Fix Samsung Smart Switch Stuck at 99% [8 Ways]
Samsung Smart Switch stuck at 99% during data transfer can be very frustrating. No worry, we will walk you through the 8 easy ways to fix this problem in this article. Besides, the best alternative to Samsung Smart Switch – DroidKit is attached for seamless data transfer!
Author Avatar Joy Taylor Last Updated: Nov. 28, 2023
Smart Switch is a file transfer that helps to migrate data from iPhone/Android phones to a Samsung mobile device. It transfers photos, messages, contacts, settings, and more so that you can set up your new Galaxy phone as soon as possible. But why is my Samsung Smart Switch stuck at 99%? How long will it take to transfer with Smart Switch? Read this guide and find out the answers.
Causes for Smart Switch Stuck at 99%
No matter whether your Smart Switch got stuck at 0%, 99%, or 100%, it’s not a full transferring process before the complete page shows. According to different user feedback online, there are some possible causes for Samsung Smart Switch stuck issue.
Damaged Cable or Port
The most common cause of the Smart Switch getting stuck is a damaged USB cable or Port. It can impair the connection between the two devices and ultimately block data transfer.
Unstable Network
An unstable or poor Wi-Fi can be a real roadblock during any data transfer. So, If your Wi-Fi is not working properly, it can cause the Smart Switch app to be stuck.
Low Storage Space
If your data is too large compared to the storage space on your target phone, it can hinder the data transfer process.
Data Transfer Overload
Another reason for the Samsung Smart Switch getting stuck is transferring a huge amount of data at once. It can overwhelm the app, or your Wi-Fi speed might not be able to catch up.
Low System Version
Either of the devices having a low system version will also cause Samsung data migration stuck at 99% issue.
Compatibility Issues
Last but not least, there might be compatibility issues between your devices or the data you are trying to transfer.
How to Fix Samsung Smart Switch Stuck?
Before moving to the possible fixes, make sure you are using the Samsung Smart Switch app correctly. For this, you can look at Samsung’s instructions for using the app. Then try the following fixes to resolve the Smart Switch stuck at 99% problem.
Fix 1. Change the USB Cable and Port
Most basically, make sure your USB cable, adapter, or connecting ports are not damaged. To do so, you can take the following measures.
  • Unplug Your Phones: unplug the devices, close Smart Switch on both phones, and try again. Meanwhile, try swapping the ends of the cable when you re-plug in the devices.
  • Connect Different Devices: Next, plug in other phones or devices to check if they work with the same USB cable and adapter.
  • Clean the USB Port: If the other phones are working fine, clean your phone’s USB port to get rid of any dirt or debris.
Replace the USB cable with a new one if it doesn’t work at all. Try again and see if your Smart Switch transfers data normally.
Fix 2. Charge Your Devices
Ensure that both devices are charged with a high battery so that it will slim down the possibility of powering off or getting stuck at a certain percentage. A wired connection will help to charge when migrating files. If you use the Wi-Fi transfer mode, you can conveniently charge your devices during the process.
Fix 3. Connect to A Stable Network
Switch from a USB cable connection to a wireless one or vice versa. Since Samsung Smart Switch supports both wired or WiFi connections, you can make an exchange if the present connection causes you stuck at 99%. It works for some people who have canceled the transfer with the cable and chose the wireless transfer method instead.
Fix 4. Free up Space on Samsung
You may dismiss how much storage is left on the target Samsung phone while the transferring data needs more space than existing. If this is the case, try to free up some storage on your Samsung phone so that it can undertake the full data, or insert an SD card to save more files.
To free up space on Samsung:
Step 1: Go to your device’s Settings and select the Battery and Device Care option.
Step 2: Now, tap on the Storage option to open the Internal storage of your device.
Step 3: In the internal storage, you can check where most storage is used and delete the specific files.
Free up storage space
Fix 5. Don’t Transfer All Data at One Time
“I find it’s the text messages that take longest. If you choose to transfer like 50k text messages it tends to freeze on it”. A user posted on Reddit.
Smart Switch data migration stuck at 99% can also be solved by migrating each type separately. Partly transferring files will not only increase the speed but also give you a chance to know which file might be the culprit. Besides, it makes it possible to transfer important data only if you don’t have enough space on Samsung phone too.
Fix 6. Clear Cache on Smart Switch App
If all else fails, the issue might be with the Samsung Smart Switch app and has nothing to do with your phone. If the Smart Switch is taking forever to transfer data or is stuck at one point, try clearing Samsung app cache and residual files. Make sure to do it on both the source and target phone.
To do this, you can take the following steps.
Step 1: Tap the Settings of your device and navigate to Apps.
Step 2: Now, find and tap Smart Switch.
Step 3: Next, tap on Storage and select Clear cache.
Clear Smart Switch cache
Note: Alternatively, you can clear the app’s data by tapping Clear data.
After you have taken the above steps, you can restart the data transfer and check if the Samsung Smart Switch stuck problem has been fixed.
Fix 7. Reinstall the Samsung Smart Switch
Sometimes, an app installed incorrectly can cause malfunction during operation. As it’s hard to decide which components are missing or corrupted, the better choice is to reinstall Smart Switch app on your phone.
Go to Settings > Apps. Then, find Smart Switch and uninstall it before downloading it again from the Google Play Store. Make sure that you repeat this process for both devices.
Uninstall Smart Switch & Reinstall
Fix 8. Update Device Systems
Samsung Smart Switch works on Android 4.3 or iOS 4.2.1 or later. The target new phone is not likely to fall into system incompatibility while your source device may be too old to use Smart Switch. Make sure both phones are using proper system versions. Upgrade to a supported version if one of them is running a system below the requirements.
Step 1: Go to your phone’s Settings. You can pull down the notification panel to click on the settings icon.
Step 2: Next, select Software Update.
Step 3: Now, tap the Download and install the available updates.
Step 4: After updating your device, restart your phone and relaunch the Smart Switch app.
Update Samsung System
Note: Make sure to back up important data before installing software updates.
So, there you have it: a complete rundown of all the possible fixes to the Samsung Smart Switch stuck at 99%! We hope that these fixes aid in your data transfer with Smart Switch.
But if none of these work for you, we suggest replacing Smart Switch with another app. You can continue below to find the best alternative to Samsung Smart Switch for smoother data transfer.
Best Alternative to Samsung Smart Switch
To make the data transfer more convenient without getting stuck, an alternative to Smart Switch data migration will be a great choice. DroidKit is an Android toolbox mastered in transferring files, system fixes, data recovery, etc for Android phones besides Samsung. What you can do with DroidKit:
Download DroidKit and install it on your Windows or Mac.
Follow the steps to transfer data from your old device to your Samsung phone with DroidKit.
Step 1
Launch DroidKit and choose Android Mover.
Choose Android Mover
Step 2
Choose iPhone to Android or Android to Android mode for data migration. (Let’s take Android to Android as an example)
Choose Android to Android
Step 3
Connect both devices to your PC with USB cables. Once your devices are detected, click on the Migrate Now option.
Click on Migrate Now
Note: Make sure to launch the USB debugging option on your Android devices. By default, DroidKit will detect your Android devices automatically.
Step 4
Now, DroidKit will start loading your data from your source phone. After the loading process is complete, select the files to transfer and click the Next option.
Select Data You Want to Transfer
Select the Data You Want to Transfer
Step 5
Wait for the data transfer process.
Transferring Data
Transferring Data
Step 6
After the migration, check if your target phone is stored with the files and unplug both devices.
Data Transferred Successfully
FAQs About Samsung Smart Switch
1. Is Smart Switch faster with cable or wireless?
Transferring with a USB cable is supposed to be faster than a wireless connection. However, according to some users’ discussions, they got the Smart Switch stuck when using a wired connection. Ending up with WiFi transferring, it works in just a few minutes. You can try to switch your connection if your Samsung Smart Switch transfers slowly.
2. Do both phones need Internet for Smart Switch?
Yes, both phones need Internet for Smart Switch file transfer. Either of the phones gets disconnected may result in transferring stuck issues. Make sure you have connected both phones with a wireless network or using a USB cable.
3. How long does Smart Switch take for data transfer?
The transfer time depends on how many files you have. The more files you choose, the longer it will take for Smart Switch migration. It’s better not to transfer too much data at once to decrease the possibility of getting stuck.
4. What happens if I stop Smart Switch during transfer?
It will be okay if you stop Smart Switch transfer halfway. The transferred files will be saved on both devices and the left ones can be migrated when you resume the transfer. Some people may stop Smart Switch when getting stuck during a transfer, just tap on the Stop button and Resume later at your convenience.
Final Thoughts
Samsung Smart Switch stuck at 99% issues are common but can be avoidable, as long as you have confirmed your phone system, available storage, charge status, and network connection. Actually, DroidKit is recommended as the best Smart Switch alternative for data management on Android devices. It will always keep your data safe with powerful recovery and transfer. Download DroidKit now and better manage your Android files without problems.
