If you are an iPhone user and your Wi-Fi automatically disconnects every time the phone is locked, check out this article to know how to fix Wi-Fi disconnects when iPhone is locked.
Wi-Fi has become one of the necessities to live in the current society. Normally, people prefer using Wi-Fi over mobile data when performing system or app updates. This is because Wi-Fi doesn’t usually have a data cap like mobile data. But after updating their iPhone to iOS 11.3, many users have reported that their Wi-Fi disconnects when iPhone is locked. This has made quite an uproar in the iPhone community.
Usually, you can’t keep the screen up all the time while the update is being downloaded. But according to the report, the Wi-Fi disconnects when iPhone is sleeping or locked, so the updates will be disrupted. One way to counter this problem is to disabling the auto sleep function on the iPhone, but this will drain the battery too fast.
So, you need to find another effective and feasible solution to the Wi-Fi is disconnects when iPhone is locked on iOS 11.3 problem. Here, in this article, we will share the best solutions to fix this problem.
See Also: What Does the Moon Mean on My iPhone Text Message in iOS 11/11.3 >
Many iPhone users have faced Wi-Fi is disconnects when iPhone is locked on iOS 11.3. This can be caused due to network-related issues, particularly the Wi-Fi network. Below are some of the best tips and solutions to solve the Wi-Fi disconnects when the iPhone is sleeping/locked.
If you are encountering the Wi-Fi disconnects when iPhone is locked problem on a particular Wi-Fi network, for e.g. your home or office, try forgetting it from the network settings and then rejoin the network. By forgetting the network, you will erase all the settings related to the particular Wi-Fi network that may be turning off Wi-Fi when the iPhone is locked or sleeping.
How to Fix Wi-Fi Disconnects When iPhone Is Locked
An active VPN is also known to cause many problems including Wi-Fi disconnects when iPhone is locked. So, if you have an active VPN on your iPhone, disabling it may help in solving the problem. To disable the VPN, navigate to iPhone Settings > VPN and then turn off the VPN if it is connected. Disconnecting the VPN should solve the Wi-Fi disconnects when iPhone is sleeping. But if even after disabling the VPN doesn’t fix the problem, move on to the next solution.
If Wi-Fi is disconnecting when iPhone is locked or sleeping, it is not necessary that the problem is associated with your iPhone. Sometimes, the Wi-Fi router can also cause problems like Wi-Fi disconnects when iPhone is locked. You can try updating the router firmware if it is outdated. As every router manufacturer has a different process of updating the firmware, visit the official website of your router manufacturer to get detailed information about the process.
Turning off Wi-Fi networking services can also help in fixing the Wi-Fi disconnects when iPhone is locked issue as reported by many users. Moreover, turning off the Wi-Fi network will also help you save battery. To turn off the Wi-Fi networking, go to Settings> Privacy > Location Services> System Services and then slide the Wi-Fi networking toggle to OFF.
Wi-Fi assist is a feature that turns on the cellular data when there isn’t any reliable Wi-Fi network to connect to or the connected Wi-Fi network is too weak. But this may very well be the cause of Wi-Fi disconnects when iPhone is sleeping. You can turn off the Wi-Fi assist if you think that the Wi-Fi is caused by the Wi-Fi assist by navigating to Settings > Cellular > Wi-Fi Assist.
If all the above solutions to fix the Wi-Fi disconnects when the iPhone is locked, then you can try resetting the iPhone network settings to erase all the Wi-Fi settings and passwords. You would need to again enter the passwords for the networks that were already saved. But this has shown to remove any problematic settings that may be caused by a faulty Wi-Fi setting. If this too doesn’t work, resetting and restoring the device is the only option. To prevent data loss, you should back up your data beforehand before restoring the device.
Backing up iPhone data with iTunes or iCloud is a very strenuous process. But you can’t skip the backup before you restoring the iPhone to fix the Wi-Fi disconnects when iPhone is sleeping to prevent data loss. Restoring the backup is as tiring as the backup process. So, you would want a better alternative to backup iPhone files. AnyTrans is the tool to help you manage your iPhone with ease.
Here, we list several amazing features of AnyTrans:
Just download AnyTrans to have a free trial. And follow the guide to backup all iPhone files to the computer without iTunes/ iCloud.
Backup iPhone Files without iTunes/iCloud
Sometimes, resetting and restoring the iPhone is the final option to solve various problems like Wi-Fi disconnects when iPhone is locked on iOS 11.3. But doing so can cause data loss. So, you can rely on AnyTrans to manage your iPhone data easily and securely. If you meet any problem while using the tool, let us know in the comments below.
