Are you one of the iPhone users who is facing the iPhone silent switch not working problem? Then, this guide has provided the various methods to fix iPhone silent button not working irrespective of which iPhone model you have.
The silent switch button on the left side of the iPhone is great functionality to put the ringing device into the silent or mute mode without any hassle. However, many issues have been reported related to iPhone silent button not working. It can cause that you can’t enable silent mode or iPhone is not ringing. Sometimes, when you switched for many times, your device will be stuck on silent mode or stuck on mute mode. Luckily, if you have a warranty for your iPhone, then you can replace your iPhone by visiting the store. However, if the warranty period expires for your iDevice, what do you do if your silent button doesn’t work?
Then you can use the below-mentioned to fix iPhone silent switch not working. The methods that we are going to discuss are for every iPhone model. Therefore, whether you are using the latest iPhone 15, iPhone 14, iPhone 13, or earlier iPhone models such as iPhone X, 7, or 8, you can try these methods on your iDevice.
Also Read: What Does Deliver Quietly Mean and How to Enable/Disable it >
If you encounter the iPhone silent switch not working issue, especially when the Ring/Silent button is broken, then you can silent or mute your iPhone from the Assistive Touch button. It is another hassle-free functionality to manage your iPhone. It is grey in color and float on your iPhone screen. To use Assistive touch on your iPhone, first, you need to enable it from the settings. Here is how to silent iPhone via this feature.
Step 1. Go to the “Settings” app and then, open the “General” settings. After that, tap on “Accessibility”.
Step 2. After that, click on the “Assistive Touch” and then, enable the Assistive Touch.
Turn on Assistive Touch
Step 3. Now, you can tap on the Assistive Touch button to open its menu and then, click on the “Device” to mute your ringing phone.
Tap on the Assistive Touch button
In some older iPhone models, the icon will be in different shapes and styles such as the bell icon, but the functionality will remain the same.
If your iPhone mute button not working, then you can also use the volume down button to mute your iPhone during ringing. The volume down button is on the left side of every iPhone model. To silent phone using this method, long-press the volume down button until sound does not reach the zero level. It is another alternative to the silent switch button.
What to do if my silent button on iPhone doesn’t work? You can silent your iPhone by setting a silent ringtone as default to fix the iPhone silent button not working issue. Adding a silent ringtone to iPhone is an easy task and you can do it using the iTunes library.
Step 1. First of all, download the silent ringtone from the internet on your computer and then, run the latest version of iTunes on your computer.
Step 2. Now, tap on the “Tones” tab under the iTunes library and paste the downloaded to it. Connect your iPhone to the computer. Then, tap on the “Device” icon and sync iTunes library to your iPhone.
Sync Tones with iPhone
Step 3. After syncing, the ringtone will appear on your iPhone. Then, open the “Settings” and then, open the “Sound and Haptics”. Finally, tap on “Ringtone” and set the silent ringtone.
Set Silent Ringtone on iPhone
Even though silent button on iPhone not working, you can still turn on your Airplane mode to silent your phone and while Airplane mode, you can still use the Wi-Fi network. Your all incoming calls will move to a voicemail that you can hear after turning off the Airplane mode. Here are the steps to fix iPhone silent switch not working.
Turn on Airplane Mode
If you want to silent your text notification such as emails, messages, and many more, then on the iPhone, Text Tone is a feature that can be used to silent notification that you will receive. Here is how to silent your iPhone with this feature when silent mode iPhone not working.
Turn on Text Tone
If the above methods didn’t work for you, the iPhone silent button not working issue may not be caused by some hardware problems. For example, your iPhone stuck in silent mode or there are other issues related to system problems. We strongly recommend you an iOS system repair tool, which is AnyFix. This tool provides you with a one-stop solution to fix various iOS problems, like iPhone ringer button not working, iPhone stuck on Apple logo, black/blue screen, etc. You can choose from 3 repair modes to fix this problem. And the Standard mode even supports to repair without data loss. Most importantly, it requires no skills and supports all iPhone models, including iPhone 15.
Also, if you meet the iTunes update/connection/sync or other iTunes errors, AnyFix can get it back to life. Besides, you can enter/exit Recovery Mode in one click. Therefore, AnyFix makes it easy to solve most issues related to your iPhone.
Now, download the latest version of AnyFix. And, here is a step-by-step guide on how to fix silent mode on iPhone via this tool in clicks:
Step 1. Launch AnyFix and you will see the interface below. Choose System Repair to continue.
AnyFix System Repair Option
Step 2. Tap on iOS Mode Stuck and Start now. Remember to connect your device to the computer using a USB cable.
AnyFix System Repair iOS Mode Stuck
Step 3. Choose a repair mode that your iPhone needs. Currently, iOS repair function provides three repair modes: Standard Repair, Advanced Repair, and Ultimate Repair. Here we take Standard Repair as an example. With Standard Repair, it supports fixing the most common system issues and no device data will be erased after the repair.
AnyFix Standard Repair
Step 4: After choosing one repairing mode, it will detect your iPhone to match firmware. Then tap on the Download button to get matching firmware.
Step 5: When firmware download is completed, click Start Standard Repair. It will ask you to enter recovery mode if you didn’t do that before.
Step 6: After that, it will start repairing the system like the below picture shows. Then wait a while and you will see the Repair Completed page when the recovery process is completed.
Repair Is Completed
That’s all how you can fix the iPhone silent button not working. You can refer to this guide and all the above methods will work perfectly on later iPhone models also. And if your iPhone stuck in silent mode or this issue is caused by system errors, AnyFix will help you out. Just free download AnyFix to fix this issue now.
