Home Video Enhancer How to Stabilize Video in iMovie [3 Methods]
This guide explains three simple methods for how to stabilize video in iMovie. You’ll learn to fix shaky footage on Mac and iOS devices with step-by-step instructions. Additionally, we introduce AnyEnhancer, an AI-powered tool that stabilizes videos and effectively reduces motion blur.
Joy Taylor | Last Updated: Sep. 24, 2024
1284 words|4minute
If you are working on videos that include blurry or shaky footage, iMovie can assist in correcting that within no time. This tutorial on stabilizing video in iMovie will make your videos look smoother and more professional. You can easily customize videos using iMovie with built-in stabilization that helps smooth out unwanted motion. We will also present an AI tool, AnyEnhancer, that can improve videos by eliminating motion blur and polishing them. Whether you are a beginner or an expert in the industry, this guide for how to stabilize video in iMovie will help you get through it quickly and easily!
How to Stabilize Shaky Videos in iMovie on Mac
iMovie provides features to improve shaky videos, and one of them is called video stabilization. Another useful option is Adjust, which allows you to make the necessary small adjustments to stabilize your footage in the best way.
Stabilization can be applied to your video, and you can see the result in real time without saving the video using the Preview option. These features make iMovie the best for enhancing video quality in personal or professional projects. All in all, removing shakiness from videos to make them stable in iMovie on Mac is easy and simple. Below are the detailed steps about how iMovie stabilizes video in minutes on Mac:
Step 1. Add your video to the timeline and make sure it’s selected. This ensures iMovie knows which clip to apply the stabilization to.
Step 2. Look above the preview window and click the “Stabilization” icon.
Stabilize Shaky Video Option
Click the Stabilization Option
Step 3. Check the box for “Stabilize Shaky Video.” iMovie will then process and stabilize the clip.
Select the Stabilize Shaky Video Checkbox
Step 4. Use the slider next to the checkbox to adjust the amount of stabilization. Move it left or right to increase or decrease stabilization.
Step 5. Click “Play” to preview the changes and see how the stabilization looks.
How to Stabilize Shaky Videos in iMovie on iOS
Adjusting shaky videos in iOS iMovie is very convenient, as many tools are integrated into the program. The iMovie stabilization tool comes as an added bonus and will lower the amount of shake that your videos will have. You can also use the Preview button to view your video before it is actually saved and the level of stabilization can also be set with the help of Slider.
These features are intended to assist you in enhancing video quality straight from your iPhone or iPad. To make it easier for you, below is a step-by-step guide for using these features of iMovie on iOS to help you fix your shaky video:
Step 1. Open iMovie on your iPhone or iPad and start a new project. Import your video file.
Start a New Project in iMovie on iPhone
Step 2. Tap on the clip in the timeline, then select the “Gear” icon to access the settings.
Step 3. Choose “Clip Adjustments” and enable the “Smooth Clip Motion” option. The app will automatically analyze and stabilize your video.
Step 4. If you add more clips, they will be analyzed and stabilized automatically. To apply stabilization to new clips, repeat the process by selecting “Analyze for Stabilization” from the “File” menu.
Step 5. iMovie uses advanced motion tracking to reduce camera shake without needing on-screen trackers.
Best iMovie Alternative to Stabilize Video with AI – AnyEnhancer
Looking for a powerful alternative to iMovie for stabilizing videos with advanced technology? AnyEnhancer offers a sophisticated solution using cutting-edge AI models. One of these features is the Frame Interpolation model, which enhances the frame rate of the video and, in turn, enhances the motion and quality of the video. Enhancing the smoothness of motion is one of its primary focuses, making this model ideal for stabilizing the footage.
Besides the frame interpolation, AnyEnhancer offers a couple of other remarkable models. The Face Restoration model enhances blurry faces by detecting and fine-tuning the face area. The Colorize Model colors the black-and-white videos, and the Color Enhancement model also makes dark videos brighter with a higher saturation. The Denoise Model helps filter out unnecessary noise for better image quality, and the Resolution Enhancement model boosts videos up to 2K and 4K for improved brightness, contrast, and sharpness.
Key Features:
Now, let’s explore the simple steps to use AnyEnhancer for video stabilization:
Step 1. Free download and install AnyEnhancer on your computer.
Step 2. Open the tool and click “Upload Video” or drag your file into the program.
Upload the Original Video
Step 3. Select “Frame Interpolation” to start stabilizing your video. The frame interpolation model will boost the FPS by 2X or 4X and smoothen the transitions between the scenes to stabilize the shakiness.
Frame Interpolation Model
Step 4. Click “Preview” to compare the improved video with the original.
Preview Frame Interpolation Effect
Step 5. If you’re happy with the preview, click “Export.” Choose a file name and format, select where to save it, and click “Export” again to finalize your video.
Choose the Preview Duration
Export the Video
FAQs on How to Stabilize Video in iMovie
Why is my video still shaky after applying stabilization in iMovie?
If your video remains shaky, try adjusting the stabilization slider to increase the effect. For more advanced stabilization, consider using additional tools like AnyEnhancer, which offers enhanced stabilization through advanced AI models.
How long does it take to make a video stable in iMovie?
Typically, the stabilization process in iMovie will vary depending on the length of the video and its general difficulty. Sometimes, it may take a few minutes as the software processes and optimizes the video you have made.
Can iMovie stabilize any video footage?
iMovie can stabilize most video footage, but the effectiveness may vary based on the extent of the shake. Tools like AnyEnhancer can provide more advanced solutions for more challenging stabilization needs.
Final Words
In conclusion, video stabilization is a vital feature that helps improve video quality, and iMovie has rudimentary stabilization options for Mac and iOS. By following the above steps, one can achieve a better flow of the camera work and make it look more professional. However, AnyEnhancer provides powerful AI-driven solutions for more advanced stabilization and enhancement. With features like Frame Interpolation and Face Restoration, AnyEnhancer can take your video quality to the next level, offering smoother motion and clearer details. If you’re looking for a robust alternative to iMovie to achieve superior video stability, try AnyEnhancer.
AnyEnhancer – AI Video Enhancement
Download AnyEnhancer to enhance your video quality to 4K resolution, remove grain, smooth motion, and add color to black and white videos with just one click.
Joy Taylor
