Why are my iPhone contacts not syncing? Read this post to learn some potential fixes and get a new way to backup iPhone contacts to iCloud.
My iPhone 12 contacts are not syncing to iCloud even though it is ON. I need all my contacts synced to iCloud as a backup. It is a new iPhone running iOS 14, any ideas?
Many iPhone users rely on iCloud to backup important iOS data like contacts, notes, calendars, photos, videos, and etc. Sync iPhone Contacts to iCloud, you can access and manage all your contacts from your iPhone/iPad/iPod touch/Mac. And if you open iCloud Contacts On, it will update automatically. But after bought iPhone 12 Pro (Max), or updated to the newest iOS version – iOS 14, some users found that their iPhone contacts not syncing properly, or even not syncing with iCloud at all.
iPhone Contacts Not Syncing
In this post, we are going to show you some potential fixes to fix iCloud contacts not syncing issues, and also provide you an alternative way to backup your iPhone contacts with/without iCloud.
If your iCloud contacts not syncing, go to Settings > Contacts > Default Account > Select iCloud.
If you have more than one account with contacts, make sure that you’re signed in to iCloud with the same Apple ID on all of your devices. Check your iCloud account on iPhone: Tap Settings > [your name] > Name, Phone Numbers, Email.
If the above still not working, try re-login your iCloud account from your iPhone: Settings > [your name] > Sign Out. Restart your iPhone and add it again and restart it once again.
After you tried any one of the above methods, you can check whether it works to refresh your contacts: Open the Contacts app > Tap Groups in the upper-left corner > Swipe down on the list to refresh your groups.
If your iPhone contacts still not syncing to iCloud and you want to backup them right now, keep reading to learn an alternative tool for backing up iPhone contacts. AnyTrans is specially made for iOS users to transfer, backup, and manage iOS content on iPhone iPad, and iPod (touch). Download AnyTrans to have a free try >
Step 1. To back up and manage your iPhone contacts, firstly open AnyTrans, and connect with your iPhone > Click More under Device Manager to enter managing content in the category page.
Click More Tab under Device Manager of AnyTrans
Step 2. Choose Contacts and now you can view and choose contacts you want to backup, and click the Send to Computer button, Send to Device button or Upload to iCloud button to backup your iPhone contacts.
Alternative Way to Backup iPhone Contacts with AnyTrans
Now you have learned various methods to fix iPhone contacts not syncing to the iCloud issue. To prevent you from the same issues, here, we’d like to brief you on some tips for managing iPhone and iCloud contacts.
If you met the problem when sync contacts with iCloud, you can try the above quick fixes to iCloud contacts not syncing to iPhone/iPad/Mac. Or, you can try to use AnyTrans to backup contacts to the computer in the readable format. It is easy-to-use and works for all iPhone, iPad, and iPod. Get it and take a tour now >
