4 Ways to Fix iTunes Error 5000
iTunes error is a common problem for iOS users. It comes with no reason and no valid solutions. If you faced with iTunes error 5000 when using iTunes, keep reading this post, we have given some efficient solutions to help you to fix this problem.
joy Joy Taylor Last Updated: Sep. 10, 2020
When you use iTunes to sync music to your iPhone, iPad or iPod touch, you might see an alert message saying that your device “cannot be synced” or that iTunes can’t copy a specific song to your device. And the message might also have error numbers such as iTunes error 5000. So what should we do to fix this problem? Here we listed 4 ways to help you fix iTunes 5000.
Method 1. How to Fix iTunes Error 5000 Quickly
Whenever you’re facing iTunes syncing error like error 5000 or other errors, AnyFix – iOS system recovery & iTunes repair can get you out of the dilemma. It’s a software that is designed to fix various iOS/iPadOS/tvOS/iTunes issues in minutes. With AnyFix, you can solve iTunes installation/download/update, connection/backup/restore, and sync/CDB errors like iTunes error 5000, 13014. Besides, if any of your Apple devices got system problems, you can find a solution with it. You can follow the simple steps below to fix iTunes error now:
Step 1. Download AnyFix – iOS systems recovery and launch it.
Step 2. Choose iTunes Repair from the homepage.
Click iTunes Repair
Click iTunes Repair
Step 3. Select iTunes Sync/CDB Errors option and head to Fix Now.
Choose iTunes Sync/CDB Errors
Step 4. Connect your iOS device as below. Head to Fix Now button, AnyFix will start repairing immediately. Wait a minute, you will get the Repair Completed page. Open iTunes to check if the sync error get fixed.
Connect your iOS Device to Computer
Method 2. Update iTunes and iPhone
Make sure your iTunes is the latest version. Open up the options menu and check if your iTunes is the latest version. If not, please update it to the latest version. Please keep internet connection active during the updating process. Also make sure your iPhone is in the latest iOS version. Go to Setting > General > Software Update to check if your iPhone is the latest version. If not, please update iPhone to the latest version and try to sync music once again.
Method 3. Consolidate the Media Files in Your iTunes Library
The media files in your iTunes library might be stored in several locations. Consolidate your files to make sure that the content is stored in one location. This can correct permissions and simplify the syncing process.
Method 4. Check for Issues with Third-Party Security Software
Some third-party software, including security software, can interfere with the sync process between your computer and your device. Close the third-party security software and restart iTunes, then try to sync again.
Method 5. Identify the Songs that You Sync
In some cases, there might be an issue with specific songs that you’re trying to sync. To identify the songs:
  • See if the error message includes which songs are causing the issue.
  • Sync only a few songs at a time, adding more until the issue occurs again.
For issues with songs that you brought from the iTunes store, you can delete and then redownload them. You can also download them directly to your iPhone, iPad or iPod touch. You might have an issue with songs you copied from a CD or didn’t buy from the iTunes Store. In this case, delete them and then import them again from the original source.
Bonus Tip: Manage iOS Data without iTunes
As mentioned above, you might encounter iTunes error 5000 or other iTunes error when you try to sync music or other data through iTunes. In order to avoid iTunes error, you can use alternative software to help you manage iPhone, iPad or iPod touch data. Here we recommend AnyTrans. It is the best iTunes alternative, becomes the first choice of a number of users for its powerful features. Here is what AnyTrans enables you to do.
1. Manage your iTunes Library
With AnyTrans, you can transfer iTunes contents to both computer and iOS device. You can view all your iTunes contents on AnyTrans and just choose the data you want to transfer, click transfer button then could transfer it to computer or iOS device. Transferring iTunes contents to computer will not need you to connect device, while transferring iTunes contents to device need you to connect your iOS device to your PC/Mac.
2. Add Contents from Computer to iPhone
Once connecting your iPhone to computer, AnyTrans enables you to add contents in computer to your iPhone. Click Add Content button on the interface, and just choose the files you want to transfer and wait for the transferring process.
3. Transfer Contents from iPhone to Computer
With AnyTrans, you can also manage your iPhone contents with AnyTrans. Connect your iPhone to computer, wait for the file loading process and select the categories you want to transfer to your computer. Just three steps, you could easily transfer iPhone contents to computer.
Manage Files in AnyTrans
That’s all about fixing iTunes error 5000. Wish you could solve your problem by reading this post. As you can see, AnyFix – iOS system recovery is the best repair tool for iTunes errors. What’s more, in managing iOS data, AnyTrans is indeed a nice iTunes alternative. If you are interested in it, do remember to download and have a try.
joy
