How to Power On/Off iPhone XS (Max)
Users who don’t know how to Power off iPhone XS Max or power on iPhone XS can refer to this guide. Here, we have mentioned how you can power off or on your iPhone XS with detailed steps.
Author Avatar Joy Taylor Last Updated: Apr. 22, 2022
iPhone XS (Max) is the latest iPhone model and every die-hard Apple fans wish to have it due to the amazing features that comes with it. If you got a new iPhone XS/XS Max, you must want to turn on it immediately. And turning on or turning off iPhone XS (Max) is quite simple. In this guide, we have discussed in detail how to turn on/off iPhone XS (Max). Head to have a check.
Part 1. How to Power off iPhone XS/XS Max
To shut down or switch off iPhone XS (Max), there are two ways and below we have mentioned both the ways in detail:
Method 1: Turn Off iPhone XS Max with Buttons:
Step 1. To commence the process, you have to press and hold down either volume up or down and the side button at the same time. Hold down both buttons until you don’t see the “Slide to Power off” slider on your iPhone screen.
Step 2. After that, you need to drag the power-off slider to switch off your iPhone.
Method 2: Turn Off iPhone XS Max from Settings:
Step 1. First of all, go to the “Settings” app on your iPhone and then, move to the “General” settings.
Step 2. After that, scroll down the screen to find the “Shut Down” option. Once able to find it, tap on it to begin the shutdown process.
Step 3. Now, “slide to power off” slider screen will appear on your iPhone screen. Drag the slider to turn it off.
Hence, using above-mentioned methods, you can power off iPhone XS Max. However, if you want to turn it back on then you can also do this in a simple way.
Part 2. How to Turn On iPhone XS/XS Max
To power on iPhone XS or iPhone XS Max, press and hold the Side button until you see the Apple logo on your iPhone screen.
Thus, now you know how to Power off iPhone XS Max and how to turn on iPhone XS Max. Must share this guide with your friends also who have latest iPhone XS Max. This guide can be helpful for them too.
