8 Ways to Fix iPhone Bluetooth Cutting Out
Are you annoyed that the Bluetooth is not working on an iPhone after the iOS 18 update? Don’t panic! Read on this post to get some quick solutions to the iPhone Bluetooth cutting out.
Author Avatar Joy Taylor Last Updated: Dec. 18, 2024
AnyFix – Fix iPhone Bluetooth issue without Data Loss
Download AnyFix to repair iPone Bluethood keeps cutting off caused by the system issues. High success rate and easy steps with no technical skills required. Support the latest iOS 18.
The iOS 18 will come to users, said to be the fastest iOS ever released by Apple. It fixes some bugs that happened before.  However, there are still some issues reported by users after the iOS 18 update, like iPhone stuck on Apple Logo, the Bluetooth not working, etc. Here we will talk about the common iPhone Bluetooth issues you may encounter after the iOS update, and give some methods to fix the iPhone Bluetooth cutting out with ease. Let’s start now!
Bluetooth Not Working on iOS Devices
Part 1. Common iPhone Bluetooth Issues on iOS 18
In the beginning, Bluetooth may just work well on your iPhone/iPad. However, after upgrading to iOS 18, some unexpected problems may occur. Issues like broken Bluetooth connections, failed Bluetooth pairing, and Bluetooth audio in the car are frequently reported. We summarize the Bluetooth issues you may encounter.
  • iPhone Bluetooth Not Finding iPhone
  • Bluetooth Won’t Connect After iOS 18
  • Bluetooth Won’t Turn on on iPhone
  • Bluetooth Keeps Disconnecting iPhone
  • iPhone Bluetooth Not Connecting to Car
  • Bluetooth Audio Stutters on iPhone
  • Fail to Initiate Calls Over Bluetooth on iPhone
  • iPhone Bluetooth Suddenly Disconnecting on Car
  • iPhone Bluetooth Connection Drops Frequently
  • iPhone Bluetooth Keeps Disconnecting
The new iOS update fixes Bluetooth issues. So if you use the old iOS version like iOS 16 or 15, try to update to the latest iOS 18, and check if the Bluetooth problem was fixed. If some other issues still exist, please keep reading and find the solutions for you.
Part 2. Possible Ways to Fix iPhone Bluetooth Not Working
We’ve listed the most common Bluetooth issues on your iPhone or iPad that you may encounter after the iOS 15 upgrade. In the following, we will walk you through the potential solutions to make Bluetooth workable again on your iPhone or iPad. Firstly, here are some basic tips you can try:
  • Check your Bluetooth on your iPhone or iPad and make sure it is turned on.
  • Confirm your iOS device and Bluetooth accessory are close to each other.
  • Try connecting to another Bluetooth device.
  • Ensure your Bluetooth accessory is turned on and connected to power or fully charged.
With some of the underlying problems out of the way, let’s explore the effective solution to iPhone Bluetooth cutting out:
Solution 1. Restart Your iPhone
Restart your iPhone X or later:
  1. Press and hold the Side button and either volume button until the power off slider appears on the screen.
  2. Drag the slider to turn your device completely off.
  3. After your device turns off, press and hold the Side button again until you see the Apple logo.
Restart your iPhone 8 or earlier or iPod touch:
  1. Press and hold the Top (or Side) button until the power off slider appears.
  3. After your device turns off, press and hold the Top (or Side) button again until you see the Apple logo.
    Restart an iPhone
    Restart an iPhone
Solution 2. Update iOS Software
Make sure that you have the latest version of all the software on your iPhone or iPad. The outdated software would cause some compliable issues.
To update the software on your iPhone: Go to Settings > General > Software Update.
Update iPhone Software
Solution 3. Turn Bluetooth Off And Back On Again
If the above two solutions fail to work, then try to turn off and back on the Bluetooth setting on your iPhone or iPad.
  • Option 1: Swipe up from the bottom bezel of your iPhone or iPad to launch Control Center > Turn off Bluetooth and back on again.
  • Option 2: Go to Settings > Bluetooth > Turn off it and back on again.
Solution 4. Disconnect from the Current Bluetooth Device
Disconnect the current problematic device, and re-pair it again to see whether the problem has been solved.
  1. Open Settings > Bluetooth.
  2. Select the connected Bluetooth device and then choose the Disconnect option.
  3. Turn off the Bluetooth device and then turn it back on to reconnect.
If this method also doesn’t work, you can try to forget the currently connected device completely, and then re-pair: Settings > Bluetooth > Choose the device you are having issues with > Tap on the info button next to the device > Tap on Forget This Device.
Solution 5. Reset Network Settings
Reset network settings on an iPhone or iPad will reset all the network settings you used before, including Bluetooth settings, Wi-Fi networks and passwords, cellular settings, and VPN and APN settings, etc. Follow the below steps to reset your network settings: Go to Settings > General > Reset > Reset Network Settings.
Solution 6. Try to Pair the Bluetooth Device to Another iPhone
Now if the above solutions don’t work, you need to check whether your iPhone Bluetooth works. So a good way to check whether the Bluetooth issue is caused by the iPhone or the accessory is trying to pair the Bluetooth device to another iPhone. If it’s successful to pair with another iPhone, it means that the issue lies with your iPhone. Then it’s time to try the next solution to fix the possible iOS system problems.
Solution 7. Fix iPhone Bluetooth Cutting out via AnyFix [High Success Rate]
If your Bluetooth keeps cutting out for iPhone system issues, you might need a system repair tool to help you. As a professional iOS system recovery tool, AnyFix would be a good choice to fix iPhone Bluetooth issues. It supports all common iOS versions, updated to the latest iOS 18. With easy steps and an intuitive interface, AnyFix can help users solve iPhone Bluetooth not working issues with a few clicks. This reliable tool can also help users to upgrade or downgrade an iPhone without iTunes effortlessly.
AnyFix – iOS System Recovery
  • Fix iPhone Bluetooth keeps cutting out without data loss.
  • High success rate in solving the Bluetooth not working issue.
  • Fast system repair process, solving Bluetooth issues within minutes.
  • Easy steps and detailed guidance to fixing Bluetooth cutting-out error.
Follow the steps below to fix iPhone Bluetooth issues:
Step 1: Download AnyFix on a computer. Launch it on your computer > Choose System Repair from the home page. Don’t forget to connect your iPhone to the computer.
Tap on System Repair
Step 2: Choose 50+ iPhone problems from the interface below > Tap on Start Now button.
Choose iPhone Problems and Start Now
Step 3: Select Standard Repair mode.
Choose Standard Repair Mode
Step 4: Tap on the Download button to add a matching firmware on your computer. Once the downloading is finished, click Fix Now.
Tap on Fix Now when Firmware Downloaded
Step 5: Then it will start repairing automatically. Once the repair process is completed, you will see a completed page.
Repair Is Completed
Repair Is Completed
Solution 8. Restore iPhone with iTunes
If all the above methods don’t help, then the last solution you can try is to restore your iPhone with iTunes. But you must be clear that restoring with iTunes requires you to erase all previous data on your device, and these erased files can’t be recovered anymore. So, before trying this solution, you’d better make a full backup of your phone.
  1. Launch iTunes on your computer (make sure that you have the latest version of iTunes) > Connect your device to the computer with its USB cable.
  2. Click on the device icon when it appears in iTunes > Choose the “Restore iPhone” option to restore your device to factory resetting, and choose the “Restore Backup” option to restore your device from the computer backup you made before.
  3. Click on the Restore button and wait for the restore process to complete.
FAQs about iPhone Bluetooth Cutting Out
Q1. Why does my Bluetooth keep cutting out iPhone?
Bluetooth cutting out on your iPhone can happen due to interference from other devices, being too far from the Bluetooth device, or obstacles blocking the signal. It could also result from software issues, like a bug in iOS, or problems with the paired device, such as low battery or outdated firmware. You can try the methods mentioned above to fix this issue. If the issue persists, consider contacting Apple Support.
Q2: How to fix Bluetooth buffering iPhone?
Here are some ways to fix Bluetooth buffering on your iPhone:
Reduce Interference: Move closer to the Bluetooth device and ensure there are no physical barriers or electronic devices like Wi-Fi routers or microwaves causing interference.
Forget and Reconnect: In Settings > Bluetooth, tap the “i” next to the device name, select Forget This Device, then reconnect it.
Update Software: Ensure your iPhone is running the latest iOS version by going to Settings > General > Software Update. Also, check if the Bluetooth device has a firmware update.
The above are some potential solutions to the iPhone Bluetooth keeps cutting out after the iOS 18 update. Among these 8 methods, we recommend AnyFix for its high success rate and easy steps. With the help of this powerful tool, you can solve iPhone Bluetooth not working issue effortlessly. Free download AnyFix to try it now!
self serviceself service
iMobie Self-Service
reduceclose
customer service
End conversation
