Unlock Samsung Phone Forgot Password Without Losing Data
Some Samsung users may forget pattern or password of the phone. Then, how to unlock it if you don’t want to lose any existing data on device? Read this post to see how to unlock Samsung phone forgot password without losing data.
Author Avatar Joy Taylor Last Updated: Mar. 05, 2025
DroidKit – 1-Click Unlock Samsung Phone Password in Easy Steps
How to unlock your Samsung when you forget the password? Free download DroidKit to 1-click unlock Samsung password, pattern, PIN, fingerprint, and face ID. Supports all Samsung models with Android 6 – 15. No technical skills are required.
I forgot the password lock that I changed last night on my Samsung. Is there any way can unlock my Samsung without losing data?
Considering data security and privacy, most of you prefer to set a password, pin, or pattern lock. However, if you forget the password like the above user, you may get locked out of your Samsung device. Normally, resetting your phone via PC is one of the options to regain access, but this erases all data on your phone. So, is it possible to unlock a phone forgot password without losing data? Yes! Read this article to learn 5 effective methods of unlocking Samsung phone forgot password without losing data.
1. Unlock Samsung Phone Without Losing Data via Find My Device
How to unlock a Samsung phone without losing data? Android Device Manager is one of the best solutions for users to unlock phones without losing data. This service can be accessed and used under the promise that Android Device Manager is enabled on your Android device before being locked. But before you try this method, you need to note that your Android phone should run on Android 4.4 and above. And then, you can follow the guide on how to unlock any phone password without losing data.
Step 1. Visit Google Find My Device on your Mac/PC > Sign in with the Google account details that you also used on your locked Android phone.
Step 2. In the Android Device Manager interface, choose the device you want to unlock > Click Lock button > Enter a temporary password (no need to enter any recovery message) > Click Lock button again.
Step 3. If the process is successful, you will see a confirmation window with buttons: Ring, Lock and Erase.
Step 4. Enter the temporary password you just set when a password field appears on your Samsung phone > Go to lock screen settings on your Samsung phone > Disable the temporary password you set before.
2. How to Unlock Forgotten Pattern Without Losing Data
Pattern lock is also a common screen lock used by Android users. So how to unlock the pattern lock without losing data? If your phone is still running Android 4.4 or lower, your Google account can also help you solve how to unlock phone if forgot password without losing data. It has a feature called Forgot Pattern, which can allow users to get into a locked Android phone. However, using the Forgot Pattern feature to unlock phone passwords required you to remember the Google account credentials logged into your phone. Here is how to unlock forgotten pattern without losing data in this way.
Step 1. Enter the wrong password multiple times until you see the Forgot Pattern > Tap Forgot Pattern.
Step 2. Enter your Google account details and tap Sign in. You should have full access to your phone now.
3. Unlock Samsung Phone Forgot Password Without Losing Data
If you are using a Samsung phone, how to unlock your phone when you forgot the password without losing data? Find My Mobile is a tool specially designed for Samsung users to unlock phone without losing data. As you need to use the Samsung account to use this tool, please check your Samsung account information first. Then, you can follow the guide below to see how to unlock Samsung phone forgot password without losing data.
Step 1. Go to the Find My Mobile official website. Enter your Samsung account to log in.
Step 2. Then select the device you want to unlock.
Step 3. Tap on the Unlock option and enter the password of your Samsung account.
Click Unlock Option
Click Unlock Option
Step 4. Wait for the unlocking process to complete.
4. How to Unlock Samsung Phone Without Losing Data in Safe Mode
If you still don’t know how to unlock Samsung phone forgot password without losing data, booting your locked phone into safe mode is the last solution for you. If you are using the third-party lock screen software, then you can definitely try this way. Turning on and turning off safe mode can solve the problems caused by the third-party app. And below is the step-by-step guide on how to unlock any phone password without losing data.
Step 1. Long press the Power button for a few seconds.
Step 2. Tap on the Power off and click OK to reboot your phone into safe mode.
Step 3. Then you can disable all third-party applications, including the third-party lock screen software.
Step 4. Get out of safe mode to restart your phone.
Boot Locked Phone into Safe Mode
5. How to Unlock Samsung Phone Without Password in 1 Click
If all the methods above cannot solve your problem, DroidKit would be a good choice to unlock your Samsung without passwords. Supporting all Samsung models with Android 6 – 15, DroidKit – Android Phone Toolkit is an efficient way to unlock Samsung phones without a password in easy steps. This reliable tool supports removing all types of screen locks on Samsung phones. Whether your screen is locked with a password, pattern, PIN, or fingerprint, it easily unlocks them in minutes. With a few clicks, DroidKit can help you regain access to your Samsung without root. It can also back up data from a locked phone in 1 click to avoid data loss.
Key Features:
  • Supports unlocking a forgotten pattern lock, password, PIN, fingerprint ID, or face recognition on Samsung.
  • 20,000+ models of Android phones & tablets supported, including Samsung, LG, Huawei, Google, HTC, etc.
  • The easy unlocking process is suitable for everyone to follow. No technical knowledge is required.
  • Also helps you recover data with/without backup, fix Android system issues, bypass FRP lock, and more.
How to Unlock Samsung Phone Without Password with DroidKit:
Step 1. Launch the software and click Screen Unlocker.
Choose Screen Unlocker
Step 2. Connect your Android phone via a USB cable and Start to unlock.
Connect your Locked Phone
Step 3. After the connection, DroidKit will prepare the configuration file for you. Once finished, tap on Remove Now button to continue.
Click Remove Now Button
Step 4. DroidKit will detect your device brand. Here we take Samsung as an example, you can follow the on-screen instructions to remove Samsung’s password.
Finish Settings on Samsung
Remove Password on Samsung
Step 5. After that, DroidKit will start the unlocking process immediately. Wait a minute, you will see Screen Lock Removal Completed page below.
Lock Screen Removal Completed
Video Tutorial: Unlock Samsung Forgot Password in Minutes
You can also follow the video below to learn how to unlock Samsung phone forgot password. These methods can help you unlock all Android screen locks, including pattern, PIN, password, etc.
FAQs about Unlocking Samsung Password Without Losing Data
Q1: What is the secret/master code to unlock an Android phone password without losing data?
There is no universal secret code to unlock an Android phone password without data loss. Some secret codes, like *2767*3855# and *#*#7780#*#* can help by performing a factory reset, which removes the screen lock but erases all data. However, you can use DroidKit to back up all your data before factory reset to avoid data loss.
Q2: Can we unlock a phone without a password without losing data?
Yes, you can unlock your phone without losing data if your device offers password recovery options, like “Forgot Password,” or by using a linked account to reset the password. However, you need to remember the linked Samsung or Google account credentials.
That’s all about how to unlock any phone password without losing data. Just as you can see, DroidKit – Android Phone Unlocker can help you 1-click unlock any Android phone screen lock, like passcode, pattern, PIN, fingerprint, Face ID, etc. in minutes. It supports backing up data from a locked Android phone, preventing data loss. So why not get DroidKit for free and try it?
