This article explores the 10 best 4K video converter options for PC and online in 2024. It covers top tools to help users convert and enhance videos to 4K. The list features five PC software solutions and five online converters, focusing on usability, performance, and quality, making video conversion simple and efficient.
Whether you are a filmmaker or a YouTuber, employing a 4K video converter is essential if you want your films to look good and stand out. We have thus put together a list of the top 4K video converters for usage on computers and the internet. We provide 10 options in all. These converters can help with any format conversion of movies; they range from sophisticated and quick PC software to free web resources. Now, let’s begin our exploration of them!
A 4K video converter is software that converts videos from one format to another at 4K resolution. These converters can upscale videos from 480p or 720p to 4K. These converters can also compress or convert 4K movies, making them compatible with a variety of devices for sharing, editing, and watching. When working on a computer or an internet tool, the 4K video converter helps to keep the movie’s quality while also modifying its size or format if necessary.
Now, let’s discuss the top 10 4K Video Converter in 2024:
Here are some of the best options for a 4K Video Converter for PC:
Wondering how to use the best 4K video converter to transform films into higher-quality formats? AnyEnhancer uses advanced models, such as the Resolution Enhancement model, to make your movies look better—more vibrant, sharp, and colorful. You are covered regardless of the video input format thanks to this model’s 2K and 4K modes.
It also features the Colorize model, which colors black-and-white videos, and the Color Enhancement model, which enhances colors in videos with poorer color quality, thus making the videos brighter and more alive. AnyEnhancer also has other great models, such as Face Restoration, which identifies faces in blurred videos and sharpens them. These tools make AnyEnhancer one of the best 4K video converters, especially for those looking to enhance both resolution and visual details.
Key Features:
Pros:
Cons: The web version is now unavailable.
Pricing:
AVCLabs can be effective in enhancing the quality of videos from 480p to as high as 4K and even 8K. Integrating sophisticated artificial intelligence algorithms brightens the videos and removes any blur and graininess, making them sharper and cleaner. It has an AI Colourization Tool that can convert movies into amazing monochrome structures with life and colors. All in all, at AVCLabs, people get access to numerous settings that help to adjust the video enhancement according to specific requirements.
Key Features:
Pros:
Cons:
Pricing:
Adobe Premiere Pro is one of the most popular software for video editing and conversion, and it has heightened support for 4K videos. Advanced Upscaling uses lower-resolution data and turns it into a full high-definition definition to give a clear result. The software also contains Color Correction tools to improve brightness intensity and overall quality of hues in videos. Additionally, noise reduction features help remove unwanted noise, improving overall clarity.
Key Features:
Pros:
Cons:
Pricing:
Camtasia Studio is a universal video editing program that cannot only upscale videos to 4K but convert them into multiple formats. It also allows you to enhance the quality of the recorded videos and gives them a rather professional look when recorded in 4K. The software also has High-Resolution Export, which makes it possible to export the videos in high resolution, clear, and detailed. Real-time editing allows the user to view the edited output without leaving the room, as the video is perfect.
Key Features:
Pros:
Cons:
Pricing:
Alt: Wondershare UniConverter For consistent conversion of 480p videos to 1080p and 4K professionally, Wondershare UniConverter is a tool that is helpful for both the professional and the new user. This software comes in two versions: Free and Pro versions. The primary focus of Wondershare UniConverter is the Super-Resolution technology, which enables videos to be converted into high-quality visualization. The Free edition provides essential conversion tools but has limitations on quality and file size. In contrast, the Pro edition unlocks advanced features like the Edit Function for professional video editing.
Key Features:
Pros:
Cons:
Pricing:
Download AnyEnhancer to enhance your video quality to 4K resolution, remove grain, smooth motion, and add color to black and white videos with just one click.
Now, let’s have a look at the best 4K video converter online free:
Online Converter is the best 4k video converter online free that converts videos from 480p to 4k without downloading additional software. Thanks to the Fast Mode and Super-Resolution Algorithm, the video can quickly switch from low quality to 4K but remains quality. The User-Friendly Interface makes the conversion process as easy as possible, even for first-time users.
Key Features:
Pros:
Cons:
Pricing:
AnyMP4 is a versatile and effective video converter that helps you increase the video resolution from 480p to 4K or even 5K. This tool applies Deep AI Learning Technology to improve the quality of videos with one tap. Other enhancement functions of resolution and quality include Auto-AI-Upscaling. Additionally, Eliminating Video Noise smooths out imperfections for a cleaner look. With support for over 300 formats, AnyMP4 is an excellent choice for influencers and content creators who need flexibility and quality.
Key Features:
Pros:
Cons:
Pricing: Free
HDconvert is a powerful online tool designed to convert videos to 4K resolution quickly and effortlessly. This tool offers No Software Installation, as you can convert videos directly from your browser. It supports different formats such as MP4, AVI, MOV, etc., which provides versatility for handling various types of videos. With no size limits for conversion, the tool supports fast conversion speeds as much as 60 times above average. With a global network of data centers, HDconvert provides users with low latency and high-speed performance worldwide.
Key Features:
Pros:
Cons:
Pricing: Free; Premium: 5.99$
Users can quickly and simply convert videos into 4K resolution by using Notta Online Video Converter. Up to three files, each no more than 500 MB, may be uploaded at once and converted right in your browser without any further fees or advertisements. It is also a flexible option for 4K video conversion because it offers High-Quality Output and lets you choose the desired video resolution.
Key Features:
Pros:
Cons:
Pricing:
With the help of this straightforward tool, you may rapidly convert films without requiring any other software. Simple navigation allows you to drag and drop files into the system or upload files from your PC. To prevent pixelation or fuzzy movies, it guarantees 4K output of the highest quality. High-quality 4K output maintains sharpness and detail in your converted videos.
Key Features:
Pros:
Cons:
Pricing:
What formats can I convert to with a 4K video converter?
Most 4K video converters support popular formats like MP4, AVI, MOV, and MKV.
Are there any size limits for 4K video conversion?
Some converters have size limits; check the tool’s specifications for details.
Which tool do you recommend for 4K video conversion?
For a reliable and user-friendly experience, try AnyEnhancer to convert videos to 4K.
In summary, 4K video converters offer a simple way to boost video quality, supporting various formats and high resolutions. Whether you need to enhance video clarity or convert files to 4K, these tools streamline the process efficiently. Try AnyEnhancer, which offers advanced features like automatic resolution enhancement and seamless format conversion for the best results.
