Can I export a text conversation from my iPhone? The answer is TES. If you want to print messages (SMS, iMessages) from your iPhone or Android, just keep reading to get 4 ways for printing text messages and event WhatsApp chats.
Free download AnyTrans to enrich your Apple life, managing iPhone/iPad/iPod, even iTunes/iCloud content, printing messages, and WhatsApp messages from iPhone.
Text messages on your iPhone or Android are sometimes very valuable and important. You may want to print them out for one of those reasons:
How to print text messages from your iPhone? You can try to save iPhone text messages to screenshots and then print them as photos by using AirPrint printer, or Email the text messages to your email account and print them from email. In this guide, we will show you 4 ways to print text messages as well as WhatsApp chats from both iPhone and Android devices, if you like a new & 1-click way to print All messages, please go to Part 1, or to print a single or several pieces of texts you can try Part 2 or 3.
Is there a way to print an entire text conversation? YES, there is. AnyTrans is an iPhone data manager that you can export text messages from iPhone to computer, or directly print out all your selected message conversations with a simple click. It works well both on PC and Mac. There is what AnyTrans can do for you:
Step 1: Free Download AnyTrans. Run & install it. Then connect your iPhone to the computer with its USB cable.
Step 2: In Device Manager, choose Messages.
Choose Messages Tab
Note: If you find nothing after clicking Messages, this means you haven’t created the backup on your iPhone and AnyTrans can’t read your iPhone’s messages. You just need to create one. In the same window, you will find a note at the bottom, says: “You Haven’t backed up your device on this computer. Please click the button below to create a full backup. Back Up Now”. Just click on “Back Up Now”, then you will see all the messages on your iPhone after this process finishes.
Step 3: Select the message conversations you want to print > Click Print.
Send Messages to PC or Print iPhone Messages
Step 4: Confirm the messages that you need to print > Then Click Print Now.
You can also view the video to see how to print text messages from iPhone using AnyTrans:
AnyTrans also helps backup and export WhatsApp (as well as Line and Viber messages) to the computer in HTML file, and you can print them from your computer too. Firstly, Download AnyTrans and run it.
Step 1. Choose Social Messages Manager, and click WhatsApp. You will see three options: Backup, Restore, and iPhone to iPhone. Click on Backup to make a backup of your WhatsApp messages on the computer.
Select WhatsApp to Back Up
Step 2. Choose whether you want to set a backup password and click Next.
Enable Backup Encryption and Continue
Step 3. AnyTrans will start backup your WhatsApp messages to the computer. When it’s done, click View to see them on your computer, and now you can print them from your computer.
You can copy the text messages one by one and past them to your email content, or add the attachments of the screenshots of your text messages. Then send yourself an email, and go to your computer, and find the email you just sent and then print the messages you need. Follow the steps below to know how to print text messages from iPhone with Email:
If you have an AirPrint-enabled printer, you can open the messages you need to print and click the Share button which may look like an arrow. Then choose the Print option to print now.
Print Messages from Email
If you only have a few text messages to print, you can try to take screenshots of the message conversations and save the photo to your Photos app on iPhone or Android.
On an iPhone, you can try Apple’s AirPrint service, it’s easy to print full-quality photos and documents from your iPhone without having to install additional software (drivers).
Instructions on how to print iPhone text messages with screenshots use AirPrint:
Print Text Messages with Screenshot
If you don’t have an AirPrint-Enabled printer, you can also transfer those screenshots photos to computer and print them.
Or you can try Google Cloud Print, which will help you print photos on your phone without connecting to a computer.
For Android users, you can use AnyDroid to export text messages from Android to the computer, and then print them out. AnyDroid is an Android data manager with it you can easily transfer, backup, and manage messages on Android phones. Here is how to use it to help you print text messages from Android:
Step 1. You can download AnyDroid on your computer. And connect your phone to the computer via Wi-Fi or USB cable.
Step 2. Choose Device Manager and select Messages.
How to Transfer Text Messages from Samsung to Computer – Step 2
Step 3. Select messages you want to print and click the Send to PC or Mac button on the top right corner.
How to Transfer Text Messages from Samsung to Computer – Step 3
As you can see, it is enough easy to export and print text messages from iPhone with AnyTrans or print out messages from Android with AnyDroid, you can make it in a few minutes. Except for exporting and printing text messages from iPhone, they also can help you export other iOS content, like Contacts, Photos, Music, Videos, Notes, etc. In the end, welcome any comment here to share your experience on printing out messages with AnyTrans. And now free download AnyTrans on your PC or Mac and start to export iPhone messages.
