Full Guide on How to Transfer Contacts from Samsung to Samsung
If you are searching for some methods of transferring contacts between Android phones, the following guide will offer you 6 top ways to help you transfer your contacts from Android to Android! Scroll down to learn how.
Author Avatar Joy Taylor Last Updated: Sep. 07, 2023
Nowadays, many guys become Samsung fanatics. More and more people begin to use 2 Samsung phones, one for business, the other for personal life. Coincidentally, I am one of them. I can totally understand how daunting it is to transfer some necessary data like contacts between 2 devices. It is such an inevitable thing that we must think about how to make it. Fortunately, I have already made a comprehensive guide on how to transfer contacts from Samsung to Samsung for you, just pick one you like most!
1. Transfer Contacts from Samsung to Samsung 1-Click [100% Work]
If you prefer an easy and quick way to copy contacts from Samsung to Samsung, among these methods, I put DroidKit – Complete Android Solution top 1 in the list.
What Is DroidKit:
DroidKit is a fascinating and user-friendly software for most phone troubles. It can transfer all the complicated data stored on your Android smartphone and showcase it straightforwardly by classifying it into appropriate categories. You can view all the contents coherently and efficiently manage them.
Its Android Mover function supports one-click phone switching, transferring contacts from an old Samsung to a new Samsung is no longer difficult with DroidKit! What’s more, DroidKit has also introduced new features of WhatsApp Manager!  It lets you manage WhatsApp data in all aspects – transfer, backup, and restore your WhatsApp data easily, so you no longer worry about data loss!
Key Features:
  • It is the easiest method, what you need is just a USB cable and your two Samsung phones.
  • Superfast transfer speed. For example, transfer 1500 + photos in 3 minutes.
  • It is a totally safe green software and there are no worries about any data loss or information leakage.
  • Preview, select, and transfer contacts you’d like to transfer.
  • Full-way Android solution: helps you recover lost Android data, fix Android system issuesunlock your Android Phone, etc.
Free get DroidKit and follow the detailed steps to transfer contacts from Samsung to Samsung 1-click>>
Step 1. Free download DroidKit on your computer > Choose the Android Mover option under the Data Manager mode.
Choose Android Mover
Step 2. As we are going to transfer contacts from Samsung to Samsung, here, simply choose the Android to Android option.
Choose Android to Android
Step 3. Connect your two Samsung devices at the same time with a USB cable.
Click on Migrate Now
Step 4. Choose the Contacts category and tap on Next. Then, you can preview and select all contacts at once or a single contact just like you want to transfer.
Select Data You Want to Transfer
Step 5. Choose transfer now and the DroidKit will transfer your contacts automatically. Wait for a while, the Transferred Successfully page will appear as below:
Data Transferred Successfully
2. How to Transfer Contacts from Samsung to Samsung with Gmail
If you are an Android fan, you probably have got a Google account/Gmail account. If you don’t, my suggestion is that you create a new one if you don’t have a Gmail account anyway. In my point of view, it is also a nice try to transfer contacts via Gmail. Scroll down to know how:
Step 1: Add a Google account on your Samsung phones. You need to go to “Settings > Accounts > Add Account > Google”, in the final section, you have to sign in to your own Gmail account.
Step 2: Transfer contacts to your Gmail account. Please go to “Settings > Accounts > Google > Sync Contacts”.
Step 3: Sync the contacts to the new Samsung phone. After adding your Google account on the target Samsung phone, please go to “Settings > Accounts > Google > Contacts > Sync Now”. Now you have your contacts on your new Samsung phone.
3. How to Transfer Contacts from Samsung to Samsung via vCards
The vCard file/vcf is the standard file format for contacts. To transfer all of your contacts from Samsung to Samsung, you can utilize a vCard file.
To utilize this method, export all of your contacts to a vCard file, then send the vCard file to your new Galaxy, and then import the vCard file into your new Samsung phone.
  • Go to the Contacts App on the source device, and click the three vertical dots from the top-right corner. Tap Settings > Contacts. Please make sure that there is a SIM card on your Samsung phone.
  • There you can have an option of Import/Export contacts. Tap Export to Device Storage. Confirm the export. All contacts would be generated as vCards to SIM card.
  • Remove the SIM card from the source Samsung phone and then install it on the target Samsung phone.
  • Run on the target device, go to Contacts App, and follow the step 1 to get to the option of Import/Export contacts. Select Import vCard file. Now, click the vcf files you want to import to Samsung phone, click OK.
4. How to Transfer Contacts from Samsung to Samsung with Bluetooth
You can also choose to transfer contacts from Samsung to Samsung via Bluetooth. Note that this method requires exporting the contacts to a vCard and then transferring the vCard to the target phone via Bluetooth. Before transferring contacts from a Samsung phone to a Samsung phone via Bluetooth, please make sure that Bluetooth is turned on on both devices and then pair the devices.
You can try transferring a small file between the two devices to confirm connectivity. This method could be a bit time-consuming, please be patient.
  1. Make sure you have turned on Bluetooth on both Samsung phones. Pair your Samsung phones.
  2. Go to Contacts App of the source device, tab and hold any of the contacts you want to transfer to the new Samsung phone. When the tapped contact is checked, tap Select All or manually check the box in front of each contact’s name individually.
  3. Once desired contacts are selected, tap the Share icon from the top of the Window. From the displayed options, tap the Bluetooth icon.
  4. From the paired devices, choose the one you want to send selected contacts to.
  5. On the target Samsung phone, accept the incoming files. Please wait patiently until the process is finished.
5. Transfer contacts from Samsung to Samsung with Smart Switch
Samsung often offers an official method to help you to transfer data like contacts from your previous compatible device to your new Samsung via an USB cable. But I think its function is quite single compared to Method 1. Continue to know how if you need this:
Step 1: Connect the two Samsung phones.
Step 2:  Open the Smart Switch app.
Step 3: Select the contacts you want to transfer. A Tap “Import” at the bottom of the screen to start transferring your contacts.
6. How to Send Contacts from Samsung to Samsung via A VCF File
Compared with method 2, this method may be faster. If you too many contacts, sending them with an Email attachment might be a better choice.
  • Step 1: Run on your source Samsung, please go to “Contacts > Manage contacts”.
  • Step 2: Please go to “Import/Export contacts, in this step, you need to choose “export” as Vcard file to SIM card.
  • Step 3: Then you need to find out the vcf file on your phone with a file finder.
  • Step 4: Using Email. Please Email it as an attachment to your target Samsung device.
  • Step 5: Sign in the Email account on the other  and download the vcf file easily.
  • Step 6: Please go to “Contacts > Settings > Manage contacts > Import/Export contacts > Imports vcf dile > Ok”.
How to Transfer Contacts from Samsung to Samsung via A VCF File
These are workable ways to transfer contacts from Samsung to Samsung, and you can select one that suits you. However, in my eyes, I would recommend method 1. DroidKit owns comprehensive functions that can manage all your necessary data. It can not only backup, transfer, and manage your content between mobile devices like Samsung phones, computers, and even iPhones. So why not download it now give DroidKit a shot!
self serviceself service
iMobie Self-Service
reduceclose
customer service
End conversation
