If your iPhone stuck on the “Verifying Update” screen when downloading new iOS, including the latest iOS 18, read on to learn some potential methods to fix it.
With the launch of iOS 18, many people want to update to the latest iOS version. You may encounter some problems, when downloading a new iOS on your iPhone over the air (directly in Settings). For example, you will see the “Verifying Update…” screen. Generally, it takes a few minutes to finish the verifying procedure, and you will be able to download the iOS update.
iOS Unable to Verify Update
But some people may accidentally get stuck on verifying update page for endless hours or get stuck on software update failure. Why is my iPhone stuck on verifying update iOS 18? What do I do if my iPhone is stuck on verifying update? Here in this post, we test and list some methods you can try to get out of this iPhone verifying update problem. Now follow us to have a try.
Verifying updated software is a necessary process to update iPhone. If you are stuck on this process and takes more than 1 hour, there are some glitches on your iPhone. And, iPhone verifying update takes several hours usually due to an unstable internet connection, low iPhone storage, software glitches, etc.
With all that said, we will show you what to do if my iPhone is stuck on verifying update as below.
Before taking some measures to update iOS or fix iPhone stuck on verifying update, you can try to lock and wake your iPhone first.
After that, try to update your iPhone again and check if it works. If not, go on with the next solutions.
Verifying the Update issue is quite normal when updating an old iPhone to the newest version of iOS. Using AnyFix to update is the fastest way to get you out of the verifying stuck. In just 3 steps, your iPhone can be updated without effort.
The following steps will lead the way to fix the “iPhone stuck on verifying update iOS 18” issue without data loss.
Step 1. Launch AnyFix on your computer > connect your iPhone to the computer and then choose Upgrade/Downgrade iOS mode.
AnyFix Upgrade/Downgrade iOS Option
Step 2. Choose the 1 click to update iOS/iPadOS > Tap on Start Now to go on.
AnyFix Upgrade iOS
Step 3. Choose the suitable iOS system file to download > Click on the Upgrade to update the iPhone.
Choose the Latest iOS Version to Update
Step 4. Minutes later, you can see this page on your computer screen.
Upgrade Completed
If the above solutions not working, you can try an alternative way to upgrade to a new iOS update: upgrade with iTunes on your PC or upgrade with Finder on your Mac.
Update to iOS 15 with Finder on Mac
To reset network settings on your iPhone:
If Reset Network Settings is not working, you can also choose Reset All Settings.
If the above methods don’t help you out of the verifying update trouble on your iPhone, you can use AnyFix to repair iOS system quickly and safely. It’s good at repairing 150+ iOS system issues such as iPhone update failure, iPhone boot loop, iPhone black screen and more. To repair your iPhone stuck on verifying update issues, you can follow the steps below:
Step 1. Launch AnyFix and choose System Repair.
AnyFix System Repair Option
Step 2. Choose Update Issues and click Start Now.
AnyFix System Repair Update Issues
Step 3. Choose Standard Mode. It will not cause data loss.
AnyFix Standard Repair
Step 4. Follow the instructions to finish repairing iOS with AnyFix.
Repair Is Completed
After repairing, your iPhone will upgrade to the latest version it supports and you can use it normally.
This article introduces several ways to solve the “iPhone Stuck on Verifying Update” problem. Among them, we sincerely recommend you repair or update your iPhone with AnyFix. It’s easy to use and trusted by worldwide Apple users. Download it and start fixing your phone now!
