Most of the new Windows Versions come with Inbuilt Webcam Apps. But the older versions do not have such a luxury that you may turn to other webcam alternatives. However, don’t worry; there is a solution for every issue. Read on to find out how to test webcam on different Windows versions.
How to Test Webcam on Windows 10?
You might not realize it, but Windows has a Camera software that automatically displays your webcam feed. The app allows you to shoot still photos and record videos. To know how to test webcam Windows 10, continue reading.
  1. Press the “Start” button and type Camera.
  2. Click the “Camera” app when it appears in the search results.
  3. The Webcam will turn on when the Camera app is launched, and you will see the Camera feed. Users who are using the Camera app for the first time must allow permission for the app to run.
How to Test Webcam on Windows 7?
Since Windows 7 does not have an integrated app. You can use VLC Media Player. VLC is a free media player and it can stream media live from a variety of sources, which is a lesser-known feature. While it’s most commonly used for streaming online video, it can also be utilized to see what your webcam is seeing right now. The steps below will show you how to check your webcam with VLC Media Player.
  1. Open VLC Media Player on your Windows 7.
  2. On the left upper corner, select the “File” option >
  3. Scroll down and choose the “Open Capture Device”.
  4. In the “Open Media” window, select your webcam from the Video device name dropdown menu.
After selecting your webcam, VLC should display live webcam playback in the video playback section. You can modify the capture frame rate for a smoother live playback experience using the Advanced Options menu (found in the Open Media Device dialogue box).
How to Test Webcam on Mac?
Testing webcam on MacOs is easy. You can use the inbuilt webcam feature to test the Mac camera. Continue reading to know-how.
  1. Open the Finder by double-clicking on the icon. It’s a blue and white smiley face-looking icon. It’s at the bottom of your screen, in the Dock.
  2. Go to the Applications tab.
  3. Open Photobooth. Photobooth will detect your webcam and instantly open it. It is working well if you can see your image from your webcam.
How to Fix My Webcam Not Detected?
Why is the webcam not detected? A non-detected webcam could be caused by faulty hardware, missing or outdated drivers, privacy settings issues, or issues with your antivirus software. In this part, we will discuss how to fix webcam not detected on Windows or Mac computers.
Fix 1. Check Your Antivirus Program
Suppose your laptop camera won’t open or work, or you get an error message claiming it can’t be located or started. In that case, it could be due to antivirus software preventing it or an outdated webcam driver.
Check your antivirus program for options relating to preventing access or granting permission to use your webcam in this scenario. You can also go to the website of the antivirus software provider.
Fix 2. Ascertain Your Software Is up to Date
Check for general updates in your computer’s software. Alternatively, if your webcam stops working after a recent software update, check the program you’re using to see whether it needs to be updated to work with your current operating system. To upgrade the program, you may need to reinstall the app.
Fix 3. Look for Applications that Use the Camera
In most cases, the camera can only be used by one Mac app at a time. Make sure the app you’re attempting to use isn’t being denied access to the camera because it’s being used by someone else at the moment. Close any other open applications that may be using the camera to see if that solves the problem.
Fix 4. Restart the Computer If Necessary
You can restart your Mac by going to the Apple Menu in the upper left-hand corner of the screen and selecting Restart. If any background programs are using the camera, restarting the computer may resolve the problem, giving you full access to the camera once more. Once the computer has been turned back on, check to see if your webcam is working properly.
To prevent getting lost in the virtual shuffle, practicing with the camera is the best option. It enhances a participant’s accountability by giving them greater space to stay focused. Put your best face forward, exercise social distancing, and make the most of Webcam testing’s flexibility and ease.
