This guide outlines the 10 best anime upscaler in 2024 for enhancing video quality and resolution for anime fans. These upscalers will improve the detail and sharpness of your favorite shows with the help of advanced technology. We recommend using AnyEnhancer to boost the resolution, remove the grains, and smoothen the frame transitions using the AI models.
For anime enthusiasts, watching their preferred series in the best possible visual quality is crucial. Sometimes, you simply get a low-quality video or an old video that might not fit the screen as well, especially if the anime is old or the video quality is low. That’s where anime upscalers come in! The AI upscaling tools employ artificial intelligence to make the animation appear in higher quality and far clearer so that it can be watched in high definition. Let’s have a look at some of the top choices in anime enhancers!
Feature | AnyEnhancer | Topaz Video AI | AVCLabs Video Enhancer |
Compatible Platforms | Windows & macOS | Windows & macOS | Windows & macOS |
Maximum Video Resolution | Up to 4K | Up to 8K | Up to 4K |
Output Formats | MP4, MKV, AVI, MOV | MP4, AVI, MOV, MKV | 8 kinds of |
Video Editing | Basic editing tools | Basic editing tools | Basic editing tools |
GPU Acceleration | ![]() |
Now, let’s discuss the 10 best anime upscalers in 2024:
What makes AnyEnhancer one of the best anime upscaler in 2024? It uses advanced AI models specifically designed to enhance anime videos to 4K. One of its key models, Resolution Enhancement, is perfect for improving the quality of low-resolution anime. This model boosts video clarity, making colors more vibrant and details more noticeable, offering 2K and 4K model settings.
In addition to resolution enhancement, AnyEnhancer comes with other AI models. The Face Restoration model locates faces in low-quality anime videos and refines blurred facial features due to the pixilation issue. There is also the Colorize Model, which paints the black-and-white videos, and the color enhancement model, which enhances the pale anime videos based on brightness and saturation. Plus, the Denoise Model can reduce noise, resulting in a clearer video.
Choose the Color Enhancement Model
Key Features:
Pros:
Cons:
Pricing:
Adobe Premiere Pro is primarily used for video editing, but it is an excellent program for increasing the resolution of anime. Thanks to enhanced color correction, enhancements, and numerous plugins, it will bring low-quality anime videos to a new level. It provides advanced settings for specifying video characteristics with high accuracy, making adjustments to color tone and edges, and increasing the resolution of anime videos with a few clicks.
User Interface of Adobe Premiere Pro
Key Features:
Pros:
Cons:
Pricing:
AVCLabs Video Enhancer is an efficient tool for upscale anime and enhancing video quality. It helps improve anime videos by increasing the level of detail and resolution and making the videos brighter and more contrasted. It recognizes the most well-known video formats, including MP4 and AVI, and can enhance multiple videos at a time, which is beneficial when scaling larger number of anime videos. With batch processing and efficient presets, it’s perfect for improving anime visuals quickly and effectively.
Key Features:
Pros:
Cons:
Pricing:
HitPaw Video Enhancer is one of the best tools for making anime upscaling easy and fast. With integrated AI technology, it increases the brightness, clarity, and contrast of low-quality anime videos in a snap. Whatever problem you may have with your anime, from blurriness to a seeming lack of brightness, HitPaw will cover it.
The Best Online Video Shanper – Hitpaw
Key Features:
Pros:
Cons:
Pricing: From $42.99 to $349.99
Topaz Video AI is an exceptional tool meant to improve anime videos with lots of precision. It employs artificial intelligence algorithms to enhance standard as well as 4K anime sequences to 8K definitions for sharper and improved video quality. This tool effectively eliminates motion blur, improving the visual quality. Because Topaz Video AI can handle several videos simultaneously, it is perfect for animes, especially many of them, or a series.
Topaz Video Enhance AI Website
Key Features:
Pros:
Cons:
Pricing:
Cutout.Pro is an advanced AI-driven tool designed to enhance anime videos with ease. Its Video Enhancer & Upscaler can boost resolution up to 4K, making your anime sharper and more colorful. The tool also features precise background removal, which helps maintain small details like hair while improving overall video quality. Ideal for both personal and professional use, Cutout. Pro combines powerful AI technology with user-friendly features to elevate your anime viewing experience.
Cutout Pro Website Overview
Key Features:
Pros:
Cons:
Pricing:
Filmora is a powerful video editing tool designed to elevate your anime videos easily. It offers robust features like Auto Reframe, which adjusts aspect ratios for different screens, and AI Smart Cutout, which ensures clean and precise graphics. Filmora’s AI Audio Stretch keeps your sound smooth while the Audio Visualizer synchronizes music dynamically with your video. Its intuitive interface and advanced tools make it a great choice for enhancing and upscaling your anime content.
Import Media
Key Features:
Pros:
Cons:
Pricing:
Movavi Video Editor is perfect for anime lovers who want to enrich their videos smoothly. It can make your videos colorful with Pro-Quality Color Correction, keep them perfect with AI Motion Tracking, and remove backgrounds with AI Background Removal, all advantageous for anime scenes. With these features, Movavi makes upscaling and perfecting your anime videos easily without needing extensive editing skills.
Movavi Interface
Key Features:
Pros:
Cons:
Pricing:
Pinnacle Studio is enhanced video editing software for enriching your anime videos effortlessly. It comes with additional tools such as Multicam Editing, which enables you to work with numerous cameras and combine them effortlessly, and Split Screen Video, which allows you to show several videos simultaneously. Plus, Stop-Motion Animation helps create captivating and dynamic anime scenes. Pinnacle Studio provides a comprehensive suite of tools to upscale and refine your anime content effortlessly.
Pinnacle Studio Interface
Key Features:
Pros:
Cons:
Pricing:
Camtasia is a powerful tool designed to precisely enhance and edit your anime videos. With features like Flexible Layout Changes and One-Click Effects Adjustments, you can easily upscale and refine your anime content. AI-Powered Script Generation helps streamline editing by providing accurate transcriptions and video-like text adjustments. The High-Resolution Screen Recording captures detailed animations and scenes, ensuring clarity and quality in your final product. Camtasia offers a range of tools to perfect your anime videos efficiently.
Camtasia Interface
Key Features:
Pros:
Cons:
Pricing:
Why do anime videos need upscaling?
If the anime looks blurry or pixelated on your screen, it may benefit from upscaling.
Is upscaling anime a complex process?
Upscaling is straightforward with the right tools and does not require advanced technical skills.
Which tool do you recommend for upscaling anime?
We suggest using AnyEnhancer for its advanced AI features that provide high-quality upscaling and detail enhancement.
To sum up, anime upscaling can help diversify your viewing habits as it improves the visual quality of definition and sharpness. There are many different tools, so finding the right one for your situation should be simple. For top-notch results and user-friendly features, consider trying AnyEnhancer. It offers advanced upscaling options and improved video quality that can make your anime look vibrant and sharp. We recommend using AnyEnhancer to get the best out of your videos.
Download AnyEnhancer to enhance your video quality to 4K resolution, remove grain, smooth motion, and add color to black and white videos with just one click.
