Home Video Enhancer How to Remaster Videos: Remaster Old Videos With AI
This article focuses on AnyEnhancer, an AI-powered utility for upgrading videos to 2K/4K quality without any difficulties. It also presents five other video remastering tools for bringing old footage up to the contemporary level of video processing. Explore how to remaster videos in detail!
Joy Taylor | Last Updated: Sep. 19, 2024
1917 words|6minute
Remastering videos is a process that involves upgrading home movies, classics, and old business videos into clear, high-definition videos. Certain tools are available that give your videos a new look by increasing the color contrast, sharpness, and resolution, even bringing them up to 2K and 4K. Here, you will learn how to use AI for step-by-step video remastering with the help of the AnyEnhancer tool. We will also reveal other effective tools that can assist you in enhancing your videos within a few simple steps.
So, let’s begin to explore how to remaster videos!
Why Remaster Videos?
Remastering old videos can bring them back to life with improved quality and a modern look. It’s a great way to refresh content that may have lost its visual appeal over time. Here are some key reasons to consider remastering:
How to Remaster Videos in 2K/4K [Best Way]
What makes AnyEnhancer stand out in video remastering? It employs artificial intelligence algorithms to improve the quality of old videos and give an impression of newly produced videos. The Resolution Enhancement Model enables hitting the 2K or 4K mark, thus making videos sharper and clearer. In blurry videos, the Face Restoration Model can recognize and sharpen different parts of faces, making the people in your videos look clear. Moreover, the Intelligent Enhancement model can improve the resolution to 4K and even restore the facial details in one go.
Among its key models is the Colorize Model, which infuses black and white videos with colors to make them look contemporary. Besides, other enhancement models in AnyEnhancer provide more AI developments to improve video output. Another helpful AI model is Color Enhancement, which enhances brightness and contrast in low-quality videos and makes them look bright and fresh.
Key Features:
Here are some simple, easy steps to use AnyEnhancer to remaster your videos:
Step 1. Free download and install AnyEnhancer on your computer.
Step 2. Launch the program and click “Upload Video,” or drag your video file into the window to upload it.
Upload the Original Video
Step 3. Choose the “Resolution Enhancement Model” to remaster your videos. This model helps improve the resolution to 2K or 4K and enhances the overall quality of the footage.
Select Resolution Enhancement
Step 4. Click “Preview” to compare the original and enhanced versions side-by-side versions.
Compare the Video Upscaled to 4K
Step 5. Once satisfied with the improvements, click “Export” to save the enhanced video. Adjust your settings, then click “Export” again to finalize.
Export the Video
Export the Video
Other 5 Tools to Digitally Remaster a Video
Now, let’s discuss some other tools to remaster a video digitally. These tools are very helpful to anyone with a video that needs enhancement, whether you’re a pro or a raw beginner.
VEGAS Pro
Wondering how to remaster a video into HD? VEGAS Pro is leading this transformation with its advanced AI features that elevate your video editing experience. With AI-enhanced Z-Depth Compositing, you can easily add depth to your visuals without complex manual work. Smart Mask is an additional option that allows you to perform masking operations automatically. It lets you remaster videos and adjust the Output Rotation, Frame Rate, Pixel Format, and more.
Text to Speech and Speech Text make voiceovers and subtitles in minutes so people can easily consume your content. Besides, the Colorization AI Effect creates fresh black & white videos, improving your clips’ looks with AI-powered style Transfer and enriching video quality with AI-driven upscale.
Video Color Changer - Vegas Pro
Video Color Changer – Vegas Pro
Key Features:
Pros:
Cons:
Pricing:
AVCLabs
AI Video Clearer - AVCLabs
Remaster Video via AVCLabs
You may improve your video editing with cutting-edge technology using AI tools from AVCLabs. It comprises the Video Upscaler, which is perfect for 4K and 8K resolution, and the Video Quality Enhancer, which raises the standard video quality to HD. Video Enhancement improves image quality and reduces distortion, while Video Blur AI allows blurring of face, background, and license plate. Based on them, AI-driven solutions ensure professional-level results with less input and make video remastering more manageable.
Key Features:
Pros:
Cons:
Pricing:
Adobe Premiere Pro
User Interface of Adobe Premiere Pro
Video editing is getting easier with the help of the integrated Adobe Premiere Pro AI features, which have made complicated work simple. Adobe Premiere Pro lets you create a new sequence with the desired resolution and FPS, where you can upscale video to UHD and even 4K. With futuristic generative AI tools, you can quickly compile clips, replace objects, remove objects, etc. Generative Extend will let you effortlessly add frames and adjust clip lengths for perfect transitions. Object Addition and Object Removal use AI to modify your footage by easily inserting or removing elements.
Key Features:
Pros:
Cons:
Pricing:
Aiseesoft Video Enhancer
Aiseesoft Video Enhancer is one of the finest tools for upscaling your videos in a few clicks. This tool is an AI-based program that provides features such as Video Upscaling, which can increase the video quality to 4K or 1080p. Its Color Correction feature can improve brightness and colors, and Frame Interpolation introduces smoothness by adding frames. With these AI-based features, all the complicated processes for enhancing the looks of the video have been made easy and achievable by even a nonprofessional Aiseesoft Video Enhancer.
Key Features:
Pros:
Cons:
Pricing:
Filmora
Edit YouTube Recordings on Filmora
The major features of Filmora employ Artificial Intelligence to enhance your videos and make them look better and more professional. Color Correction Presets allow you to get the look of a cinema in your videos within a few seconds. The White Balance tool will help you change temperature and tint to make your video colors true to life.
For those who want vivid and saturated colors, 3D LUT presets provide choices made from popular TV shows and films. In the Color settings, some options can adjust brightness, contrast, vividness, and color saturation, making even the most boring videos interesting.
Key Features:
Pros:
Cons:
Pricing:
FAQs on How to Remaster a Video
What tools can I use for video remastering?
You can use AI-powered tools such as AnyEnhancer for effective remastering and upscaling videos to 2K or 4K.
How much time does it take to remaster a video?
The time varies depending on the video length and tool used, but modern software speeds up the process.
Can I remaster videos to 4K resolution?
Yes, using tools like Aiseesoft Video Enhancer or Filmora, you can upscale videos to 4K. We recommend using AnyEnhancer with its pre-defined Resolution Enhancement AI model for upscaling.
Final Words
In conclusion, remastering videos improves quality and sharpness and can increase color saturation. Enhancements like resolution upscaling, color correction, and noise removal make it possible to convert old, poor-quality videos into HD counterparts. For a seamless and efficient enhancement experience, consider using AnyEnhancer. Its powerful AI-driven features offer an excellent way to elevate your video quality effortlessly.
AnyEnhancer – AI Video Enhancement
Download AnyEnhancer to enhance your video quality to 4K resolution, remove grain, smooth motion, and add color to black and white videos with just one click.
Joy Taylor
