10 Best Voicemeeter Alternatives: Tools for Enhanced Editing!
  • 180+ lifelike VST and AI voice effects.
  • Compatible with 13 popular third-party platforms.
Home Voice Changer 10 Best Voicemeeter Alternatives: Tools for Enhanced Editing!
If you’re a game enthusiast or love to explore the fun and success behind voice changing, you need to explore 10 best voicemeeter alternatives. By reading this guide, you will choose your desire and seamlessly enhance your gaming and chatting.
Joy Taylor | Last Updated: Aug. 01, 2024
2182 words|7minute
Do you want to explore that one fantastic application that allows you to quickly mix any sound, device, or app? Here it is!
We are thrilled to share a detailed guide on what is Voicemeeter and an alternative to Voicemeeter! So stay tuned and catch the best option.
Voicemeeter is one of the best audio mixer applications. It allows you to mix new audio from a device or application and get instant results. Consider it a virtual audio mixer or audio mixer device as a gamer or streamer. However, sometimes, you can’t get access to this app and want to discover some best voicemeeter alternatives that offer you quite the same functionality.
What is Voicemeeter?
Users can use Voicemeeter as a primary device to quickly mix and connect numerous audio. It’s an audio mixing console that effectively helps you manage audio sources. No matter what the device or application is, you can mix audio. You can get multi-channel recording and connect with a Microphone, Music, Movies, Skype calls, video game sound, net radio, and much more. Besides this, you can control all voicemeeter features with macro buttons. You can quickly mute a talker with the support of buttons.
Voice Meeter Robot Voice Changer
Key Features of Voicemeeter
Check out some key features of the voicemeeter mentioned below.
  1. Manage Audio Sources: It’s easy to manage audio sources on a PC or any other Windows. There’s no need to change any settings for a specific purpose.
  2.  Voice-Changing Effect: With Voicemeeter, you can use two headsets on Skype, Facebook, and other platforms to get instant voice-changing effects.
  3. Mix Different Audios: Mix numerous audios for a game or conversation and record performance efficiently.
  4. Virtual ASIO: Voicemeeter is a virtual multi-channel soundcard that offers pro audio that gives you an enhanced experience.
  5. High-Quality Podcasting: If you’re a podcast host, Voicemeeter is for you! Mix your microphone input with any background.
  6. Get a Wide Range of Sound Effects: You can quickly improve your speech using your favorite sound effects.
Take a look at the ten best voicemeeter alternatives below. We will share the best options with you so you can transform your voice for gaming, streaming, or podcasting.
Vozard – Best Voicemeeter Alternative
Vozard’s Official Website.
Vozard is a top-recommended alternative to voicemeeter because it allows you to access a powerful AI-powered voice filter. With Vozard’s 180 lifelike sound effects, you can enhance the overall journey of a game, chatting or live streaming. It allows users to enjoy it endlessly by offering voices like celebrities, singers, or other characters.
Key Features
Pros
Cons
Pricing
How to use Vozard? 6 Quick Steps
Using Vozard is easier than compared to other tools. All you need to do is follow the six quick steps mentioned below;
Step 1: Download and Install Vozard
First, you need to free download and install Vozard from the official site.
Main Interface of Vozard Official Website
Step 2: Create or Sign in to Account
Create a new account or sign in with Google or Discord.
Create an Account Or Sign in
Step 3: Choose Voice Changing Mode
You must choose a new real-time voice-changing mode to get a new voice.
Activate Real-Time Mode in Vozard
Step 4: Setup Microphone
You must set the microphone and speaker to change your voice into a new character or creature.
Setting up Microphone and Speaker Levels
Step 5: Select AI Voice Effect
Numerous AI voice-changing effects will be available; you can choose according to your preferences.
Select Your Desired Voice Effect
Step 6: Change Voice and Export File
Now, it’s time to change your voice by clicking the voice change option and getting instant results. After that, you can export files to any platform.
Click Export Voice Changing File
2. Audacity
Audacity is a 100% free-to-use tool that is an excellent alternative to Voicemeeter. It’s an open-source tool that allows you to get audio editing and record voice effectively. Users can edit and mix different kinds of audio. This tool is available for Windows, Linux, and other devices.
Audacity Mac Internal Sound Recorder
Key Features
Pros
Cons
Pricing: Free to use
3. Adobe Audition
Record Your Audio with Adobe Audition
With Adobe Audition, you can create, mix, and edit any type of audio. The easy-to-use display helps beginners get instant voice-changing effects without compromising on quality. This tool is available for Windows and macOS.
Key Features
Pros
Cons
Pricing: $22.99 per month
4. Audio Hijack
Voicemeeter Alternative - Audio Hijack
Voicemeeter Alternative – Audio Hijack
Audio Hijack allows you to record off sound cards and do real-time editing. It effectively supports VST plugins recorded applications from iTunes, Skype, Safari, and other popular apps. It also supports microphones and mixers.
Key Features
Pros
Cons
Pricing: It offers a one-time purchase license that costs around $59
5. Sound Desk
Voicemeeter Alternative - Sound Desk
Voicemeeter Alternative – Sound Desk
Sound Desk is a perfect option if you want to convert your MacOS into a professional mixing desk. It’s a virtual audio device that connects audio streams amazingly. With it, you can access numerous sound effects from any device.
Key Features
Pros
Cons
Pricing
6. Voice AI
Home Page Interface of Voice.ai
Voice AI is a 100% free tool that enhances your streaming journey with ready-to-use voice. Due to its wide range of features, it is one of the most popular tools. The tool is compatible with Android and Apple, so you can use it without worrying about compatibility.
Key Features
Pros
Cons
Pricing: It’s free to use
7. HitPaw
HitPaw Voice Changer operating interface
HitPaw is another famous alternative to Voicemeeter. It comes with AI technology to help you edit and alter your voice. A wide range of voice effects is available so that you can choose according to your preferences. It supports popular games while offering a voice editor feature. You can record voices without any distortion.
Key Features
Pros
Cons
Pricing: The subscription charges start from $15.95 per month
8. FineVoice
FineVoice Voice Changer
Get access to 200 plus voice effects by using FineVoice. With this outstanding tool, you can switch to any age or gender. Converting voice to any character or creature is an exceptional feature of this tool. Further, you can adjust the pitch according to your needs.
Key Features
Pros
Cons
Pricing: One time purchase is for $29.99 to $39.99
9. Pulse Audio
Voicemeeter Alternative - Pulse Audio
Voicemeeter Alternative – Pulse Audio
Suppose you’re searching for a fantastic Voicemeeter alternative that works as a proxy for any audio application. You can easily manage and edit sounds from your device and convert them into different file formats like MP3 and WAV. Not only this, but you can also mix audio clips to get good results.
Key Features
Pros
Cons
Pricing: 100% free to use
10. Murf
Murf.ai Voice Changer
Find it easy to explore more than 120 high-quality AI voices with Murf AI. It helps you get an accurate voice-changing effect in minutes. The best thing you will get is Murf AI, which allows you to write text for dubbing or translation.
Key Features
  1. High range of sound effects
  2. Emotional control feature
  3. Filler removal
  4. 120 high quality AI voices
Pros
Cons
Pricing
 FAQs on Voicemeeter Alternatives
What is the best Voicemeeter Alternative?
If you’re looking for the best alternative to Voicemeeter, Vozard is a highly recommended tool. It works the same way as Voicemeeter and offers impressive features even in its free version.
Is there any alternative to Voicemeeter that is free to use?
Yes, Audacity is 100% free to use the voicemeeter alternative. You can download and install this tool on any device and effectively access voice-changing effects and other features.
Is Voicemeeter free to use?
A big yes! Voicemeeter is a free and safe tool that can be downloaded and installed on any device. It allows you to edit, mix, and record voices.
Final Thought!
We have shared a detailed guide on Voicemeter Alternatives, features, pros, cons, and more. Voicemeeter allows you to mix any voice on any device and get instant results. Although Voicemeeter is free to use, other tools have fantastic functionality, but you must pay a fee. As a user, you can improve your experience by choosing a suitable alternative to Voicemeeter.
The fun and magic behind voice changing are undoubtedly excellent. However, selecting the right tool is essential. Enjoy editing sounds!
Joy Taylor
