This post aims at telling you how to fix issues of can’t get into iTunes Store issues. Do keep reading and follow us to get iTunes Store sign in problem fixed.
It could be quite annoying that sometimes you can’t sign in to the iTunes store. When the iTunes sign is not working, you can’t download music, movies, or TV shows from iTunes. And actually, it happens more common than you think.
Although there are many reasons that might cause the issue of can’t sign in to the iTunes Store error, don’t worry. Here in this post, we summarized all possible solutions. Now follow us and fix the iTunes Store sign-in problem.
Can’t Sign into iTunes Store
There are four solutions in total, please try them one by one.
1 > Check Internet Connection
Internet connection is crucial for devices to offload and upload information from/to the Apple server. It is for sure that you can’t sign into iTunes Store without an Internet connection.
To check if your device is connected to the Internet, please try to open a website with a browser and see if it can connect to any website. If no, go to Settings > Cellular, make sure cellular is enabled for iTunes Store.
2 > Check the Date and Time
On your iPhone iPad iPod touch, go to Settings > General > Date & Time, on your Mac, go to System Preferences > Date & Time. If the date and time are wrong, set the correct date and time or turn on the option to set it automatically.
3 > Update Software to the Latest Version
If you have an older version of OS, please update it to the latest version. The latest version of OS might contain fixes for some bugs causing iTunes Store sign-in problems.
4 > Check System Status
Sometimes there could be interruptions in service in a specific country. Please search the Apple System Status page to check.
In some cases, users will meet Apple ID error messages when login in to iTunes, then you can refer to the solution for “Apple ID Hasn’t Been Used with the iTunes Store”.
Ringtones are one of the easiest things to customize in your iPhone. To get special ringtones, you can DIY with iTunes or purchase them in the iTunes library.
The sad news is that Apple has updated iTunes to focus on music, movies, TV shows, podcast, and audiobooks, and the Tones icon is now disappeared in iTunes 12.7, which means customizing ringtones is no longer supported in iTunes 12.7 or later version.
“Can we not pay for custom ringtones?” “Is there a tool that could help us custom special ringtones?” These are two questions we have frequently got recently. Sure, we can get free ringtones. What you need is AnyTrans.
AnyTrans is an excellent iOS data transfer and it could help people transfer music from computer to iPhone as 25s or 40s custom ringtones. Here are the reasons why you will like the program.
For detailed steps to custom ringtones for iPhone iPad after installing AnyTrans, please refer to How to Get Free Ringtones for iPhone iPad iPod touch >
Customize Ringtone Using AnyTrans
That’s all for how to fix can’t log in iTunes Store issues. Hopefully, you have already solved this problem. If you find this post helpful, please share it with others. By the way, if you need custom ringtones on your iPhone iPad, don’t forget to download AnyTrans.
