Available for both Win & Mac
Find out the best free voice changer for PC designed for creators. With it, you can transform your audio without much effort.
You might have noticed that voice changers are quite the trend. Yet, when it comes to choosing the right one, the cost often becomes a major problem. Many users are trying to find a voice changer for PCs that’s not only effective but also free of charge. And that’s exactly what we’ve got here for you!
In this short article, we’ll show you how Vozard is gaining attention for providing a mix of user-friendly features and high-quality audio effects.
Whether you’re aiming to improve your gaming, create unique content, or simply have fun with friends, Vozard is always useful.
So, let’s get started right away.
Vozard is an excellent voice changer for Windows and Mac. It provides a free version for all users without complicating the process. Its voice effects will allow you to inject humor, personality, or dramatic flair into your voice projects.
Vozard’s Official Website.
Let’s see what Vozard offers for free!
Free Features of Vozard
Here are the key features of Vozard that are available for free.
While the free version of Vozard is packed with features, it’s important to note that certain limitations exist. However, for users seeking a basic yet effective voice changer, Vozard’s free version is a reliable option.
Let’s see how you can use it in daily life.
For gamers, YouTubers, and live streamers, finding the right voice changer for Windows/Mac is important. Because there are many situations where you can use them.
For example:
Gamers can use Vozard to modify their voice in real-time during gameplay. It will add an element of fun or strategic communication in multiplayer games. Moreover, gamers can create unique identities for their characters or maintain anonymity.
To support this, Vozard seamlessly integrates with all popular gaming platforms.
Vozard will improve your gaming experience
YouTubers can utilize Vozard’s sound effects to create distinct characters. They can also add narration with a twist and make their content more attractive. It will greatly encourage encouraging audience interaction and sharing.
With the ability to apply voice effects to pre-recorded audio, YouTubers can refine their content during the editing process.
Change your YouTube videos with voiceovers using Vozard
Live streamers can use Vozard to change their voice on the fly. It will add an element of surprise or humor to their streams. Moreover, streamers can respond to viewer interactions in creative ways and keep the content interactive.
Enjoy live sessions with a mix of different voices
In short, you can use Vozard in every digital presence.
So are you getting interested now? Let’s show you in a stepwise manner how to change your voice with Vozard.
Changing your voice with Vozard is anything but difficult. Here’s how you do it in Real-Time mode.
Step 1. Start by downloading & installing Vozard on your computer. Once installed, open Vozard and select your microphone and speaker device.
Vozard Settings Option
Step 2. Now, select the Real-time Mode. You’ll see a voice change area at the top and your free voice effects below.
Go to Vozard Real-time Voice Change Mode
Step 3. Test this effect in real time to hear how it alters your voice. You can also add a background voice if you want.
Step 4. Now click on the volume button. Adjust volumes for the microphone, speaker, and background sounds.
Step 5. Now that you’re set up play with different settings. Then click on the share button and connect Vozard with other popular platforms.
Hear the Voice Effect and Click Share Option
What? Are you now confused about how to connect Vozard with other platforms? Don’t worry! Let’s get rid of this confusion.
You can easily connect Vozard with all the popular platforms. Whether it’s a streaming platform or some popular game, there are options in Vozard.
Let’s take OBS as an example which is an open source free streaming tool. Follow these simple steps to connect Vozard with OBS.
Step 1. Make sure Vozard is installed and set up with your microphone and speaker configured. Select the voice change effect you wish to use.
Step 2. Launch OBS on your computer. Go to the top left corner and click on File. Now open Settings.
Open Settings in OBS
Step 3. Go to the audio settings. Now set the “Mic/Auxiliary Audio” to Vozard. This directs OBS to use Vozard as the audio input source.
Set Voard Microphone as Mic/Auxillary audio
With Vozard as your audio input, start streaming or recording in OBS. Your voice will now be broadcast with the chosen Vozard effect.
A good voice changer for PC can significantly improve your audio projects. Vozard, with its user-friendly interface and an array of features, stands as a shining example of such a tool.
From gamers to YouTubers and live streamers, Vozard can be used by anyone. It will add depth and originality to your content in just a matter of seconds. You can even connect Vozard to many popular platforms for real-time voice changing.
Free download Vozard voice changer software to change your voice into anyone you want to enhance online chatting, gaming, live streaming, and content creation experiences.
