If you see an alert error 45054 in iTunes and have on idea, read this article to get the detailed solutions of how to fix iTunes error 45054.
Almost all Apple users have installed iTunes on Windows or Mac, and make use of it with all your iOS devices. Undoubtedly, it is really handy and excellent software provided by Apple Company. While iTunes is not perfect, there occasionally arise a lot of issues like iTunes error 2006, iTunes error 21, and iTunes error 4013 etc. Here in this post, we focus on how to fix iTunes error 45054 on Windows and Mac without third-party software.
This infamous error – iTunes error 45054, which states that the computer could not complete iTunes Store’s request when files or folders that iTunes uses to download purchases are restricted. Why it happen, the reasons are varied, such as:
No matter for what reasons, you can try the following methods to see if one of them works for you.
Step 1. Quit iTunes (if it’s open).
Step 2. Go > Go to Folder. Input “/Users/Shared/adi” and press Go.
How to Fix iTunes Error 45054 – Step 2
Step 3. If you see the Shared folder exists, and you find the adi folder, drag the adi folder to the Trash and open iTunes to make a purchase.
How to Fix iTunes Error 45054 – Step 3
If you don’t see a Shared folder, you can try these steps: Run Terminal > Input sudo mkdir -p / Users/Shared/ and press Return > Input your Mac password and press Return > Type sudo chmod 1777 / Users/Shared in the Terminal window and press Return > Quit Terminal.
After opening Terminal, the next step requires you to enter commands in Terminal to modify permission settings. If you’re unfamiliar with Terminal and UNIX-like environments, be cautious. If you enter incorrect commands, you might lose data, or your system software might become unusable.
If you are a Windows user, here are the steps of how to fix iTunes error 45054 on Windows.
Step 1. Also, quit iTunes.
Step 2. Press the Windows key or Control (Ctrl) and Escape (Esc) keys on your keyboard.
Step 3. In the search box, type “ProgramData”, then press the Enter key.
Step 4. Make sure that the hidden files are visible, if not, you can follow steps below:
Windows 10: View > Hidden items.
Windows 8: View > Options > Show hidden files, folders, and drives.
Windows 7: Organize > Folder and search options > Show hidden files, folders, and drives.
Step 5. Open the Apple Computer folder, then the iTunes folder.
Step 6. Delete the SC Info folder and the adi folder.
Step 7. Restart your computer, then run iTunes again and try to make a purchase.
Also Read: How to Transfer Playlist from iTunes to iPhone >
AnyFix is an easy to use and professional tool to fix 200+ iTunes errors covering iTunes error 45054, iTunes error 10, iTunes error 3006, etc., and 130+ iOS/iPadOS/tvOS problems. It quickly scans your iTunes and finds the problem. Just click the Fix Now button, and you can get your iTunes back to normal. Now download AnyFix on your computer to fix iTunes error 45054 error.
Step 1. Open AnyFix and choose iTunes Repair to start.
AnyFix Main Screen
Step 2. Choose according to your iTunes error type. For iTunes 45054 you can try “Connection / Backup / Restore Errors”. Click on Fix Now to continue.
Choose the Second iTunes Repair Mode
Step 3. AnyFix will start to scan your iTunes and find the problem. Click on Fix Now and you may need to authorize AnyFix to fix iTunes.
Start to Repair
Step 4. AnyFix will show you the repair completed interface, you can go and check if your iTunes problem is solved.
Repair iTunes Completed Interface
When comes to syncing data from computer to iPhone, there is no doubt that the first method that comes to mind is using iTunes. However, using iTunes sometimes may lead to some bad occasions like erasing data on your iPhone or meeting some annoying errors. So, in this part, we recommend a powerful iTunes alternative – AnyTrans, which can help you manage and sync iOS data in a more convenient & safe way.
AnyTrans is a professional iOS data transfer tool applied for both PC and Mac computers. It has some outstanding features:
AnyTrans for iOS
That’s all for how to fix iTunes error 45054, after trying the methods mentioned above, if your question remains, you can go to the Apple Store and ask for Apple Specialist for help. By the way, if you have any other iPhone system issues, you can also try AnyFix.
Please enter a valid email address
