Wondering how to convert video to 60fps? Look no further! We have reviewed professional tools to optimize the frame rate and smoothen the videos. Utilize AnyEnhancer’s Frame Interpolation AI model to enhance the FPS by 2X or 4X with a few clicks. You can also use the Adobe Premiere Pro and online VEED.io FPS converter.
Consider viewing an action film or a basketball game while feeling blurriness owing to the fast-paced activity and motion. This hazy and grainy look might impair the whole experience, preventing you from enjoying the action in the swift motions. Moreover, in another example, you may have neglected to capture the videos at a higher frame rate, and the only option now is to boost the FPS in post-production editing.
Whatever the reason, you can always convert your 24fps to 30fps films to 60fps with a video frame rate converter to enhance frame transitions and experience fast-paced action more seamlessly. This detailed guide will explain the concept of frame rate and why converting to 60fps would be a better idea for content. Moreover, we’ll review ways to convert videos to 60 FPS. Let’s explore how to convert video to 60fps!
Frame rate (FPS)— as evident from the name— is the number of frames that change or appear on the screen in a single second. It can be defined as the rate of change of frames per second. FPS can notably impact the motion and smoothness of a video.
You might be wondering what frame rate suits digital content creation. The answer varies for each domain or profession. Let’s look at each frame rate setting and how it can complement the type of video or profession you’re in!
Frame Rate Explained
The human eye sees a video played on the screen, but that’s not a video! That’s the combination of multiple still images appearing on the screen so fast that the human eye sees it as a video. This is where the concept of frame rate comes in! The frequency at which the still images or frames appear in a video is known as the Frame Rate.
Motion blur occurs when an item moves too quickly in low-frame-rate video footage. To avoid this effect, you’ll have to either record the video at a higher FPS or increase the frame rate per second through post-production editing.
Benefits of 60 FPS Video
Recording videos at 24fps and 30fps can cause video lag or motion blur, mainly if the footage contains fast-paced actions. It is recommended that videos be recorded at 60 FPS or converted to higher FPS in post-production editing with the help of tools. Here’s why you need to convert your videos to 60fps:
Here are three methods to convert videos to 60 FPS:
How a video is delivered on the screen significantly impacts the overall watching experience. Increasing the frame rate adds value to footage by increasing the number of still images and frames within a given second. There are various tools and techniques to enhance the footage’s frame rate, and we recommend using the AnyEnhancer. AnyEnhancer is an AI video enhancer tool that boosts a video’s resolution and transforms low-quality visuals into industry-grade cinematic footage.
AnyEnhancer Webpage Interface
AnyEnhancer has a brilliant Frame Interpolation AI model that can optimize the frame rate of a video by 2X or 4X to add an element of smoothness. The mature AI algorithm will automatically scan and analyze the footage and ensure ideal transitions. Moreover, this AI model reduces shakiness and shuttering during frame transitioning.
The Resolution Enhancement model can also upscale the video resolution to 4K. You can also revive the facial details using Face Restoration. AnyEnhancer has an intelligent AI model that combines the effects of resolution enhancement and face restoration AI.
Key Features
Here’s how to convert video to 60fps using AnyEnhancer:
Step 1. Free download and launch AnyEnhancer and click the “Upload Video” button to import the low fps video to this AI video enhancer tool.
Upload the Original Video
Step 2. Click on the “Frame Interpolation” AI model to enhance and optimize the frame rate. You can set the interpolation model settings at 2X or 4X to smoothen transitions and improve video sequences.
Frame Interpolation Model
Step 3. Select the duration between 3 to 5 seconds and then press the “Preview” button for the tool to start processing your video file.
Preview and Export
Step 4. The software will give you a preview of the more fluid and smoother version of your video. Click on the “Export” button to save the smoothened video. You can adjust the name, frame rate, format, and save location settings.
Adobe Premiere Pro is a versatile editing tool that serves users with various advanced editing functionalities. This tool lets you craft the whole story using blending effects, industry-standard effects, and three-point editing. Moreover, the tool offers to refine, reorder, and even trim the clips with a single click. You can stabilize video and reduce the noise of video with Premiere Pro, Adobe Premiere Pro is considered a professional’s choice when it comes to manipulating the resolution, frame rate, bitrate, and encoding.
Here’s how to adjust and optimize the frame rate of a video via Adobe Premiere Pro:
Step 1. Import video to Adobe Premiere Pro after launching it on your PC. Right-click and create a “New Project.” Then, click “Import” to upload the low fps video footage.
Import the Video Clip
Step 2. Drag and drop the footage in the timeline. Right-click on the clip and then “Modify > Interpret Footage”.
Click Interpret Footage
Step 3. In the dialogue box, locate the frame rate section. Check the “Assume this frame rate” and enter 60 FPS.
Assume this Frame Rate
Step 4. Click “OK” to apply the changes and export the video with these new frame rate settings.
To avoid blank screens and shuttering in the film, utilize the web application VEED.io to optimize video settings and modify the frame rate. Enable flawless frame-to-frame transitions and export the video in whatever format you like, such as MP4, H.264, MPEG, and others. With only a few clicks, VEED.io converts your videos to 16, 24, 30, and 60 frames per second. Wondering how to convert video to 60fps? Follow the steps below to optimize the frame rate by VEED.io:
Step 1. Visit the official VEED.io Frame Rate converted website. Click on the “Adjust Video Frame Rate” button.
Step 2. Click “Settings” and adjust the Frame-per-second rate to 60fps. Click “Done” to export the video.
Change FPS
Can you convert video to 60fps?
Yes! You can utilize various editing tools to optimize the frame rate. We recommend using AnyEnhancer, which offers a Frame Interpolation AI model to scan, analyze, and enhance the FPS by 2X or 4X with a single click.
Why do you need to change the video’s FPS?
Changing the FPS of a video will remove the motion blur and laggy effect from the footage. It smoothens the transition between the frames, especially in fast-paced videos.
Converting videos to 60fps will remove the shuttering and motion blur effects. You can enjoy fast-paced action movies, game videos, and football matches without lags and blurry feel. Various editing tools are available to enhance the frame rate per second of a video. You can utilize the industry-grade Adobe Premiere Pro or VEED.io online FPS converter. However, we recommend using AnyEnhancer, which offers a Frame Interpolation AI model to optimize FPS by 2X or 4X for ultra-smooth transitions.
Download AnyEnhancer to enhance your video quality to 4K resolution, remove grain, smooth motion, and add color to black and white videos with just one click.
