iCloud backup failed on your iPhone? Well, don’t worry. This article is going to proffer you some useful methods to help you out of this problem. Check it out now!
For iPhone users, backup is an important part of keeping our data safe. However, there are some occasions that you suddenly find out that iCloud backup is not working. This can be caused by amounts of reasons. In this guide, you will be able to know not only the reason why iCloud Backup Failed but also the solution to this problem!
The first thing you should do is check whether you have changed the iCloud settings on your iPhone. This may lead to the error of unsuccessful iCloud backup.
Open Settings app on your iPhone > Tap your Apple ID > iCloud > Scroll down and tap iCloud Backup > Toggle on iCloud Backup > Click “Back Up Now” to backup your iPhone.
How to Fix iCloud Backup Failed – Check iCloud Settings
If the Back Up Now button is grey out, there might be something wrong with your network connection. You should check your Wi-Fi connection or network restriction.
If you receive the messages on your iPhone saying iPhone Backup Failed because you do not have enough space in iCloud, you should free up space by following the below tips:
Go to Settings app > Tap your Apple ID > iCloud > Manage Storage > Buy More Storage.
Go to Settings app > Tap your Apple ID > iCloud > Manage Storage > Backups > Tap your current device > Turn off the apps you don’t want to back up.
If after checking that the iCloud space is sufficient, but the iCloud backup failed error still occurs, then you can check the WiFi internet connection, whether it is unstable or unavailable.
If the aforementioned methods don’t solve your problem, you should give a try to the most common and easy troubleshooting method – restart your iPhone:
Then you can try to back up your iPhone, and check whether the issue still persists.
To clear any possible problems in your network connection, you can try to reset network setting in your iPhone by following the below step:
Go to Settings app > Tap General > Tap “Reset Network Settings”.
How to Fix iCloud Backup Failed – Reset Network Settings
If you have set your iPhone to back up automatically, to proceed the backup process, you have to make sure that your iPhone is locked.
Go to Settings app > Tap the Display & Brightness > Tap “Auto-Lock” > Check a time period except “Never”.
How to Fix iPhone iCloud Backup not Working – Lock iPhone Screen
If you all the above methods are worthless for you to fix this iCloud backup failed issue, then you can try to back up your iPhone manually to keep your data safe. In this case, there are some great softwares for you to back up data. Here we consider that AnyTrans can be a perfect match for you to back up data on iPhone directly with these features:
Download AnyTrans now and follow the below step to back up your iPhone.
Launch AnyTrans on your PC/Mac > Choose Backup Manager in the left menu > Click on Back Up Now > It shall start to back up your iPhone to computer on regular.
Back up iPhone via AnyTrans
That’s all the 7 methods on how to fix iPhone iCloud backup not working issue. Hope these tips can help you get out of this troublesome problem. As you can see, AnyTrans is a great assistant to backup and manage iOS data. Download it now and give a free try!
