Imagine you’re capturing a memorable moment on your Android phone – a family event, a scenic landscape, or an adventurous hike – but later, you realize the video is shaky. Want to learn how to stabilize video on Android? This guide shows simple steps to stabilize videos, including Google Photos and AI tools such as AnyEnhancer. We recommend AnyEnhancer – a reliable video enhancer – for clearer, steadier, and high-quality videos.
Ever recorded a video on your Android, only to find it shaky and hard to watch? Don’t worry; fixing it is easy! Whether capturing a special moment or making content, smooth videos are key to clear things. Android offers built-in tools to help and some great apps that simplify stabilizing videos. One top option is AnyEnhancer – it’s efficient and uses a smart AI video stabilizer to make your videos look steady, clear, and professional. This guide will show you how to use Google Photos, AnyEnhancer, and other tools to stabilize your videos quickly. Let’s explore how to stabilize video on Android and make your videos look their best!
Using Google Photos to stabilize video on Android is an easy, built-in method that delivers smooth results. Its stabilization feature effectively reduces shakiness, making videos look more polished. Key features include preserving original video quality during stabilization, a quick editing process directly within the app, and comparing stabilized and original versions before saving.
This user-friendly approach allows Android users to enhance video quality effortlessly without needing external apps. The simplicity and accessibility make Google Photos an ideal choice for anyone looking to improve video clarity on Android. Here’s how to stabilize video in Android using Google Photos:
Step 1. Download and set up Google Photos on your mobile device. Then, locate the video you wish to stabilize by opening the app and selecting “Library” at the bottom.
Step 2. Tap the video to start it. From the options at the bottom of the screen, select “Edit” after it begins to play.
Select Edit
Step 3. Verify that you are in the “Video” section before selecting “Stabilize” in the lower-left corner. Google Photos will begin the stabilization process.
Tap Stabilize
Step 4. Allow the app a few moments to process and stabilize your video.
Step 5. Once you’ve finished, tap “Save copy” at the bottom right to keep a new, stabilized version without changing the original.
Tap Save Copy
Looking to stabilize videos on Android using AI? AnyEnhancer is an excellent choice that provides advanced tools for enhancing video quality. The Frame Interpolation model is especially useful for stabilizing Android videos, as it increases the frame rate, resulting in smoother motion and improved clarity. Enhancing the frame rate by 2X or 4X makes your videos look more professional and polished, whether using Mac or PC.
AnyEnhancer also includes various models to enhance your videos further. Resolution Enhancement improves the quality and clarity of your videos, creating vibrant and colorful effects with options for 2K and 4K settings. The Face Restoration Model recognizes and enhances faces in blurry videos, ensuring clear facial details. Furthermore, the Denoise Model lowers noise for improved visual clarity, while the Colorize Model adds color to black-and-white recordings.
Key Features
Now, let’s have a detailed look at the simple steps to use AnyEnhancer for video stabilization:
Step 1. Free download and install AnyEnhancer on your computer.
Step 2. Upload the video from your Android phone to your computer > Launch the application and click “Upload Video,” or drag and drop your video file into the window.
Upload the Original Video
Step 3. Choose “Frame Interpolation” to initiate the stabilization process for your video.
Frame Interpolation Model
Step 4. Click “Preview” to compare the enhanced video and the original.
Preview Frame Interpolation Effect
Step 5. If you’re happy with the preview, click “Export.” Enter the desired file name and format, select a save location, and click “Export” once more to complete the process.
Export the Video
How can shaky videos be avoided the best?
Try recording with a tripod or stabilizer to avoid wobbly videos. Keep your elbows close to your torso, and use both hands to grip your device. By following these pointers, you can start with more smooth footage.
Can I stabilize videos after recording?
Yes, you can stabilize videos after recording. You can improve shaky films and apply stabilization effects using various programs like Google Photos and AnyEnhancer. In this manner, you can improve your video even after it has been recorded.
Does using video stabilization techniques require specialized knowledge?
No, using video stabilization tools doesn’t require any specialized knowledge. Most apps are easy to use, taking you step-by-step through the procedure. Even beginners can stabilize their videos easily with tools like AnyEnhancer.
Is it possible to stabilize slow-motion videos?
On Android, slow-motion videos can indeed be stabilized. Some apps even include stabilizing tools designed specifically for slow-motion videos to minimize blurriness and maintain the fluid, slowed-down image. Your slow-motion videos will appear sharper and more polished as a result.
Stabilizing your Android videos can significantly improve the quality of content, making them smoother and more entertaining. The correct stabilization method can have a big impact, regardless of whether you utilize specialized programs or built-in methods like Google Photos. For those looking to enhance their videos further, AnyEnhancer is an excellent option. This tool offers features like resolution enhancement, frame interpolation, and face restoration, ensuring your videos stabilize and shine with improved clarity and detail. If you want to take your video quality to the next level, we highly recommend trying AnyEnhancer for a professional touch to your footage!
Download AnyEnhancer to enhance your video quality to 4K resolution, remove grain, smooth motion, and add color to black and white videos with just one click.
