How to Get a Ghostface Voice Changer
  • 170+ lifelike VST and AI voice effects.
  • High-quality voice change with no lag.
  • Compatible with 13 popular third-party platforms.
Available for both Win & Mac
Home Voice Changer How to Get a Ghostface Voice Changer
Discover how to use a Ghostface voice changer with our guide. Learn to use Vozard, VoiceMod, LingoJam, and a mobile app for spooky, fun voice transformations!
Joy Taylor | Last Updated: Jan. 29, 2024
1625 words|5minute
For fans of heart-pounding horror flicks, Ghostface from the Scream series needs no introduction. This scary person is famous for his frightening actions and for using a device that changes his voice. This clever tool disguises the user’s voice, making it a mystery. But fear not! These Ghostface voice changers aren’t just for the villains in movies.
They’ve found a fun place in our everyday lives, too! Think about making your gaming sessions more exciting or scaring your friends during voice chats on Discord or Zoom. These voice changers add surprise and excitement to games that allow their use. Get ready to learn how you can turn your voice into something eerily entertaining!
How to Create a Ghostface Voice on PC
Want to sound like Ghostface from the Scream series? It’s easy with voice changer software! These tools can change your voice to sound just like the spooky movie character. You have two options for changing your voice: desktop programs or online voice changers.
Both types allow you to change your voice and have fun. Our guide will show you how to use these tools step by step, so let’s get started!
Method 1. Changer Voice to Ghostface with Vozard
Vozard is an AI-powered voice changer that provides a rich voice effect library. You can find classic horror voice effects such as Ghostface,  Freddy Krueger, Jigsaw, and Vecna from Stranger Things, etc.
Vozard is a perfect choice for online chatting, gaming, or content creation. Because it supports all kinds of voice changing. For example, with a microphone, you can change your voice with Vozard in real-time. Once select a voice effect, what you say is what you get. You can also record or upload an audio file and then change the voice to the character you like.
Vozard Product Page
Vozard Product Page
Download Vozard now and follow the steps here to see how to get Ghostface’s voice.
play.svg play.svg
Change Voice
Step 1. Download and install Vozard on your computer.
Step 2. After installing Vozard on your computer, click the Settings button to set the Microphone and Speaker.
Vozard Settings Option
Step 3. Go to the Real-time Mode tab, you will see the voice change area. With this mode, you can hear the voice-changing result in real-time.
Go to Vozard Real-time Voice Change Mode
Step 4. Choose the Ghostface voice effect in the library below. You can preview the voices before using them.
Vozard Change Voice in Real-time
Step 5. After deciding which one to choose, make sure to toggle on the Change Voice button, speak what you want to say, and you can hear your voice change in real-time.
*You can also customize the voice effect by adjusting the parameters.
Method 2. Create Ghostface Voice with VoiceMod
VoiceMod is a cool Ghostface voice changer. The software makes changing your voice fun and easy. If you want to sound unique, like Ghostface from Scream, this is perfect for you. With VoiceMod, you can make your voice sound scary, funny, or anything in between.
It works with games, chats, and even video calls. The best part is that it’s super easy to use. Just pick a voice, and you’re ready to go! VoiceMod is a great choice for playing games, talking with friends, or having fun.
Step-by-Step Guide to Using VoiceMod on PC
The following steps will help you to use the VoiceMod app easily on your PC.
Step 1. Download and install VoiceMod on your computer.
Download VoiceMod Software
Step 2. As the installation process completes, click the finish button.
Finish VoiceMod Installation
Step 3. Choose the Voicebox menu option to access different voice filters. Now click on any icon to activate the Ghostface voice filter.
Go to VoiceMod Voicebox
Step 4. Turn on the Hear Myself and the Voice Changer toggle at the bottom of the window. Also, you can use the Background Effects toggle to turn ambient effects on or off.
Turn on hear myself and voice changer toggle
Step 5. Choose Microphone as your Input device and Headphone as your Output device.
Set up VoiceMod Microphone
Step 6. Now choose Ghostface voice effect and change your voice.
Method 3. Generate Ghostface Voice with Online Voice Changer
LingoJam is a user-friendly online Ghostface voice changer. It is great for voice-changing. It’s free and works directly in your web browser. So, there is no need to download anything. You can use LingoJam to record or upload your voice and add different effects. This includes the Ghostface voice from the Scream series. The platform is simple. You talk or upload your audio. Then, you pick the effect.
After that, it does everything else. Plus, you can instantly play back your transformed voice to hear the results. Once you’re happy with the new sound, LingoJam lets you download the file or share it online. It’s perfect for quick voice changes without any hassle.
How to Use LingoJam- An Online Ghostface Voice Changer
Follow the below steps to create a Ghostface scary sound using LingoJam.
Step 1. Open a web browser, then go to the LingoJam Scary Voice Changer website.
LingoJam - Scary Voice Changer
LingoJam – Scary Voice Changer
Step 2. Choose to either record your voice directly or upload an audio file.
Choose to Record or Load a Clip
Step 3. Play back the transformed audio to hear your new scary voice.
Play Back the Transformed Audio
Step 4. If satisfied, download the new audio file or share it from the site.
Download the New Audio
Now that you know how to use LingoJam – the scream voice changer. You can make awesome Ghostface sounds now. It’s time to move to the next part of our discussion.
Change Ghostface Voice with Mobile Voice Changer App
Voice Changer with Effects is a cool Ghostface voice changer for your phone. You can use it to change your voice into different sounds, like the creepy Ghostface voice. It’s really easy to use. With this app, you can make fun voices for jokes or to surprise your friends. You can even save these cool voices and share them. If you love making different voices, this app is perfect for you.
How to Use Voice Changer with Effects On Phone?
Follow these easy steps to change your voice into a Ghostface voice.
Step 1. Download the “Voice Changer with Effects” app on your phone.
Download Voice Changer with Effects
Step 2. Open the app. Then, record your voice using the app.
Record Your Voice Using the App
Step 3. Choose the Ghostface effect from the list.
View the List to Choose the Effect
Step 4. Listen to your voice with the effect. Then, save or share your new scary voice.
Save or Share Your Scary Voice
This Ghostface voice changer is mobile-friendly. On top of that, you can easily use the following above steps. Let’s move to the next part of our discussion.
Who is The Ghostface Voice Actor?
Roger Jackson is the voice of Ghostface in the Scream movie series. He’s the one who makes Ghostface sound so scary. Roger Jackson didn’t show his face in the movies, but his voice is very famous. He would call the actors on set to make it feel real.
Ghostface and Roger Jackson
His spooky voice is a big part of why Ghostface is such a memorable character. Jackson’s voice acting added a lot to the scary and suspenseful parts of the Scream movies. He is famous for this role. People praise his work for making Ghostface scary and iconic.
We’ve reached the end of our guide to making a Ghostface voice. You’ve learned about cool tools like Vozard, VoiceMod, LingoJam, and the voice changer app. These can turn your voice into a Ghostface from the movies. It’s great for fun with friends, in games, or just for a laugh.
Vozard -AI-Powered Voice Changer
Free download Vozard voice changer software to change your voice into anyone you want to enhance online chatting, gaming, live streaming, and content creation experiences.
Joy Taylor
