  1. Part 1. Why is Voicemod Not Working on Discord?
  2. Part 2. How to Make Voicemod Work with Discord?
  3. Part 3. Discord Voice Changer Alternative: Vozard
  4. Final Words
  • 180+ lifelike VST and AI voice effects.
  • Compatible with 13 popular third-party platforms.
Available for both Win & Mac
Home Voice Changer How to Make Voicemod Work with Discord?
Discover solutions to common issues users face when using Voicemod in Discord, and learn how to troubleshoot effectively. Additionally, explore alternative voice changers for seamless integration with Discord. Let’s dive into this guide now!
Joy Taylor | Last Updated:Apr. 25, 2024
1821 words|6minute
I know! Voicemod is excellent for changing voice on Discord.
But only if it works normally!
Many users find themselves puzzled when their favorite voice changer doesn’t seem to work as expected with Discord. And that’s why we are here. To solve your problem once and for all!
In this article, we’ll show you the reasons behind this happening. We’ll also discuss how to make Voicemod work with Discord again with a step-by-step guide. That’s not all.
If you are fed up with Voicemod, then we’ll present a better alternative that works perfectly with Discord.
So why are we still waiting? Let’s start this article now!
Sometimes, despite your best efforts, Voicemod doesn’t seem to cooperate with Discord. This section aims to shed light on common reasons why Voicemod might not be functioning as expected on Discord.
Let’s explore some of the typical issues users encounter:
So, which one do you think is the cause in your case? No matter what it is, you can fix it with these solutions!
We have four different methods. So, if you are wondering how to make Voicemod work with Discord, then try out every single one. Before you finish, you’ll get Voicemod back on track.
Let’s start these methods by restarting the computer.
Method 1. Restart the Computer
Our first and simplest tactic is giving your computer a fresh start. A restart might seem basic, but it’s the unsung hero of troubleshooting.
This simple action can resolve a surprising number of technical issues. It clears your computer’s memory and halts ongoing processes that might be causing conflicts. Ultimately, it provides a fresh start for both Voicemod and Discord.
Here’s how you restart a computer.
Step 1. Save any important work and close all open applications so you won’t lose any unsaved data.
Step 2. Click on the “Start” menu. Locate and select the “Power” option. Then, choose “Restart” from the available options.
Restarting a Computer
Step 3. Wait for the computer to turn off and come back on. This may take a few minutes as the system shuts down and restarts all services.
Once the computer has restarted, open Discord and Voicemod. Check if the issue has been resolved and Voicemod is functioning as expected with Discord.
If not, then move on to the next method.
Method 2. Check Your Microphone
The next step involves ensuring your microphone is in harmony with Voicemod and Discord. The microphone serves as the bridge between your voice and the computer. So, properly checking it can be the key to solving our issue.
Here’s what you do:
Step 1. Make sure your microphone is properly plugged in or connected. If it’s a USB microphone, try different ports for a solid connection.
Step 2. Right-click on the sound/volume icon on your taskbar and select “Sound Settings.” Set your attached microphone as the default input device.
Setting the Microphone as the Input Device
Step 3. Check the microphone’s properties so that the levels are appropriately set. Also, see if the device is muted or not. Adjust the volume if necessary.
Step 4. Test the microphone in another application to ensure it’s working independently of Voicemod and Discord.
If it works elsewhere, the issue might be specific to the settings in Voicemod or Discord. So let’s check them as our method three.
Method 3. Check Discord Settings
Discord provides a lot of settings. So, a misstep here could be the silent culprit behind your issues. Fine-tuning Discord’s settings is important to make sure that our altered voice flows into your channels and chats.
Here’s how you set the settings for Discord.
Step 1. Open Discord & click on the “User Settings.” It’s a gear icon near your username at the bottom.
Step 2. In the settings menu, go to “Voice & Video” under the “App Settings” section.
Step 3. In the “Voice & Video” settings, select Voicemod as the input device. Then, select your speakers or headphones as the output device.
Setting Discord for Voicemod Usage
Step 4. Scroll down to the “Voice Processing” section. Now experiment with Noise Suppression, Echo Cancellation, and Automatic Gain Control. See if any of these settings improve the connection of Voicemod with Discord.
If your issue is still present, then here’s…
Method 4. Reinstall Discord and Voicemod
We sometimes find that the issue lies within Discord or Voicemod itself. So, reinstalling them can do the job in this case. It’s a bit like moving into a freshly cleaned home. Everything is set up anew, ready for a fresh start.
Here’s what you do to reinstall them.
Step 1. Uninstall Discord by opening Control Panel > Programs > Programs and Features. Find Discord in the list, right-click on it, and choose “Uninstall.”
Uninstalling Discord from the Computer
Step 2. Uninstall Voicemod by following the same steps as above. Go to where Voicemod is listed, right-click, and choose “Uninstall.”
Step 3. After both applications are uninstalled, restart your computer so all residual files are cleared.
Step 4. Visit the official websites of Discord and Voicemod to download the latest versions of these software. Install them on your computer, and set them up as you did initially.
Test to see if the issue has been resolved. At this point, most people have already resolved the issue. But still, we always try to give something extra for our readers.
Therefore, here’s an excellent alternative for voice changing on Discord.
Voicemod is not the only option you have if you want to change your voice on Discord. Many other apps can do the same job. One such app that’s considered excellent in every aspect is Vozard.
This tool is designed by iMobie to integrate flawlessly with platforms like Discord. You can easily install Vozard on other Windows and Mac computers.
Out of the vast collection of voice-changing options, there are both free and paid voice effects. What’s even more surprising is that you can even change the pitch of every sound effect you choose. Using this feature, you can create unique voices of your favorite cartoon characters, celebrities, and many other things.
Vozard Official Logo
Free Download   for all windows & 100% safe Free Download   for all mac & 100% safe
Key Features of Vozard
Here are the key features of Vozard that distinguish it from others.
Steps to Use Vozard to Change Voice on Discord
Here’s how you can use Vozard with Discord.
Step 1. Download and install Vozard on your computer. After installing Vozard, open the program and choose your microphone & speaker devices.
Set Your Microphone & Speaker Devices
Step 2. Choose “Real-time Mode” in Vozard. Go to the bottom of the Vozard interface and select your preferred voice effect. Then, download it and test the effect in real-time.
Choose a Character and Change Your Voice
Step 3. Click on the volume button & select the volume level of your audio. Then adjust the Pitch Shift, Throat Width, and Pitch Length as you like.
Set the Volume as You Like
Step 4. Now open Discord on your computer and click on the Settings icon. It’s located at the bottom left corner mostly.
Click on the Settings Icon
Step 5. On the left side, go to the Voice & Video settings. Now select Vozard Microphone as the input device and set your output device as you like.
Setting Vozard Microphone as the Input Device
Step 6. Now scroll down until you find the Noise Suppression options. Select None for this feature.
Adjusting Noise Suppression
For Mac users who want to use Vozard in Discord, here is also the tutorial for using Vozard for you to check.
Final Words
How to make Voicemod work with Discord can seem difficult at first. But, with the steps outlined in this guide, you’re well-equipped to tackle this issue.
From checking your microphone to changing Discord’s settings, we’ve explained four different methods. Each method aims to ensure a smooth, fun, and engaging voice-changing experience.
If Voicemod still doesn’t meet your needs, Vozard stands ready as an excellent alternative. It provides an array of voice effects and user-friendly features for your Discord chats.
Vozard -AI-Powered Voice Changer
Free download Vozard voice changer software to change your voice into anyone you want to enhance online chatting, gaming, live streaming, and content creation experiences.
Joy Taylor
