How to Fix iPhone Not Showing Up on PC/Mac
Sometimes, when you want to import your photos and videos to PC but your iPhone doesn’t show up on PC as it used to be. No worries. Here in this post, we will shou you some quick ways to fix iPhone not showing up on PC/Mac.
Author Avatar Joy Taylor Last Updated: Mar. 18, 2025
AnyTrans – Best Way to Access iPhone Data on PC/Mac
How to access iPhone files, if iPhone doesn’t show up on PC? Just free download AnyTrans and connect your iPhone to it. With this complete iOS data manager, you can easily view and manage all iPhone data on your computer, including photos, messages, videos, etc. You can even transfer them to computer via this tool. Supports all iPhone models running iOS 5 and above, including iPhone 16 and iOS 18.
We often connect our iPhone to it to import photos and videos in camera roll, but it happens sometimes that iPhone won’t show up on pc. This problem usually takes place on Windows 10/8/7/XP computer and happens occasionally on Mac.
Then, why iPhone connect to PC not showing? How to fix iPhone not showing up on PC? Next, we will analyze the reasons for this problem and show you some potential solutions to solve this problem.
Why Is My iPhone Not Showing Up on My Computer
Why iPhone connected to pc but not showing (Windows PC/Mac)? There are most common reasons:
  • The most common reason is that the USB cable not working or even broken but you don’t aware of it. Or the USB port on your iPhone/computer not working.
  • If your computer or iPhone got software issues, you also can’t see your iPhone on computer.
  • Also, the Apple USB driver issue or other unknown reasons can cause PC not to recognize iPhone.
If you encounter the iPhone not showing on PC problem, you can follow the 7 common tips below to fix this issue.
Tip 1. First, make sure your iPhone is unlocked and on the Home screen.
Tip 2. Make sure your Windows and iPhone are running the latest iOS. If you’re using iTunes, make sure you have the latest version.
Tip 3. Restart your iPhone and PC.
Tip 4. Make sure you connect your iPhone with the original Apple USB cable and try a different USB port on your computer.
Tip 5. Unplug and plug in your iPhone two or three times.
Tip 6. On your PC, after connecting with your iPhone, you’ll see a message on iPhone asking if you want to trust the computer. Unlock your device and tap on Trust. Sometimes, you may need to repeat a few times.
Tip 7. Update iPhone drivers
Outdated iPhone Driver may also cause iPhone not showing up on PC. Therefore, before you connect your iPhone to the computer, please update iPhone drivers first. And here is how to fix iPhone not appearing on PC in this way.
1. Open Control Panel > Hardware and Sound >
2. Look for Apple iPhone under the “Unspecified” section > Right-click on it, choose “Properties”.
3. Click the Hardware tab> Choose change settings button > Click on the Driver tab and Update Driver.
4. Then Browse my computer for driver software.
5. Now navigate to C:\Program Files\Common Files\Apple\Mobile Device Support\Drivers and click Ok, then Next.
Try Driver Easy to Recognize iPhone
If there is no updating option for you or no such driver at all, you can try Driver Easy to help you with it. Driver Easy will automatically recognize your system and find the correct drivers for it. You can update your drivers automatically with either the FREE or the Pro version of Driver Easy. To connect iPhone to the computer successfully:
Update All Available Drivers on Computer
1. Download and install Driver Easy.
2. Run Driver Easy and click the Scan Now button. Driver Easy will then scan your computer and detect any problem drivers.
3. Click the Update button next to the flagged xxx driver to automatically download the correct version of that driver (you can do this with the FREE version), then manually install it. Or click Update All to automatically download and install the correct version of all the drivers that are missing or out of date on your system. (This requires the Pro version).
4. Restart your computer to check if iPhone appears on the computer.
How to Fix iPhone Not Showing Up on Mac
In addition to Windows PC, some users also complain iPhone not showing in my computer (Mac). So here we will also talk about how to fix iPhone not showing up when plugged into computer (Mac).
View iPhone with USB Device Tree:
1. Connect your iPhone and make sure that it’s unlocked and on the Home screen.
2. On your Mac, hold down the Option key > Click the Apple menu > Choose System Information or System Report.
3. From the left list, select USB.
4. If you see your iPhone under USB Device Tree, get the latest macOS or install the latest updates. If you not, please contact Apple Support.
View Your Connected iPhone with the Finder App:
Starting with macOS Catalina, your devices appear in the sidebar of the Finder windows. Open the Finder and click your device’s name to select it.
View Connected iPhone with the Finder on Mac
Also, starting with macOS Catalina, you can sync iPhone/iPad with the Finder is similar to syncing with iTunes.
Best Way to View and Transfer iPhone Data to PC/Mac in 1 Click
If you can’t fix iPhone not showing up on PC with the above methods, then here is an alternative way that you can easily view and sync iPhone data with computer. This is a better way to manage all your iPhone data on the computer, which is AnyTrans – iPhone Data Manager. It is full-way iOS file transfer and management tool, can help you transfer data from iPhone to computer, iPhone to iPhone, and Android to iPhone. And you can even use this tool to manage iTunes and iCloud contents. AnyTrans works well on Windows PC and Mac. You can learn more about it below.
  • Transfer all data, like photos, music, messages, etc. to computer.
  • Transfer data in 1 click. Only take 3 minutes to transfer 1000 files.
  • Manage iTunes and iCloud data on a computer with ease.
  • Supports all iPhone models and iOS versions.
Download for Win100% Clean & Safe
Download for Mac100% Clean & Safe
Here are the simple steps of transferring & managing pictures on iPhone with AnyTrans.
Step 1. Free download, install, and launch AnyTrans on your computer, and connect your iPhone > When AnyTrans has detected your iPhone, you will see the main interface shows below > Select Photos.
Choose Photos Category
Step 2. View your iPhone photos, like Places, People, Photo Videos, etc in My Photos, or click Albums with photos.
View All Photos on Computer
Step 3. Then select and export pictures to your computer by clicking To PC button on the upper right corner. You can also transfer the pictures to iCloud or to another iPhone device by click More.
Select the Photos and Send to Computer
Fix iPhone Not Showing Up on PC without Data Loss
If the above methods didn’t work, maybe the Apple iPhone not showing up on PC issue isn’t caused by hardware-related issues. Then you need to consider the system errors. Here we recommend you try AnyFix – iOS System Recovery, which is designed to fix 150+ iOS/iPadOS/tvOS problems, like iPhone not showing on PC, iPhone frozen, computer not recognizing iPhone, iPhone/iPad disabled connect to iTunes, etc. It offers 3 repair modes for different system fixing needs and guarantees a high success rate. Most importantly, you can even use it to fix system without any data loss.
AnyFix can fix system issues on all iPhone and iPad models. And it even supports iOS 18. Just free download and install AnyFix on your Windows PC or Mac. Then follow the steps below to fix iPhone not showing up on PC.
Step 1. After launching it on the computer, you will see the interface as below. Click System Repair and continue.
AnyFix System Repair Option
Step 2.Now, AnyFix will start to detect your iOS device. After completion, you will see the below interface. Click the Start Now button.
AnyFix System Repair Device Bug
Step 3. Now, what you have to do is select a repair mode. Choose the Standard Repair option, which will fix issues without data loss.
AnyFix Standard Repair
Step 4. AnyFix will give you the firmware of your iOS device. Click the Download button to download your device’s firmware package.
Step 5.  After the firmware package for your iOS device is downloaded successfully, you will see the below interface. Click the Start Standard Repair button.
Step 6. Wait a while and when the recovery process is completed, you will see the completed page.
System Repair Completed
That’s all possible methods for you to fix iPhone not showing up on PC. If you failed with the common tips, don’t forget to free download AnyFix to have a try. And you can also use AnyTrans to transfer data from iPhone to the computer. All iOS data like photos, ringtones, notes, contacts, etc, are supported. What’s more, AnyTrans is the best iPhone data management tool for you to export, import, and delete iPhone data anywhere you like. Explore more about AnyTrans now! >
