Home Video Enhancer How to Correct Lens Distortion – 3 Ways
This article will discuss appropriate software for managing videos shot with a distorted lens. Correct basic things such as fisheye or wide-angle lens distortion to make your videos appear more professional. Enhancing the quality of videos only takes a few minutes; this can be done manually or with a video editor. We suggest using AnyEnhancer, the best AI video enhancer, and upscaler, to correct lens distortion easily.
Joy Taylor | Last Updated: Sep. 25, 2024
1407 words|5minute
Distortion is a familiar problem in videos, mainly when using wide-angle or fisheye lenses. It can make straight lines look curved, which may destroy the video’s appearance. Thankfully, post-processing lens distortion doesn’t always have to be such a dreadful experience if one knows the right methods.
For anyone, be it a first-time or an experienced user of video editing software, it is helpful to know how this problem can be solved to improve your footage. This guide will teach you how to eliminate lens distortion and make your videos as if a professional films them. Additionally, we will suggest a reliable tool such as AnyEnhancer, an AI video enhancer, for the quickest and least troublesome fixes to correct lens distortion.
What is Lens Distortion?
Distortion is a lens flaw that makes straight lines appear curved and warps the footage that a camera records. This is usually a common issue with wide-angle, fisheye, and cheap lenses since they tend to distort some objects so much that they look squished.
There are mostly two kinds: Straight lines bow in two different directions: first, they bow outward with the barrel distortion, and second, they bow inward with the pincushion distortion. While it’s not always bad, it typically makes a picture or video seem less real. You can get more accurate photos or films by using post-processing tools or programs in photography or videography to fix lens distortion.
How to Correct Lens Distortion (2 Ways)
Distortion of lenses makes your videos appear distorted, especially when using wide-angle or fisheye lenses. Fortunately, this issue can be corrected with apps like Adobe Premiere Pro and the Filmora Video Editor.
Way 1. Correct Lens Distortion in Video via Premiere Pro
Fixing lens distortion in your footage with Adobe Premiere Pro is straightforward using the internal “Lens Distortion” effect. Follow these steps:
Step 1. Launch Premiere Pro and import your video, then pick the clip on the timeline.
Import Your Noisy Video
Import Your Video
Step 2. Navigate to “Effects” > “Video Effects” > “Distort” > “Lens Distortion Removal.”
Step 3. Apply the “Lens Distortion” effect to your clip by dragging it onto the clip.
Step 4. Tweak the effect settings in the “Effect Controls” panel:
Step 5. If necessary, keyframe the properties for animated adjustments.
Step 6. Process the effect by either exporting your project or carrying on with your editing process.
Way 2. Correct Lens Distortion in Video via Filmora
Filmora provides users with basic options to correct distortion and enhance the video footage. Regardless of how experienced you are in editing, Filmora is the best tool for fixing the lens problems because its interface is very friendly, and it takes less time to correct this issue and enhance the quality of the videos without much strain. Here’s a step-by-step guide to correct lens distortion:
Step 1. Open Filmora and click on “New Project.” Import the video file in which you want to correct lens distortion.
Import Media
Import Media
Step 2. Click on your video clip and go to the lens correction settings. You’ll find the settings in the right pane in the AI Tools section. Toggle to turn on “Lens Correction”. Choose the camera model you used.
Lens Correction
Lens Correction
Step 3. Move the slider left to correct distortion. Sliding it to the right does not apply correction while sliding it to the left straightens lines.
Step 4. Play your video to see the improvements. The video should now look clearer and more natural. Once done, click on “Export” to download the corrected video.
Filmora lens correction tools are helpful but unsuitable for complicated distortions and high-resolution adjustments. As suggested, AnyEnhancer can make finer corrections and enhance video quality. It brings AI models for accurate lens correction and complex video improvement for Mac and PC.
Pro Tip. How to Improve Video Quality and Correct Lens Distortion on Mac & PC
How does AnyEnhancer help with video quality and lens distortion? This powerful AI video enhancer tool is designed to enhance video visuals and efficiently correct lens distortion. Its advanced models, like the Resolution Enhancement Model, improve video clarity by offering 2K and 4K settings. This model helps fix lens distortion issues, making your videos look sharper and more professional.
In addition to lens correction, AnyEnhancer provides other useful features. The Face Restoration Model can recognize and enhance blurry faces, while the Colorize Model adds color to black-and-white videos. Color Enhancement boosts the brightness and saturation of low-quality videos, and the Denoise Model reduces visual noise for a cleaner look.
Key Features
Now, let’s explore the simple steps to improve video quality and correct lens distortion on Mac & PC:
Step 1. Download AnyEnhancer from the official site and install it on your computer. It would help if you had a strong internet connection throughout the process.
Step 2. Open AnyEnhancer and click “Upload Video,” or drag and drop your 1080p video file into the program to import it.
Upload the Original Video
Step 3. Choose “Resolution Enhancement” to upgrade your video to 2K or 4K quality, then select the AI model for upscaling.
Select Resolution Enhancement
Step 4. Click “Preview” to compare the enhanced video with the original version. You can view a 3 or 5-second preview to check the changes.
Preview the Resoltion Enhancing Effect
Step 5. If you’re satisfied with the preview, click “Export.” Choose your file name, set the frame rate, select the format, and pick a save location. Click “Export” again to finalize and save the enhanced video.
Export the Video
Export the Video
FAQs on Correct Lens Distortion
How do I know if my lens distortion needs correction?
If your photos or videos are filled with lines that seem curved, stretched objects, or unusual shapes, you could be dealing with lens distortion. Addressing and eliminating these problems enhances the aesthetic and accuracy of the visuals.
Can one eliminate the lens distortions?
Although it is difficult to negate lens distortion, it is possible to reduce it with lenses and settings that are less distortion-prone. If any such distortion is obtained, post-processing tools can assist in correcting it.
Is it possible to eliminate lens distortion in videos?
Indeed, some lenses create distortions in videos, which can be corrected using the right video editing tool. Tools like AnyEnhancer can detect distortion and other problems and customize videos to improve them.
Which software can I use to correct the lenses?
You can use different photo and video editing tools to correct lens distortion. Anyone who needs a simple and efficient tool to sharpen video and correct distortion should try AnyEnhancer.
Final Words
Distortion is a lens imperfection that alters photos and videos as straight lines appear curved. This is usually found in wide-angle and fish eye lenses, although there are ways that it could be rectified through modification. By applying lens correction features in software, you can restore clarity and improve the overall look of your visuals. For an efficient and straightforward solution to enhance video quality and fix lens distortion, we recommend using AnyEnhancer. Its advanced AI models make it easy to achieve professional results with minimal effort.
AnyEnhancer – AI Video Enhancement
Download AnyEnhancer to enhance your video quality to 4K resolution, remove grain, smooth motion, and add color to black and white videos with just one click.
Joy Taylor
