Poor video quality can ruin your overall TikTok audience reach and engagement. Worry not! Keep your views entertained and earn new followers by posting high-quality videos. But how to increase TikTok video quality? Learn 5 ways to improve your TikTok video quality and a reliable AI video upscaling tool, i.e., AnyEnhancer, to boost resolution to 4K.
One of your responsibilities as a content creator is to amuse your audience across various platforms. But what if the videos you publish aren’t up to par, and you’re losing viewers and interaction? You’ll experience worry since all of your hard work will be in vain. The TikTok platform may compress your movies, the portrait mode may destroy the pixels, or your camera may be defective, resulting in poor recording quality.
Whatever the reason, we have got a solution for you! Wondering how to increase TikTok video quality? Several ways exist, including turning off the data saver mode and using the web browser to upload TikTok videos. Moreover, we have also recommended utilizing an AI upscaling tool, AnyEnhancer, to improve TikTok video quality. Let’s unfold some ways to post high-quality, engaging videos on TikTok and earn a great audience!
As a TikTok content creator, you must understand the video quality requirements or needs while posting videos on this platform. Ensure to follow the recommendations below to make your videos stand out. From resolution and frame rate to format, we have compiled everything you need to keep in mind before shooting or posting videos on TikTok. Let’s delve into the details:
Another critical quality element is the FPS of a TikTok video. TikTok supports 30 to 60 frame rates per second for videos. However, the greater the FPS, the better the video quality.
TikTok supports various formats, offering comparability to various audiences. You can post videos in MP4, MOV, and HEVC (H.265).
It speaks to the volume of data sent throughout a video frame. However, “the higher the bitrate, the better the quality” holds true. TikTok suggests a bitrate of 1-2 MBPS for MP4 files and 2-4 MBPS for HEVC files.
Resolution is an essential element that affects the overall quality of the TikTok video. The lowest recommended resolution for an immersive experience, which TikTok can easily accommodate, is 1080 pixels high and 1920 pixels wide, with an aspect ratio of 9:16.
Want to upgrade your TikTok videos and gain more followers by uploading high-quality content? No worries! A dependable AI video enhancer like AnyEnhancer may boost resolution and remove visual noise. This AI upscaling application uses cutting-edge artificial intelligence models to improve smoothness and convert low-resolution films into engaging material. In addition to boosting clarity, the Frame Interpolation AI model can increase FPS by 2X or 4X.
Advanced AI algorithms can upsurge the resolution of your TikTok movies from 360p or 480p to 4K while maintaining quality. Additionally, AnyEnhancer presets users with its Denoise AI model to eliminate the visual grain and compression artifacts. You can restore the details and convert your TikTok videos into captivating visuals.
Key Features
Here’s a step-by-step guide to improving TikTok video quality via the AnyEnhancer AI tool:
Step 1. On your computer, download and install AnyEnhancer. To add TikTok videos to the tool, launch it, click the “Upload Video” button, or drag and drop the videos.
Upload the Original Video
Step 2. AnyEnhancer offers four different AI models to improve video quality. To enhance the TikTok video quality and make it clearer, choose “Intelligent Enhancement” and select 2K or 4K. It can not only improve the overall video resolution but also enhance facial details at the same time.
Choose the Intelligent Enhancement
Step 3. Apart from boosting resolution, optimize the frame rate of your TikTok videos to add an element of smoothness. Click on “Frame Interpolation” and select 2X or 4X.
Frame Interpolation Model
Step 4. Press the “Preview” button to begin the procedure. The preview timer can be adjusted to run for three or five seconds.
Preview Changes
Step 5. After that’s finished, click the “Export” button to save the improved TikTok video.
Aside from employing AI techniques, there are additional methods to increase TikTok video quality. No matter if your TikTok videos are of poor quality due to low-resolution cameras, inadequate settings, portrait mode destroying pixels, or compression, you can improve the overall picture by following this straightforward technique.
Let’s go through 5 tips for improving TikTok video quality:
Another option to improve video quality is to post TikTok videos via a web browser. Web browser allows you to post videos without any compression to preserve the overall quality. To post TikTok videos via web browser, follow the steps below:
Step 1. Open TikTok’s official website on your PC. Sign in to your account with the credentials.
Step 2. Click the “Upload” button and choose a video you want to post.
Click on Upload
Step 3. Enter the caption and click “Post” to share the high-quality TikTok video.
TikTok has a data saver mode to cut down on resources and save some money on internet bills. It has the potential to degrade the quality of TikTok material you consume as well as videos you record and share. Another trick for improving TikTok video quality is to disable the data saving option.
To turn off data saver mode in TikTok, follow the steps below:
Step 1. Launch the TikTok app on your device and navigate to the profile. Once opened, click on the menu and the “Settings and Privacy“.
Step 2. Scroll down and find the “Data Saver” option. Tap on it and toggle to turn it OFF.
Turn Off Data Saver
Want to improve TikTok video quality? By capturing in 1080p, you can steer clear of low-quality footage. A camera with at least 1080p resolution is required to capture excellent TikTok videos. Once done, choose a good lighting setup and keep the camera stable. Record in portrait mode to guarantee the movies fit well according to the requirements, i.e., 9:16 aspect ratio.
TikTok offers a way to post HD content by enabling the high-quality uploads. Never heard of this. No worries! Ensure that the videos you are uploading are high definition and that the uploading parameters are set to high definition. However, you’ll need to enable the option while uploading.
The steps below can be used to upload HD videos:
Step 1. Launch the TikTok application and click the “+” button to upload your videos.
Step 2. Record your TikTok video or select it from the gallery. Once done, tap on “Next.”
Step 3. Tap on “More Option” and then toggle to turn on “Upload HD.” You might find the “Allow High-Quality Uploads” option in some countries. Tap on “Post” to upload the high-quality video.
You can switch to a Wi-Fi network rather than cellular data, as Wi-Fi is usually faster. Higher-speed internet ensures that the video data is transmitted smoothly and quality remains preserved.
What are TikTok’s quality limits?
You can upload videos in 1080p resolution with a 9:16 aspect ratio in MP4, MOV, and HEVC format. Android’s maximum video file size is 72 MB, and iOS’s is 287 MB.
How to improve TikTok video quality?
You may boost the quality of your TikTok videos in a variety of ways, like activating HD uploading, disabling data saver mode, uploading material using a web browser, or using Wi-Fi instead of cellular data. AI solutions like AnyEnhancer can help you boost TikTok quality by scaling it up to 4K resolution.
Are you a content creator trying to entertain your audience or create TikTok videos as a leisure? Regardless of how you want to utilize your TikTok videos, their quality will influence their reach and engagement. Would you like your TikTok videos to be of higher quality? To boost the quality of your TikTok movies, you may use a web browser, disable data saving mode, enable high-quality uploads, and other options. AI video enhancer applications such as AnyEnhancer may raise the resolution to 4K and FPS by 2X or 4X.
Download AnyEnhancer to enhance your video quality to 4K resolution, remove grain, smooth motion, and add color to black and white videos with just one click.
