Forgot Samsung pattern lock and have no idea on how to unlock it? Don’t worry, this post is going to show you 4 simple and free methods to unlock Samsung phone if forgot pattern.
Free download DroidKit to 1-click to unlock a Samsung Phone when you forgot the pattern.
It will be very frustrating when you want to open your Samsung phone but forget the pattern lock Samsung. Getting in such a predicament, you must be eager to unlock the pattern lock in Samsung to make it workable again, right? Keep reading to figure out how to unlock the pattern lock if you fail to remember it.
How to Crack a Pattern Lock
Fortunately, it’s easy to make it. In the following post, we will introduce 3 easy methods to help you unlock a Samsung phone if you forgot the pattern completely. These 3 methods can help you unlock pattern lock without losing data. Here we go!
Also Read: How to Unlock Samsung Lock Password without Losing Data >
You’ll be allowed to draw the wrong pattern five times, and the sixth is locked. And then you will see a message “You have incorrectly drawn your unlock pattern 5 times. Try again in 30 seconds.” In this way, you can use your Google Account to unlock your Samsung Phone when forgetting the pattern. Supports only Android 4.4 or lower.
Step 1. Draw a wrong pattern 5 times on your Samsung phone.
Step 2. Tap Forgot pattern.
Step 3. Enter your Google Account and password.
Step 4. Once you have signed in, you can set a new PIN, pattern or password to reset the forgot pattern.
How do I unlock my Samsung phone if I forgot the pattern, PIN, password, or fingerprint? How to unlock Samsung phone forgot password without losing data? The professional Android solution – DroidKit – Android Phone Toolkit would be your first choice! As one of the easiest Android Phone Unlockers in the market, DroidKit enjoys a sound reputation among Samsung users and other Android models.
With DroidKit, you can remove various types of passwords such as pattern, PIN, digital number, fingerprint, and facial recognition. And you don’t need to root your device to finish unlocking. Except for Samsung phones and tablets like the latest Samsung S21 or earlier Samsung Galaxy S8, you can also unlock other 20,000+ models of phones and tablets, covering Sony, Motorola, Google Pixel, Huawei, etc.
What’s more, you can also remove Google Account from Samsung if forgot password with the help of DroidKit. And you can explore more functions about DroidKit – a complete Android solution.
Step 1. Install and launch DroidKit on your computer > On the welcome page, go to the Screen Unlocker mode to initiate the progress.
Choose Unlock Screen Function
Since unlocking the screen will erase the data on your Android device, you may need to establish a Samsung backup in advance.
Step 2. On the “Unlock Screen” page, read the notes and hit the Start button after connecting your Samsung device to the computer via a USB cable.
Connect your Locked Phone
Step 3. After DroidKit prepared the configuration file for your device, click Remove Now. Then check Samsung to confirm your device brand.
Step 4. Following the on-screen instructions put your Samsung phone into recovery mode and wipe the cache patterns on your phone.
Step 5. Wait for a few minutes, you will get the Screen Lock Removal Completed page below.
Lock Screen Is Removed Successfully
If you have enabled Find My Mobile in the phone settings, you can remotely unlock your Samsung with it. To use Remote Unlock of Find My Mobile, your device must be turned on and be connected to a network. To unlock Samsung:
1. Go to Find My Mobile and sign in to your Samsung account.
2. Select your device from the list.
3. Select Unlock on the right side of the screen.
4. Enter your Samsung account password when prompted, and select Next or UNLOCK to make sure.
Samsung Find My Mobile
And, Google Find My also enables you to unlock your phone with the pattern and data permanently erased. Just enter the Find My Device website, log into the Google account, and choose ERASE DEVICE, your Samsung can be unlocked with the factory reset done.
Sometimes you can bypass Samsung forgot Pattern/Pin/Password via Smart Lock. Some conditions include on-the-go detection (the phone stays unlocked while on-the-go), establishing a trusted location (e.g., your home or office), or connecting to a trusted Bluetooth device (e.g., your car’s system or a wearable device).
If you want to try the master code to unlock Samsung pattern, you can try “*2767*3855# *2767*2878#”, and restart your device. Please make sure your phone is backed up to avoid data loss.
That’s all about how to unlock a Samsung phone if forgot the pattern, both above 3 methods can help you make it with ease. In a word, if you want to quickly remove pattern lock without limitation, you can download DroidKit.
