  1. Method 1. Re-enable Your Group Message
  2. Method 2. Check If You Have Left the Group (Re-join)
  3. Method 3. Delete the Conversation & Start a New Group Message
  4. Method 4. Link the Phone Number to Apple ID
  5. Method 5. Check Group Message Notifications
  6. Method 6. Carrier Settings and iOS Software Updates
  7. Method 7. Force Restart Your iPhone
  8. Method 8. Repair Your iPhone System
  9. The Bottom Line
Home Support Why My iPhone Not Receiving Group Texts & How to Fix
There are various reports on Reddit that iPhone not receiving group texts. It can be caused by phone limits, wrong settings, or system bugs. No matter what situation you are in, there is a way out. This post will introduce 8 methods to fix not receiving group texts on iphone according to different cases.
Joy Taylor | Last Updated:Feb. 14, 2025
1535 words|5minute
Group messaging is one of the basic yet useful functionalities of any iOS device. That is why having your iPhone not receive texts or group texts is a frustrating experience. But don’t worry about that too much. In the following guide, 8 effective solutions that proved to be useful will be offered to help you fix the iPhone not receiving group messages problem effortlessly.
You should know that your iPhone, by default, sends group messages as MMS messages rather than SMS messages. To send and receive group messages, you need this functionality activated. If one or more of your contacts are not receiving group messages on their iPhones, then you should first check if you have activated group messages on your device.
Fix: iPhone Not Receiving Group Messages – Enable Group Messaging
Enable Group Messaging from Settings on iPhone
If you don’t see an option to turn on MMS Messaging or Group Messaging on your iPhone, it means that your carrier might not support this feature. So you need to check with your carrier or follow Method 6 to fix the message not delivered.
You definitely must be a member of a group conversation if you are to get group texts. That is why you need to check if you are still a member of a group if your iPhone is not receiving group texts.
Anyone in a group iMessage can add someone from the conversation: Tap the group conversation that you want to add someone to > Tap the top of the conversation > Tap “i” and click on Add Contact > Enter the contact information for the person you want to add > Finally tap Done.
However, if one of the users in the group is using a non-Apple device, you can’t add anyone. Then, you need to follow the next method to start a new group message.
If your iPhone is not getting group texts and no group member is available to add you back to the group, you can try another fix. Sometimes you can restart group messages by deleting the conversation and starting a new group message.
Delete Conversation:
Start a New Group Message:
Just in case you mistakenly remove the valuable messages while deleting the unwanted conversations, the guide about how to recover deleted messages on iPhone is offered here.
In a scenario where your iPhone is not receiving group texts while you are still able to get group messages on another iOS device, it is worth checking whether your phone receives messages using your phone number or via your Apple ID.
Fix: iPhone Not Receiving Group Texts – Link to Apple ID
Once you have completed the above steps, you should go to Settings and select FaceTime there. Repeat the same steps to link your Apple ID and iPhone number and start receiving group messages using both methods.
iOS enables you to hide message alerts without leaving a conversation, which might make you think that your iPhone is not getting group texts. Here are the steps to check whether the group message notification is switched on:
Anyway, an iPhone will not receive group texts if the sender’s carrier has put a limit on the number of group messages one can send. Certain telecoms may limit your group messaging to some 10 conversation members. Also, an update or a faulty update by your carrier or Apple may result in not receiving group messages on your iPhone.
Some carriers may also prevent you from sending MMS messages. If you constantly get an alert “Not Delivered” for a message, you may need to do the following steps:
Sometimes, you are not receiving group texts on iPhone because your phone is stuck and a force restart can help. Follow the steps below to finish force restarting your iPhone and solve the group message problem.
If none of the above methods solves the iPhone not receiving group texts issues, you can try to fix your iPhone system and make it run normally. AnyFix is recommended as a useful iOS system repair tool to fix 150+ system issues without data loss.
Steps to fix iPhone system issues with AnyFix:
Step 1. Download and install AnyFix on your computer.
Free Download   for all windows & 100% safe Free Download   for all mac & 100% safe
Step 2. Launch the software and choose System Repair.
AnyFix System Repair Option
Step 3. Use a USB cable to connect your iPhone and choose App Issues.
AnyFix System Repair App Issues
Step 4. Choose Standard Repair Mode and follow the instructions to start system repair.
After repairing, your iPhone will restart and you can check if it receives group texts from others.
Repair Is Completed
Repair Is Completed
Usually, you will be able to restore an iPhone not receiving group messages to normal operation by applying one of the above tips. Nonetheless, your iPhone may not be receiving group texts due to carrier or network issues, so do not be too fast to reset to factory settings if you are experiencing continuous problems with a specific conversation. For those who cannot fix iPhone not receiving group messages with simple settings, AnyFix is an alternative to repair iOS in quick steps. Try it now and get your iPhone back to normal easily.
Joy Taylor
