“I accidentally deleted my photos in Motorola album, I can’t recover it from my recently deleted folder. Is there any Motorola data recovery tool recommend?” – A user asked online.
You may wonder how to recover data from your Motorola phone. In this review, we will share the top 6 Motorola data recovery software in 2024 to help you retrieve lost or deleted data from Motorola. Moreover, a detailed comparison of these tools, including the types of files they support, pricing, and user reviews is provided. Read on to find the most suitable tool for your needs and ensure your valuable data is always recoverable.
You may also like: How to recover data on Android after factory reset
The first and foremost thing is to define the Motorola data recovery software. Simply speaking, Motorola data recovery software is a tool used to recover deleted or lost data that are not visible or even not accessible to you. But when you search solutions on the Internet, Google will offer you lists of Motorola data recovery software and you will be puzzled at selecting the best one among them. So we should remind you that a good Motorola data recovery software is supposed to have these features:
Also Read: How to recover lost photos on Android without root
For most Motorola users, recovering data is not easy. But with DroidKit Android Data Recovery, this work can be as easy as to count 1.2.3. As the most effective Motorola data recovery software, you can easily retrieve deleted, lost, and missed data using DroidKit.
Highlights and advantages of DroidKit:
No matter what kind of problems Motorola users encounter, DroidKit can get it fixed easily. Let’s check out how DroidKit works on data recovery.
Step 1. Download and install DroidKit on the computer. Also, connect your device to the computer with a good USB cable.
Step 2. DroidKit will detect your device in seconds, now you should already launch it. Choose the Data Recovery mode and select the Deep Recovery from Device option.
Choose Deep Recovery from Device from Recover Lost Data
Step 3. Unselect all and just choose the data you want to recover.
Select the Data Type You Need to Recover
Step 4. Now recover the data to your device by clicking on the To Device button, or save the data to the computer by clicking on To PC. (Here we take the message as an example)
Select Messages You Want
If you have lost or mistakenly deleted data from your Motorola before and want to retrieve them in one click, PhoneRescue for Android is the top 1 choice for you. As this tool is 100% clean and safe, easiest to run, and has the widest coverage, it has been firmly trusted by millions of users around the globe.
Advantages:
Disadvantages:
Just download PhoneRescue for Android and check how to recover data from Motorola phones.
Step 1. Download PhoneRescue for Android on your Windows or Mac computer > Install and launch it > Connect your Motorola phone to the computer via a USB cable (taking HUAWEI as an example).
Connect Huawei Phone and Run PhoneRescue for Android
Step 2. Select the types of files you want to recover from your Motorola (you can choose one, some, or all of them) > Hit the “Next” button on the right of the interface to start the scanning process.
Choose the Data Type to Recover
Step 3. After the scanning process, all deleted and existing data will be listed here, and you can choose “Only list deleted” if you just want to retrieve those deleted ones > Click “To Device” or “To Computer” button at the lower right corner to choose the place you prefer those data being recovered to.
Contacts Android Recovery App – PhoneRescue for Android
Step 4. When your data has been retrieved successfully, you can click the “View Files” button to check the recovered data or the “Start Over” button to get back to the home interface.
Jihosoft Android Recovery is the next Motorola data recovery tool we will recommend to you. It also has models respectively suitable for Windows and Mac. It shall be a good choice if you lost or deleted data and want to recover them as soon as possible.
Jihosoft Android Recovery Screenshot
Advantages:
Disadvantages:
FonePaw Android Data Recovery is a terrific recovery program as well, which runs on Windows and Mac computers. You can simply get the existing or deleted files from your Motorola phone out of its user-friendly interface.
If you are looking for easy-to-carry data recovery software, this tool can be a good one.
FonePaw Android Data Recovery Screenshot
Advantages:
Disadvantages:
As a powerful data recovery software, Wondershare Dr.Fone for Android enables you to retrieve data deleted, formatted, or even lost from your Motorola device.
Not just for Motorola, Dr.Fone can also work on other brands of Android phones, such as Samsung, HTC, Sony, Google, LG, Huawei, etc. So if you are eager to use an efficient and safe tool, it will be a good choice for you.
Wondershare Dr.Fone for Android Screenshot
Advantages:
Disadvantages:
Gihosoft allows users to check both existing and deleted files, and make a selective recovery. As a good application to help you recover your deleted or lost data, it supports any types of files, such as photos, audio, contacts, messages, videos, and documents. If you just want to recover data of these types, it is a pretty simple and easy way to make it.
Best Android Data Recovery App – Gihosoft Android Data Recovery
Advantages:
Disadvantages:
Software | Coverage of Files | Success Rate | Scanning Speed | Recover to Device | Total Value |
DroidKit | Wide | High | Less than 1o seconds | Yes | ***** |
PhoneRescue for Android | Wide | High | 35 seconds | Yes | ***** |
Jihosoft Android Recovery | Wide | High | 1 minute 15 seconds | No | ***** |
FonePaw Android Data Recovery | Wide | Middle | 44 seconds | No | ***** |
Dr.Fone Android | Wide | High | 41 seconds | No | **** |
Gihosoft Android Recovery | Wide | Middle | 1 minute 03 seconds | No | **** |
How to recover deleted photos from Moto G internal memory?
If you used Google to back up your photos and other data before deleting them, then you can try to recover them from Google. When you delete a photo or video, the data will be removed to the trash first.
So to recover a photo or video, you should open the Photos app first, find Bin, find the photo you want to recover, and click Restore.
How can I recover data from my Motorola Android phone with a broken screen?
No worries, to recover lost data from a broken-screen phone, you can use Autoplay, or you can use DroidKit to help you recover data from your Google account, SD card, SIM card and the device itself.
Can I free download the Motorola data recovery tool?
Of course, to protect the rights of users, you are allowed to download the data recovery software for free to try first. And most of the software supports to help you scan lost data within the trial version.
This review is completed based on precise and careful tests among lists of Motorola recovery tools. The tools mentioned above stand out to be the best Motorola data recovery software in 2024 because of many factors, such as wide coverage, high success rate, etc. Among all 6 products, DroidKit offers you the most comprehensive and powerful data recovery features. Just download it to try!
