How to share your iTunes library with your families or friends with ease? In this guide, we will show you several ways to share iTunes Library between users without data loss.
In this post, you’re going to know all the available methods you can try to share iTunes Library with your families or friends. No matter you are using a Mac or Windows PC, you can find solutions in this guide.
This guide includes methods as follow:
So if you want to share your beefy iTunes library with others, you’ll love this guide. Let’s dive right in.
On a local network, you can set up to 5 computers to share iTunes libraries with each other. If a shared computer is turned on and iTunes is open, you can play that computer’s shared items on other computers in the network. Here are the detailed steps of sharing the iTunes library on a local PC network.
Step 1. Open your iTunes on your computer, click Edit > Preferences, then click Sharing.
Step 2. Tick “Share my library on my local network”.
Step 3. Select the items you want to share with your friends or families. Here you can also tick “Share the entire library”.
Step 4. To require anyone to enter a password before they can see your shared items, select “Require password,” and enter a password.
How to Share iTunes Library with iTunes
Apart from sharing on a local network, another choice you can try is to share the iTunes library with Home Sharing, but there are some limitations:
Turn on Home Sharing
Steps to share iTunes library with Home Sharing:
If you failed to share your iTunes library with the above methods, there’s another way you could try, which is using a third-party tool to manually transfer your iTunes library to your friends’ or family members’ iPhone. Here we recommend an all-in-one tool – AnyTrans.
AnyTrans is an iOS extractor and transfer that is capable of sharing iTunes library from between iPhone users. You won’t need to use the same Apple ID on both iPhones or connect to the same home network.
Step 1. Download AnyTrans and run it > Connect the iPhone (your mother’s iPhone or your friend’s iPhone) to your computer.
Access iTunes Library on Your Computer
Step 2. Choose “iTunes Library” mode at the left panel of AnyTrans. Select the songs or movies to share with any iPhone by clicking the “To Device” button on the upper right corner.
Manage iTunes Library with AnyTrans
With AnyTrans, you can directly share content from one iPhone to another, and to computer.
See Also: How to Add Music to iPhone with/without iTunes >
What if you find out the songs lost after sharing iTunes library with your friends or families? Don’t worry, all you need is a trouble-free iPhone data recovery – PhoneRescue to recover what you want.
Sharing iTunes library with AnyTrans is easy and straightforward, and you can also share messages, contacts, notes, photos and more from one iPhone to another with it.
