How to Fix: iMessages Not Syncing Between Mac and iPhone
In some cases, iMessages won’t sync between your iPhone and Mac after updating to iOS 16, or the latest iOS 17, you may wonder how to fix it. Read this post to get 6 practical and effective solutions to fix this issue quickly.
Author Avatar Joy Taylor Last Updated: Oct. 12, 2023
For some reason my iMessage just started not syncing to my MacBook Air. I can ‘send’ iMessages but not receive on my MacBook Air.
        ——A User from Apple Community
With iMessage enabled on your iPhone, iPad, and Mac that share the same Apple ID, you can reach the same iMessages threads on both your iDevice and Mac. But you may notice that some iPhone messages not sync with Mac after updating to the latest iOS. In fact, you can see a lot of discussion about iMessage/Message problems in the Apple community, and most Apple users will encounter.
In this article, we are going to show you some possible fixes to solve the problem of iMessage not syncing on the Mac issue. Applied to all iPhone and Mac models, including the latest iPhone 15 and MacBook. Here we present you with 6 possible solutions to fix the iMessage not syncing between your Mac and iPhone problem.
iMessage Not Syncing Between Mac and iPhone
You May Like: How to Fix Pictures Not Importing from your iPhone to Mac >
Solution 1. Turn Off iMessage and Turn On It Again
How do I sync messages from my Mac to my iPhone? The first thing you should do when faced with this problem is try to turn off iMessage on both the Mac and the iPhone and then turn it back on.
  1. On your iPhone: Go to Settings > Messages > Toggle off iMessage > Wait a few seconds and turn it back on.
  2. On your Mac: Open the Messages app and click on Preferences > Choose Accounts> Click Sign Out > Wait a few seconds then sign back in.
  3. After the process completes, enable iMessage on both Mac and iPhone, you can check if the iMessages sync properly.
Enable iMessage on iPhone
Further Reading: How to Recover iMessage without Backup >
Solution 2. Check iMessage Settings on iPhone
Make sure you have activated all email addresses you want to use with iMessage:
  1. On your iPhone or iPad, go to Settings > Tap on Messages.
  2. Choose Send & Receive.
  3. Under “YOU CAN BE REACHED BY IMESSAGE AT”, make sure the phone number or email address is checked.
    How to Fix iMessage Not Syncing with Mac
Solution 3. Check iMessage Settings on Mac
  1. Open the Messages app on your Mac > Click “Messages” in the top menu.
  2. Click “preferences > Choose “Accounts”.
  3. Under the “You can be reached for messages at” section, make sure the phone number and Apple ID match the settings on your iPhone.
You May Like: How to Transfer Text Messages from iPhone to Computer >
Solution 4. Reliable Way to Sync iMessages Between iPhone and Mac
If the above methods could not help you fix iMessage not syncing between iPhone and Mac problem. You can manually transfer messages from your iPhone or iPad to your computer with an iPhone transfer tool named AnyTrans. It is a one-stop iPhone data manager that enables you to transfer iPhone Messages to PC/Mac in a Readable Format very easily [iOS 17 supported].
AnyTrans – iPhone Messages Transfer
AnyTrans also supports transferring photos, videos, music, contacts, notes, call history, and more, from iPhone to computer and vice versa, or between iPhones.
Step 1. Free download AnyTrans on your computer. Click on the messages.
Connect iPhone with AnyTrans Mac Version
Step 2. Preview and select the messages that you want to send to Mac. After being transferred successfully, you can view all iPhone messages on your Mac.
Alternative Way to Get iPhone Messages to Mac
Solution 5. Confirm the Mobile Phone Number with Apple ID
  1. Go to appleid.apple.com and log in with your Apple ID and password
  2. Under “Account” make sure you are reachable at the correct phone numbers and email addresses.
    How to Fix iPhone iMessage Not Syncing with Mac
Solution 6. Log in with the same Apple ID
On your Mac make sure you log in with the same Apple ID as you used on the iPhone:
  1. Open the “Messages” app > Go to “Preferences”.
  2. Click on the “Accounts” button > Click Enable this account.
  3. Select the email address you have registered with the Apple ID.
Further Reading: How to Fix Apple ID Locked for Security Reasons >
Solution 7. Using the Device that is not Syncing to Send out Messages
Sometimes, it is because one of your devices may only be delayed during the update, so using that device can also trigger a message update. The following steps are how to do that:
  1. Check which of your devices is not updated correctly.
  2. If it’s your iPhone, try using your iPhone to send a message, if it’s your Mac, use your Mac to send a message.
  3. After the message is sent, this usually prompts the device to start updating the message so that iMessage is properly synchronized on all devices.
That’s all about how to fix the message not syncing between iPhone and Mac. The above methods also can be used to fix the message sync issues, like iMessage on Mac not updating, iMessage not working on Mac, etc. If you have any other advice on solving the iPhone messages not syncing problem, please share it in the comment section below. At the same time, don’t forget to download AnyTrans to give it a try.
