Wanna keep those photos full of memories without knowing how to transfer photos from Samsung to flash drive? Check this guide right now and gain the best method to meet your need.
With the continuous optimization of Samsung camera components, the photos taken by the camera are clearer and more colorful. But at the same time, the photos are becoming larger and larger, which will take up more storage space on the phone and your Samsung storage will be insufficient.
For the need to free up space, you may think about transferring photos to your computer, another phone, or an external memory device like a flash drive. Flash drive is a simple tool to save files, which can be used to make a backup for your photos, share photos with friends or family, or transfer photos from Samsung to another device. No matter what kind of demands you have, this guide can render you a great solution.
In order to release more storage space on your Samsung phone, you just need a way to transfer photos from your Samsung phone to a USB/Flash Drive. So, here comes DroidKit – Android Solution Toolkit, which can help you manage your data on your Android phone, including transferring photos from Samsung to a flash drive. Don’t worry, all the data is encrypted throughout the process. There are the main features of DroidKit:
How Do I Transfer Photos from Samsung phone to Memory Stick? Follow the detailed steps below to make it.
Step 1. Free download the latest version of DroidKit and launch it on your computer > Plug the flash drive or USB into computer > Choose the Device Manager under Data Manager function and connect your Samsung phone to computer.
Step 2. Tap on the Export Content option. You can see all the types of data that you can save from your Samsung phone to your computer.
Choose Export Content
Step 4. Now you can preview and choose the Photos that you want to transfer > Click on the To PC button and choose your flash drive.
Choose Data You Want to Transfer
Step 5. Just wait for a moment, when the transferring process is completed you will see the interface below.
Data Transferred Successfully
If your Samsung phone is Android OS Version 11.0, you can transfer photos from your Samsung phone to a USB stick directly by following the steps below:
Step 1. Insert your USB stick into the multipurpose jack on your Samsung phone > Find and open My Files app on your phone.
Step 2. Select Photos/images Category or search for the file under Internal Storage.
Select Images Category
Step 3. Long press the photo to select > Tap on Move or Copy.
Step 4. Back to your My files main screen > Select USB Storage 1 > Tap on Move here or Copy here.
In order to transfer photos from Samsung to flash drive, you can seek for help from AnyDroid, a professional and useful Android data management tool. No worry about the burdensome search for the photo files in numerous folders, by utilizing AnyDroid, you can have the best solution on how to transfer photos from Samsung to flash drive with these features:
Now get AnyDroid which is available both for Mac and PC and follow these steps below to know how to transfer photos from Samsung to flash drive.
Step 1. Launch AnyDroid on your computer > Connect your Samsung with your computer via USB cable > Plug the flash drive into computer > Choose Device Manager and Export Content.
Connect Android Phone to Computer
Step 2. Choose the folder in your flash drive and select the photos you want to transfer > Click Settings to set the export path > Choose Photos under Device Manager Mode.
Step 3. Select the photos you’d like to transfer > Tap the To PC button to get photos transferred to your flash drive.
Select Photos to Transfer to PC
As you can see in this guide, when you have no idea about how to transfer photos from Samsung to flash drive, DroidKit can always be the one to help you perfectly solve the problem. You can use it at any time to manage all your Android data like contacts, texts, musics, etc. Download it now and enjoy your free trial!
