Home Video Editing Top 10 TikTok Video Editor for PC & Mobile 2024
TikTok is one of the leading social media apps that has taken the world by storm over the past few years. And if you’re a content creator looking to thrive on this platform, you need to create videos that stand out. But how do you go about this? Well, this is where the need for a powerful TikTok video editor becomes important.
Joy Taylor | Last Updated: Mar. 14, 2024
1823 words|6minute
Although TikTok offers its built-in video editing tools, you need the best video editor for TikTok to make your videos look more attractive to viewers. So, in today’s post, we shall introduce you to some of the best video editors for TikTok that you can use to create high-quality videos for your viewers.
You May Also Like: Best Vlog Editing Software 2024
1. Movavi Video Editor – Most Popular for TikTok
Movavi Video Converter
Movavi Video Editor is a widely recognized video editing software that offers a user-friendly interface and a wide range of features. This tool allows TikTok content creators to take their videos to the next level by using efficient features like fast video cutting, filters, transitions, titles, etc.
What’s more, Movavi Video Editor offers smart AI tools for background removal, motion tracking, and noise removal. And you don’t necessarily need to be tech-savvy to utilize these tools. All it takes is only a few clicks.
Key Features
Pros
Cons
Compatibility: Mac and Windows
2. YouCam Video Editor
YouCam is a versatile video editor for Android and iPhone that offers a wide range of features and effects to enhance your TikTok videos. From filters to stickers, special effects, and lots more, this TikTok video editing app got you covered with efficient features that you can utilize to make your videos look more stunning.
With YouCam Video Editor app, you get access to beautification tools a library of trendy effects, hair makeup and filters, etc. that you can use to spice up your video regardless of the type of content you create.
Key Features
Pros
Cons
Compatibility: Android/iPhone
3. Inshot
InShot Video Editor
InShot Video Editor
Inshot is one of the most efficient video editing apps that is designed for social media platforms. It offers simple, yet effective features that both beginners and experienced users can utilize to edit TikTok videos with high quality.
Whether you’re looking to trim, cut, and merge videos, add music and text, apply filters and effects, or more, Inshot will provide you with the relevant tools to be able to get the job done without requiring technical knowledge. It also offers a range of stylish fonts and emojis to enhance your TikTok videos, and it is supported on both Android and iOS devices.
Key Features
Pros
Cons
4. YouCut
Are you looking for a TikTok video editor with basic editing tools for video content creation? YouCut got you covered. This app enables you to trim, cut, and merge videos easily. Plus, it supports filters and effects that you can use to improve the overall feel of your video without requiring any video editing skill.
YouCut also allows you to create transition videos using unique transition effects.
Key Features
Pros
Cons
Compatibility: Mac/Windows
5. Magisto
If you need an AI-powered video editor for TikTok videos, Magisto is the go to app for you. This tool supports features that allow auto-editing of videos to make them look more professional. All you just need is to upload your videos and let the app do the rest.
Once you upload your video to Magisto video editor, it analyzes your footage, selects the best moments, adds effects, and lots more to create a polished final result. It also enables you to adjust the video output using various customization options.
Key Features
Pros
Cons
Compatibility: Android, iPhone, Online
6. Picsart
Picsart is a versatile photo and video editing app that offers cool features for editing TikTok videos. You can use this app to add effects, filters, AI-powered enhancements, and even create collages and stickers for your videos.
Also, Picsart provides a range of tools for drawing and adding text to your videos, allowing you to add a creative touch to your TikTok content. And in terms of simplicity, it has a simple user interface that makes navigation easy for all users.
Key Features
Pros
Cons
7. PowerDirector 365
PowerDirector 365 is an advanced video editing software developed by Cyberlink. This tool allows you to carry out various video editing tasks like the creation of transition videos, adjustment of video speed, cutting, trimming, and lots more.
PowerDirector 365 also allows you to edit your TikTok video at a fast speed. And it offers advanced features like audio restoration, motion tracking, and background removal.
Key Features
Pros
Cons
8. Vivid Cut
Vivid Cut
Vivid Cut
Next on our list is Vivid Cut. This is another reliable TikTok video editor that can satisfy your basic editing needs. It provides you with features like a video trimmer/cutter, filters, video effects, and music tracks.
ViVid Cut also allows you to create slow-motion and time-lapse videos using simple tools. And the best part? It offers beauty filters that you can use to make your TikTok videos appear more attractive to your audience.
Key Features
Pros
Cons
9. KineMaster
KineMaster
KineMaster
KineMaster is a professional video editing app that facilitates seamless video editing. It offers high-quality templates, AI tools, and lots more that you can use to enhance the quality of your TikTok videos.
With KineMaster, you can create videos with transparent backgrounds, add text to videos, improve video image quality, and lots more. You don’t even need to be tech-savvy to navigate around the app. It also supports color filters to adjust the visual quality of your video.
Key Features
Pros
Cons
10. Veed.io
Veed.io Video Editor
Veed.io is a reputable online TikTok video editor that many content creators use to edit their videos. You can use this online video editor to add text, music, background effects, and lots more to your videos within a few clicks. It also allows you to automatically generate subtitles for your TikTok videos. All you just need is to upload the TikTok video and select the relevant settings, and this tool will edit your video without requiring you to install any app.
Key Features
Choose from a range of video effects to spice up your TikTok videos.
Built-in AI text-to-speech tools to create voiceovers for your videos.
Supports different video formats, including MP4 and MOV formats.
Optimize video aspect ratio to fit TikTok’s requirements.
Pros
It does not require the installation of an app.
Its user interface is very easy to understand.
Share edited video directly to TikTok.
Cons
Video quality is not guaranteed.
It uploads large video files slowly.
Compatibility: Mobile devices, PCs, and Mac
Bottom Line
The TikTok video editor in the article are great option for both experienced and non-experienced users. They all provide amazing tools that you can use to bring life out of your TikTok videos. However, be sure to read our review of each of the tools before making your final choice. We recommend the Movavi Video Editor for all users.
Joy Taylor
