This guide will show you 10 common fixes of the iPhone no sound issue. You can check them and find one useful way for you.
Many users reported that there is no sound on iPhone or their iPhone sound not working normally. There are many conditions of no sound on the iPhone: no sound on the videos, speaker sound not working, alarm sound not working, no sound on games or apps, sound not working without headphones, and so on. What to do when you hear no sound on your iPhone? Here we list some common but always work solutions. You can check them one by one; hope one of these solutions can help you out.
Most of the time, we don’t know what causes no sound on iPhone. In this case, an iOS system repair tool will help check your iPhone status and make a response to the issues. AnyFix – iOS System Recovery, as a system/iTunes troubleshooter, supports fixing over 200 iTunes problems and more than 130 system issues within a few steps. Follow the tutorial list below to fix the iPhone-no-sound problem.
Step 1. Launch AnyFix> connect your iPhone to the computer > choose System Repair.
AnyFix Main Screen
Step 2. Tap on the Device Bug >Click on the Start Now to go on.
AnyFix System Repair Device Bug
Step 3. We recommend Standard Repair as the most suitable repair mode for you to repair your iPhone which won’t risk any iPhone data loss.
AnyFix Standard Repair
Step 4. Following the leading steps for a while, you will see the screen on your computer.
Repair Completed
Check the Ring/Silent switch. When you turn the Silent switch on and forget to turn it off will lead to this issue. So, first of all, you should make sure that your iPhone is not in silent mode – move the switch forward—toward the device’s display—so that orange isn’t showing. After the Silent switch is turned off, then adjust the volume with the volume buttons or the slider in the Control Center.
Check the Silent Switch and Adjust Volume
Further Reading: How to Fix Silent Switch Not Working on iPhone >
When Do Not Disturb is enabled, you will see a little moon sign in the top right bar on your iPhone, and you will not hear any sound on your iPhone. So, you need to ensure that it’s off.
Turn off the Do Not Disturb
If your iPhone is connected to another device, the sound will be transmitted to that device so that you can’t hear any sound on your iPhone. Thus, if you enabled Bluetooth on your iPhone, go to Settings and click on Bluetooth, turn it off.
Turn off Bluetooth from Control Center
If you can’t sound or anything from your iPhone, you need to check whether iPhone speaker is not working. Go to Settings > Sounds & Haptics (or Sounds), drag the Ringer and Alerts slider back and forth a few times.
Check the iPhone Speaker
If a sound appears, the iPhone speaker works. If you still can’t hear a sound, the device may need a hardware repair. Or if your speaker button on the Ringer and Alerts slider is dimmed, your speaker might need service. Contact Apple Support for iPhone, iPad, or iPod touch.
If you can’t hear any sounds from a specific app or some apps, the problem may be in your Notification settings. Make sure that you turn on Allow Notifications and Sounds. You can check by going to Settings > Notifications and choosing the app. On the next screen, make sure both the Allow Notifications and Sounds switch are green.
Fix iPhone No Sound by Enabling Notifications and Sounds
An outdated system can also cause problems on iPhone. Every iOS system update would fix some minor bugs including sounder issues. So check for system software updates and download the latest iOS version.
If there is no sound in games or some apps, check for App updates to fix sound bugs.
Close all the applications on your iPhone, turn off your iPhone then turn it on. To do this:
If the above methods are not working, you can try to reset the settings on your iPhone. Just go to Settings > General > Reset. Tap Reset All Settings, which will reset the sound, display, and network settings to defaults. So it can probably work for iPhone sound.
Reset All Settings on iPhone
If the problem still remains, you can have a try on Reset Network Settings. Generally, it can reset Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you’ve used before. Some users reported it’s useful for their devices.
No sound on iPhone can be a frustrating issue but it’s possible to fix in some ways. We have an ultimate way to use AnyFix and 9 common solutions to iPhone no sound issues. You can try one of them as you want. For those who can’t figure out the problem causes, AnyFix is the best choice. It will check and repair iPhone system in one click. Download AnyFix and resolve no sound on iPhone quickly.
