How to Fix Lenovo Laptop Camera Not Working
Are you finding ways to fix the Camera of your Lenovo laptop that is not working fine? If no, then we’ve got your back! Discover the effective workarounds here that will help you fix the Lenovo laptop camera not working in just a couple of minutes!
Author Avatar Vicky Carter Last Updated: Aug. 30, 2021
The pandemic has made most things virtual. From attending classroom sessions to office meetings online, video conferencing is the only mode available that can help you attend the meetings online. Now, when it comes to video conferencing, there are a handful of necessary types of equipment that must be present, and most importantly, a laptop camera or webcam should be a good choice to deliver high-quality videos. But what if your Lenovo camera not working in zoom?
Well, if you have a Lenovo laptop whose Camera is not working, then you will not be able to attend the meetings or sessions online. In order to help you fix the Lenovo laptop camera not working, we have compiled a list of effective quick fixes below. Read along and get your hands on any of the methods at your convenience!
But before moving ahead to the quick fixes, it’s pretty important for you to know the possible reasons behind why the Lenovo camera black screen issue arises. Let’s have a look then!
Why is my Camera Not Working on Lenovo Laptop?
Here, we have listed below some of the possible reasons that could prevent your Lenovo camera from working flawlessly!
  • You have not selected the Camera in the application or program that you are using.
  • The program you are using does not recognize the Camera.
  • Another program is using the Camera.
  • The privacy settings are blocking the Camera from working fine.
  • The camera driver has encountered an issue.
  • The Camera is defective.
One or more reasons above can cause the issue of Lenovo camera black screen! So, make sure to recognize the problem first and then follow the appropriate solution below to fix your Lenovo laptop camera.
How to Fix: Camera Failed Error on Samsung Phone >
How to Fix Lenovo Laptop Camera Not Working Windows 10
“Lenovo laptop camera not working” is no longer a challenging issue with these solutions below! Go thoroughly through each of the quick fixes and get your Lenovo laptop camera repaired at the comfort of your home.
1. Check Camera Privacy Mode
Windows allows the users to tweak the Privacy Settings of the Camera in order to have complete control over allowing the camera access to your laptop. By changing the Camera Privacy Mode, you can allow or disallow access to the Camera on your Lenovo laptop. You can even change the Camera Privacy Mode settings to which applications are allowed or denied to access Camera.
So, if your Lenovo laptop camera not working, then it might be possible that there’s some issue with the Camera Privacy Mode. In order to check and fix this, you need to follow the steps below:
Step 1: Open the Lenovo Vantage app on your Windows laptop. In case you don’t have the application installed on your device, you might have to install it.
Step 2: Click on Hardware Settings.
Step 3: Under Hardware Settings, select the Audio/Visual option from the list.
Select the Audio/Visual
Step 4: Now, scroll down a bit until the Camera Privacy Mode menu is visible. Make sure that it is OFF.
Toggle Off Privacy Mode
Once you turn off the Camera Privacy Mode, you will then be able to use the Camera on your Lenovo laptop. If, in case, the issue of the Lenovo camera not working in zoom continues to exist, then try resolving it by following the next solution below.
2. Check if Lenovo Camera Driver is Installed Properly (Device Manager)
Another way to fix the Lenovo camera black screen issue is by checking if the Lenovo Camera Driver is installed correctly. There are times when the Lenovo Camera Driver is not installed appropriately, and this might stop the Camera of your laptop from working fine. It is also possible that the current camera driver in your Lenovo laptop is corrupted or in conflict with Windows 10, and this might trigger the Lenovo laptop camera not working issue.
So, you must try reinstalling the driver by following the steps below and check if it fixes the camera problem.
NOTE: Uninstall the current driver before reinstalling it.
Step 1: On your laptop’s keyboard, press the Windows Logo + R key together to open the Run dialog box. Here, enter devmgmt.msc in the empty field and press Enter.
Enter devmgmt.msc in Empty Search Field
Step 2: Now, double click on either Imaging Devices or Camera to reveal the Camera of your device.
Click Imaging Devices
Step 3: Here, right-click on your Camera Device and tap on Uninstall Device.
Tap on your Camera Device and Choose Uninstall Device
Step 4: Click on Yes to continue the uninstallation process.
Step 5: Now, Restart your laptop and open the Device Manager window again. Here, click on Action and select Scan for hardware changes to continue.
Click on Action and Choose Scan for Hardware Changes
After following all the steps, Reboot your Lenovo laptop and check whether the issue of the Lenovo camera not working in Zoom is resolved!
3. Check Whether Camera is Disabled on Device Manager
Sometimes the issue of the Lenovo laptop camera not working can be caused if the Camera is disabled on Device Manager. So, to fix this error, you can opt for verifying whether the Camera is disabled on Device Manager. For this, you need to:
Step 1: Press Windows + R key simultaneously to open the Run dialog box.
Step 2: Enter devmgmt.msc in the empty field and hit the OK button to continue.
Step 3: In the Device Manager window, search for Imaging Devices and then right-click on it.
Step 4: Finally, choose Enable to continue.
Choose Enable Device
After enabling, Restart your laptop and check whether the error of the Camera not working is now fixed or not!
4. Verify the Program Settings
If none of the above-mentioned solutions helped you fix the Lenovo laptop camera issue, you could try fixing it by checking the Program Settings. Sometimes, it may be the Program Settings and not the Camera Settings causing the problem.
So, here’s how to verify the Program Settings!
Step 1: Open the program that you wish to use and locate the Settings menu option.
Step 2: Make sure the Lenovo Camera is set to be the Default Camera in those Settings.
Set your Lenovo Camera as Default
This might be an obvious solution for many of you, but it is worth trying if you are getting a problem with your Lenovo laptop camera to work!
Bonus Tip: How to Turn on my Camera on my Lenovo Laptop
As you have got to know how to fix Lenovo laptop camera not working, now its time for you to know how to turn ON the Camera on your Lenovo laptop.
Here’s a step-by-step guide to help you turn ON the Camera on your Lenovo laptop!
Step 1: Go to Start and choose Camera in the list of applications.
Step 2: Once the Camera is activated, you can easily flip the Camera back and front by clicking on the Camera Flip icon.
Alternatively, if you wish to use Camera within other applications like Zoom, Google Meet, etc., select the Start button, click on Settings > Privacy > Camera, and turn on Let apps use my Camera. From there, you can easily turn on each of the listed applications where you wish to use the Camera of your Lenovo laptop.
This was all about fixing the Camera on your Lenovo laptop. Since the Camera on your Lenovo laptop is of great use, therefore it must work flawlessly all the time to offer you the best video conferencing experience. So, without wasting much time, opt for the above-stated method of your choice and fix the issue of the Lenovo laptop camera not working in just a couple of minutes. No matter which quick-fix you opt for, you will surely get the best results without much hassle!
Vicky Carter Twitter Share Facebook Share
Member of iMobie Inc., is also a more than 3-year user of iPhone, iPad and iMac, like to fix all kinds of iOS and Mac OS problems.
