How to Print Calendar from iPad
Do you want to learn how to print calendar from iPad? In this post, we have covered four ways to help you print a calendar from the iPad without much hassle.
Author Avatar Joy Taylor Last Updated: Jan. 18, 2022
There’s no doubt that calendar helps you to keep on track with your day-to-day tasks. Indeed, there are so many things going on in our personal and work like and sometimes, it’s hard for anyone to keep up. There are some users who may want to print calendars from the iPad but don’t know how to do this. Well, there are several solutions to do your job. In this post, we are going to walk you through four different ways to print calendar from iPad. So, spare some time to read the guide below and select the method that meets your unique requirements.
Also Read: Fix iPhone/iPad Calendar Not Syncing >
Part 1: How to Print Calendar from iPad with iCloud.com
We all know that backing up an iOS device to iCloud would help in getting iOS content from iCloud.com with ease. Therefore, you can print the calendar from the iPad through iCloud online. By syncing your calendar from iPad to iCloud, you can print calendars from the iPad using iCloud.
Step 1: To start with, you have to sync your iPad to iCloud. To do so, go to the device’s “Settings”>” [Your Name]”>”iCloud”. Here, switch the “Calendar” option on.
Print iPad Calendar Using iCloud – Step 1
Step 2: Open iCloud.com your system’s browser and enter your Apple ID and passcode for sign-in. On the iCloud panel, go to the “Calendar” app to view all schedules and events.
Step 3: Choose the month that you would like to print. Then, capture a screenshot of that selected month. To do so, hit the window key + PrtScr key at the same time and save it.
Print iPad Calendar Using iCloud - Step 3
Print iPad Calendar Using iCloud – Step 3
Step 4: Open the captured screenshot and click on the “Print” option from the “File” drop-down menu and that’s it.
Part 2: Print iPad Calendar by Enabling Calendar Sync on Mac
The second way to print the calendar from the iPad is by enabling calendar sync on Mac. Below is the quick guide to help you learn how to print calendar from iPad using this method:
Step 1: To commence the process, you need to log-in with the same Apple ID and passcode you are using on your iDevice on the iCloud of your system.
Step 2: After the successful log-in, sync your iDevice calendar on your Mac.
In order to sync the calendar on your iPad, open settings and tap on your name and go to “iCloud to enable the “Calendar” option. To sync on your Mac, open your system preferences, enter into your iCloud settings and then, enable the “Calendar” option.
Step 3: Once enabling sync on both the devices, you will be able to see your iPad calendar on Mac. Click on the “Print” option from the “File” drop-down menu to print the calendar from your iPad.
Print iPad Calendar Using Enabling Calendar Sync on Mac
Part 3: Print iPad Calendar with AnyTrans for Windows PC & Mac
As a reliable iOS content manager, AnyTrans comes in handy for transferring and managing iOS content such as calendars, photos, notes, contacts, and a lot more. With the help of this program, you can export all your iPad/iPhone calendars to your computer so as to print them via a printer. The great thing is that AnyTrans provides support for both Windows and Mac, offering more flexibility to print calendars from your iPad.
To learn how to use AnyTrans to print an iPad calendar, get it from its official site on your computer and then follow the below steps:
Step 1: Once installing AnyTrans successfully, run it and connect your iPad to the computer with the help of a digital cable. Let the software detects your connected device.
Step 2: Once the software detects your device, click on the “three-dot icon/More” option from the main interface of the software.
Connect iPhone with AnyTrans Mac Version
Step 3: Select the “Calendar” option. Now, you can select the calendars that you would like to print. Hit on the “To Computer” button and select the export format also. In a while, the software will export the selected ones to the computer and then you can print them via your printer.
Transfer Calendars from iPhone to Computer
Part 4: Print iPad Calendar Using AirPrint
To print calendars from the iPad, you can also take advantage of the AirPrint feature available on all iOS devices. This will help you to print data without the need for connecting the iPad to the printer using hardware. The feature comes in handy when it comes to printing your calendar from the iPad.
Before you proceed with the method, ensure that your printer provides support for AirPrint and your iPad and printer are connected to the same internet connection.
Step 1: Open the calendar and select the month that you would like to print.
Step 2: After that, click on the “Print” that you will most probably find in the “Share” option.
Step 3: Now, you will get a list of several printer options and you need to click on the one that says “AirPrint enabled Printer” and tap on the “Print”.
That’s how to print calendars from an iPad. As you can see that there are so many ways out there to help you print calendars from the iPad. Now, it’s your time to pick the one that suits you the most. However, we recommend you give AnyTrans a try as it makes the printing iPad calendars job easy and quick. On top of all, it has several other features to transfer and manage your iOS content effectively.
