Home Video Enhancer How to Fix Shaky Video: Mastering Video Stability
How to fix shaky video clips by yourself? Uncover the secrets to rectifying shaky video clips using a suite of potent techniques. Master the stabilization process and achieve seamless, polished outcomes for your visual content.
Joy Taylor | Last Updated: Jul. 29, 2024
1572 words|5minute
We’ve all been in the position where a fantastic moment is captured, but the video seems shaky. This can be not very reassuring, especially if the video is essential. Both new users and videographers frequently ask how to fix shaky videos.
Fortunately, there are several approaches to stabilizing your video. Hardware or software solutions can help you create smooth and professional videos.
Let’s examine the top techniques for stabilizing shaky video and enhancing its quality. Then, let’s explore the causes of camera shaking and how to address them.
What Causes Camera Shaking?
A camera shake might spoil a flawless video. The first step in solving the issue is figuring out its causes. Some factors can cause shaky footage.
The most frequent violator is handheld shooting. Even the steadiest hands can introduce unwanted movement. Mechanical vibrations, such as those from equipment or machines, can influence your video.
Another problem is the rolling shutter effect, particularly with digital cameras.
Types of Camera Shake:
Factors Contributing to Shaky Videos:
  1. Not using gimbals, tripods, or other stabilizing equipment can result in shaky videos. These tools help keep the camera steady.
  2. Poor handling techniques, like gripping the camera too tightly or moving too quickly, can cause shakes.
  3. Wind, uneven terrain, and other environmental factors can contribute to shaky videos. Shooting in unstable conditions makes it harder to keep the camera steady.
As you learn the types and factors of shaky videos, explore the fixing techniques!
AnyEnhancer – AI Video Enhancement
Download AnyEnhancer to enhance your video quality to 4K resolution, remove grain, smooth motion, and add color to black and white videos with just one click.
How to Fix Shaky Video in Post-Production
Techniques used during post-production may greatly enhance shaky video. Video quality can be improved using iMovie and Adobe Premiere Pro. It could lessen shakes.
Using these tools, you can achieve professional-grade results. It requires deep technical expertise. Their robust features and user-friendly interfaces make video stabilization simple.
Next, let’s look at how to stabilize shaky video in Adobe Premiere Pro.
Stabilizing Shaky Video in Adobe Premiere Pro
One of the best programs for editing videos is Adobe Premiere Pro. Professionals use it because of its powerful features. Excellent tools are available in Premiere Pro to stabilize shaky video.
User Interface of Adobe Premiere Pro
Premiere Pro’s user-friendly interface makes editing and stabilizing videos simple. It provides refined editing features and supports several formats. Filmmakers and videographers love it.
Read below to explore how to stabilize shaky video using Adobe Premiere Pro.
Step-by-Step Guide
Step 1. Import Your Video
Open Adobe Premiere Pro and create a new project. Import the shaky video you want to stabilize.
Step 2. Add Video to Timeline
Drag the video to the timeline. Select the clip to activate it for editing.
Add the File to the Timeline
Step 3. Apply Warp Stabilizer
Go to the “Effects” panel and search “Warp Stabilizer.” Then, drag the effect onto your video clip.
Warp Stabilizer Effect
Step 4. Adjust Settings
Adjust the stabilization settings in the “Effect Controls” panel as needed. You can change the smoothness, method, and other parameters.
Adjusting the Settings
Step 5. Analyze and Render
Premiere Pro will analyze the footage and apply stabilization. Once complete, render the video to view the stabilized footage.
Stabilizing Shaky Video in AnyEnhancer
AnyEnhancer is a versatile tool designed to enhance video quality using advanced AI technology. It’s perfect for anyone looking to improve their videos effortlessly. With features like resolution enhancement, denoising, and colorization, AnyEnhancer is a powerful tool.
The Best AI Video Enhancer - AnyEnhancer
The Best AI Video Enhancer – AnyEnhancer
One of its standout features is the Frame Interpolation AI model. This feature helps explicitly stabilize shaky videos, making them smooth and professional-looking.
Let’s explore why AnyEnhancer is an excellent choice for video stabilization.
AI Enhancement:
AnyEnhancer’s AI technology upscales video to 2K or 4K resolution, delivering enhanced clarity and improved overall video quality.
Video Denoising:
The denoising feature effectively diminishes graininess, resulting in a cleaner and more transparent video appearance.
Colorize Black-and-white Video:
AnyEnhancer breathes new life into monochrome footage by adding vibrant colors, turning black-and-white videos into visually rich experiences.
Video Frame Interpolation:
By smoothing out the motion between frames, AnyEnhancer’s interpolation technology effectively stabilizes shaky videos, providing a more professional and fluid viewing experience.
Now, let’s move on to the step-by-step guide on stabilizing shaky videos using AnyEnhancer.
Steps to Stabilize Video in AnyEnhancer
Step 1. Install and Launch AnyEnhancer
Free download and install the AnyEnhancer on your PC from the official website.
AnyEnhancer Webpage Interface
Step 2. Import Your Video
Import the shaky video you want to stabilize by clicking the “Upload Video” button.
Upload Your Video to AnyEnhancer
Step 3. Apply Frame Interpolation
Use the Frame Interpolation AI model to stabilize your video. Adjust the settings as needed for optimal results.
Frame Interpolation effect
Step 4. Preview and Export
Preview the stabilized video to ensure it meets your expectations. Once you are satisfied, click the “Export” button to save the video.
Export the Video
Export the Video
Using AnyEnhancer, you can quickly transform shaky footage into smooth, professional-quality videos with just a few clicks.
Stabilizing Shaky Video in iMovie
iMovie is a well-liked video editing application for Mac users. It is easy to use and ideal for intermediate video editing. iMovie has powerful stabilization tools to fix shaky videos.
The software is suitable for beginners and regular users. It offers simple-to-use features and an appealing user interface.
User Interface of iMovie
Let’s see how you can stabilize your videos using iMovie.
Step-by-Step Guide
Open iMovie and create a new project. Import the shaky video clip you want to stabilize.
Start a New Project in iMovie
Drag the video clip to the timeline. Click on the clip to activate it for editing.
Step 3. Apply Stabilization
Click on the “Stabilize Shaky Video” option in the toolbar. It is above the preview window. iMovie will analyze the clip and apply stabilization.
Stabilize Shaky Video Option
Stabilize the Shaky Video Option
Select the Stabilize Shaky Video checkbox. Then, use the slider to adjust the stabilization amount. Preview the changes in the video window.
Select the Stabilize Shaky Video Checkbox
Step 5. Export Your Video
Once satisfied, click the “Share” button and export your stabilized video.
FAQs on Stabilizing a Shaky Video
Q: What is the best software to fix shaky video?
Adobe Premiere Pro and iMovie are excellent options. Both offer powerful stabilization features to smooth out shaky footage.
Q: Can I stabilize the video on my phone?
Yes, apps like iMovie for iOS and Android offer stabilization features. You can fix shaky videos directly on your phone.
Q: Is it possible to stabilize videos for free?
Free software like DaVinci Resolve and Lightworks offers video stabilization. These tools provide robust features without costing anything.
Q: How does stabilization software work?
Stabilization software analyzes the video to detect shakes and movements. It then adjusts the frames to smooth out the footage.
Q: Will stabilizing a video reduce its quality?
Stabilizing a video can sometimes crop the edges slightly. However, reducing the shake usually enhances the overall quality.
Q: Are there hardware solutions for stabilizing videos?
Using tripods, gimbals, and stabilizing rigs can prevent shaky footage. These tools help keep the camera steady during shooting.
Final Words
Fixing shaky footage can improve your video. You can generate smooth, high-quality clips from shaky movies using the tools. Stabilizing your films is easy, even if you use AnyEnhancer.
Keep the most critical moments intact by not letting the camera shake. You can always create faultless videos if you know what causes shaky footage. Remember that using these tools will give better results since practice makes perfect.
Continue experimenting with various configurations and approaches. Discover what best suits your requirements and style. You’ll make polished, expert-looking films, capturing viewers with each shot.
Joy Taylor
